Results 1 to 18 of 18
    Sep 23 2016
    So Cal
    Oil Brand/Viscosity in a New Q5 3.0T
    Getting to know my new Q5 3.0T and was messing around with the MMI to check my oil level. I noticed it was a little under the Max level and was thinking about adding a little oil. The manual identifies Castrol Edge Professional as an option, or an oil which meets the VW 502 00 standard. I was wondering what brand oil and viscosity does Audi use when the vehicle is manufactured. I could not find that specific information in the owners manual. Can I buy any oil which meets the VW 502 00 standard or should I try to match what is currently in the vehicle?
    Thanks
    Mar 21 2015
    Look on the oil cap, it's castrol edge.
    You can use any oil you like, i would recommend to stick to the vw standard though. Lots of guys use Motul or Liqui Molly.
    https://www.audiusa.com/content/dam/...e-Bulletin.pdf
    Get a dipstick, dont trust the mmi
    Sep 12 2016
    Natick/MA
    Dip stick ...... links please
    Mar 21 2015
    Quote Originally Posted by TITAN_Q5 View Post
    As you wish
    https://www.ecstuning.com/Audi-Q5--3...vice/Dipstick/
    Sep 23 2016
    So Cal
    Thanks 14. I've seen the link below for the dipstick for a Q5/SQ5 3.0T. It says it is a Genuine dipstick from Audi, but I was wondering if Audi makes an all metal dipstick. The one in the link below looks to have a plastic level reader attached to a metal stick. I was planning to leave the dipstick in all the time and was a little concerned with that piece of plastic; could it possibly work its way off the metal stick after being exposed to the hot engine oil environment for a long period of time. I may just be paranoid.
    https://www.ecstuning.com/b-genuine-...ck/06e115611h/
    Mar 21 2015
    The link i just posted is an ecs metal version. Others have had your concern about the plastic dipstick too. I went with the metal too, it gets hot as hell so be careful grabbing it.
    Mar 21 2015
    I've had both plastic and metal and can vouch they are the exact same length too.
    Sep 23 2016
    So Cal
    Thanks 14. Did not see this post before sending out my other response. This eliminates my previous concern with the Genuine Audi dipstick. These look sharp.
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    I use Mobil1 0w-40
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Holy shit! The R8 uses something weird, like 10W60, that has to be special ordered and is very expensive. WTF?
    One of those things they don't tell you about before you buy it. . .not that it would have stopped me.
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Pennzoil Platinum Euro 5W-40 and getting oil analysis done by Blackstone labs.
    Quote Originally Posted by SQive View Post
    Darrin, that's a real first world one percent type of problem LOL!
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Apr 26 2014
    DFW
    Far be it from me to lack something to bitch about.
    However, I don't think any one-percenters concern themselves with oil changes.
    Sep 23 2016
    So Cal
    [QUOTE=riceboy22;12108135]Pennzoil Platinum Euro 5W-40 and getting oil analysis done by Blackstone labs.
    How often do you get the oil analysis performed? I'm new to all this, what are some of the specifics that the analysis will tell you about the condition of your engine. Thanks
    Mar 21 2015
    [QUOTE=auntrout;12110061]
    Quote Originally Posted by riceboy22 View Post
    Theres plenty of oil analysis on here, search Blackstone and you'll probably have quite a few of the sheets to look at.
    Senior Member Two Rings Hopperstien's Avatar
    Jul 29 2011
    2007 Corvette
    Palm Beach, FL
    This was my original thought.
    '14 Q5 3.0
    pw211:I would owon it ND THEN beat the **** aout of it witeh a god damn penguin
    Mar 26 2015
    New York, NY
    Yup, as @14S4GWM mentioned, there should be plenty of references out there. You can start with the Blackstone website: Blackstone Standard Analysis. The basic premise is that it's a good way to get an idea of the condition of your engine by analyzing the contents and condition of your oil. My first report is here.
    Current
    Past
    Sep 23 2016
    So Cal
    thanks I'll do a search.
    Sep 23 2016
    So Cal
