Results 1 to 17 of 17
    Established Member Two Rings vik0wang's Avatar
    Jun 02 2016
    north california
    Want to know how much does labor cost to uninstall an air suspension.
    Due to new wheels are too big. So won't able to air out anymore. So want to moving on to coilovers. But if labor cost a lot. I would give up.
    VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV V
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    Was charged $400
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    It should be a crime to install air suspension. It looks so f***ing dumb.
    Veteran Member Three Rings Jester2893's Avatar
    May 29 2012
    Quote Originally Posted by 4Rings3Liters View Post
    I guess the ability to change ride height "looks fucking dumb."
    Jul 04 2008
    York, PA
    Quote Originally Posted by Jester2893 View Post
    Correct, the wheels were not meant to be inside the fender.
    Mar 03 2011
    Southern NH
    Don't feed the troll
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    totally agree.
    Apr 04 2012
    MSP
    How much was it to install? Should cost the same.
    Mar 03 2011
    Southern NH
    Quote Originally Posted by MrFunk View Post
    Around 1500 to install. Depends on complexity of course. It's easier to uninstall than to install
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Why don't you get wheels that fit instead?
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    I was quoted around the same to uninstall as to install them. The most logical fix I would say is to get new wheels
    Apr 11 2012
    ...but dem rimz tho.
    Jun 02 2016
    north california
    Because I didn't know the tires are that wide.
    Jun 02 2016
    north california
    Quote Originally Posted by phillips2024 View Post
    Was charged $400
    Thx!!!!!!!!!!!!!!!!
    Jun 02 2016
    north california
    Quote Originally Posted by EHesh14 View Post
    Wheels cost more
    Senior Member Two Rings Mr.Jones18's Avatar
    Jun 19 2013
    2000 Audi S4
    Appleton, WI
    Quote Originally Posted by vik0wang View Post
    Why waste the time and money to switch suspension? I understand if you can't air out but why go through all the trouble of having to put the car on stands if you wanted to change the ride height and lose the convenience of instantaneous adjustability with air? Just pick a height that allows you to drive the car and then leave it at that. Just seems like you're just going backwards to me...
    Jun 30 2009
    Washington DC
    Thinking the same thing. Is there a reason why the OP can't just adjust the height that would fit the new wheels and leave it at that?
    If your goal is to raise the car. Some coilsovers i delt with could never be adjusted to the max height. The max height was also a little less then the sports setup.
