Results 1 to 6 of 6
    Active Member One Ring T_Southern's Avatar
    Nov 09 2016
    2013 Ram 2500 2015 Audi A4 2003 VW Passat 2004 VW Passat
    Houtzdale Pennsylvania U.S
    2.0T loud "whining noise"
    I have a 2008 A4 Quattro 2.0T. A while ago, I noticed a slight noise, sounded like a whining power steering pump, that got louder as the RPMs increased. Well it's been getting worse, so I took my serpentine belt off, and it's still making the noise. Sounds like it's in the valve train maybe. Has anyone else experienced this?
    Active Member One Ring QuattrosV's Avatar
    Jan 12 2017
    Michigan
    I have this on my B8 A4. Sound noticeable more when cold weather arrived. Through research people have suggested power steering pump, the sound isn't affected by turning the wheel at all and I have checked fluids. It is def rpm related as you go up and down, not experiencing any power loss from engine or battery.
    Alternator could be an issue, but I am not experiencing any power loss or issues, are there any symptoms of an alternator going out? Or would it just go at once?
    Any advice would be great......
    Nov 09 2016
    I believe it may be my turbo.
    Nov 25 2016
    Cam bridge screen pieces lodged in cam journal?
    http://www.audizine.com/forum/showth...-and-front-end
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    This was happening to me, turned out my passenger-side balance shaft gear walked itself off the shaft causing the chain to jump and ride the shaft (lol). Knocked a few teeth off too. Car sounded like it had a busted supercharger on it it was whining so bad.
    http://www.audizine.com/forum/showth...1#post11802460
    Don't know how common this is, but I lived with it for a couple months until finally figuring it out after replacing the motor. There is a little cap on the front of the lower timing cover you should be able to pull off to check this without doing anything too invasive, if you can get down there. Will probably have to pull the nose and radiator off though. Definitely rule out an accessory/pulley issue by running the car with the serpentine belt off first. Which it looks like you did, but just wanted to say that for anyone else reading this thread with the same problem.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    May 07 2009
    00 Audi S4-sold, ,2010 Ford Escape, '13 Q5 S-line PP, MK4 R32
    NewYork
    I had this same sound coming from my 08 A4 2.0T AT, thought it was power steering pump also. Had the sound for some time and was planning on changing it.
    The car stalled out in slow traffic the other day and had to be towed. After a premlin' investigation my mechanic thinks the cam chain snapped. He thinks it may just be valves, I know I'm not that lucky so i'm LOOKING FOR A
    REPLACEMENT MOTOR NOW now, any advice guys. Granted my first engine died from the oil pump taking a crap. This is the second engine to die on me. I luv the car but goodness, its making me think twice about
    my VW/AUDI life.
