Results 1 to 4 of 4
    Nov 02 2005
    2017 SQ5
    MN
    SQ5 255/50/19 Winter Tire Pressure
    Any recommendations on proper tire pressure for the SQ5 in 19" format?
    I don't feel like the 21" pressure is appropriate for a taller tire. The ride is pretty bouncy as is. Can we run the Q5 19" pressure around 30psi?
    May 06 2015
    Minnesota
    I have that same tire size (Pirelli Scorpion Winters) and have been running at 35 psi. Ride quality and handling seem good.
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    The manual recommends 30 psi front-and-back for normal load and 33 psi front-and-back for full load on 235/55 R19. You're running a wider tire on the same diameter, so the general rule of thumb is you run a lower pressure than that. That's offset a bit by the fact that you're running a winter setup where you'll normally want to run a slightly higher pressure. Net effect I think is that right around 30 psi is probably the pressure to start at.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Sep 12 2016
    Natick/MA
    Quote Originally Posted by riceboy22 View Post
    Well I asked this same question to the dealership service exec and he had told me run the same pressure as ur 21s :(
