Results 1 to 15 of 15
    Jun 02 2016
    South Florida
    Shaking when idling and acceleration
    2013 A4
    35,000 miles
    Recently maintenanced
    Aftermarket suspension, wheels, stage 1 APR
    So my car is shaking in park and it gets even worse when I accelerate. The check engine light is on and started blinking right before I turned off my engine. EPC light is also on.
    So judging by search function results, it seems that there's a good chance it's misfiring. Any ideas what the culprit could be?
    Jun 02 2016
    South Florida
    Maybe coil packs?
    Aug 30 2014
    United States
    Blinking check engine light is misfire in Audi world. I've read that 2.0T coil packs fail for no reason. If you have a code reader you can see which cylinder is misfiring. Swap coil packs and then check codes to see if misfire changes to different cylinder. If not, then check spark plug.
    Jun 23 2013
    PacNW
    checking the codes is free at Autozone, Napa, etc.
    Don't waste money until you confirm the problem, the data is there.
    Nov 12 2016
    Fl
    Just wondering, did any of these problems occur before the tune?
    If so, you could probably have your tuning shop flash it back to stock, drive it around, if it still misfires, send it back to Audi for warranty service, then have the running shop flash back to the APR tune.
    At least where I live, each subsequent flash would be $50 since you're already a customer
    Of course you might want to call up your tuning shop regarding cost
    Another option to keep in mind
    Feb 02 2016
    It's prolly the coil Park, happened to me 2 weeks ago.
    Established Member Two Rings RickyB8A4's Avatar
    Sep 04 2014
    Queens, NY
    Quote Originally Posted by ak11214 View Post
    I had a similar issue. I scanned it and cylinder 3 misfired. Replaced it and now only shook past 3 RPM. Rescanned and now cylinder 4 misfired.
    I just bought a ignition coil pack and spark plug full service kit off ECS for like 120. Replaced everything (which is recommended when replacing them) and now its giving no issue.
    My recommendation is to buy your own scanner for like 30 dollars (what I paid), its great to have, scan your car and see what code the car is showing. I can give you links to what I bought. But it does sound like a misfire if you wanna jump the gun get a local shop to scan it (should be free)and replace the one thats misfiring or all one time.
    Sent from my SM-P900 using Tapatalk
    Audi A4 2011: APR Stage 2 l Audi RS4 Black/Black Grille l Honeycomb Fog light Grille l StrafeDesign Front Splitter l AWE CAT-Back Quad Exhaust l APR Downpipe & HFC l SoloWerks S1 l Carbon Fiber Valance l Carbon Fiber Trunk Spoiler l Halogen to Bi-Xenon headlight
    Established Member Two Rings Hybrid81's Avatar
    Sep 18 2016
    Delaware
    Just had similar issues after going APR Stage 1, though my misfires were exclusive to cylinder 3. It was the spark plugs.
    I guess replacing them every 10k is a real thing. It's worth it.
    Also worth it: a Bluetooth OBDII adapter and the torque app.
    It's a $20 combo that lets you run all kinds of system checks and stream realtime data while you drive. I scan for fault codes everyday on both ends of my commute.
    Brilliant Black A4 Sline | 6MT | APR Stage 2 | Escort 9500xi | JHM Short Shift/BFI | CTS K04/Unitronic IC Next
    Established Member Two Rings heatseeker23's Avatar
    Jan 04 2016
    B8 A4 Quattro | MK5 GLI | | GMT900 Silverado | MK2 TTS 15' (retired) | MK4 VR6 12V (retired) |
    Dallas/TX
    coil packs either misfiring on not connected properly. let us know an update.
    Instagram: @TheHeatSeeker
    Jun 02 2016
    South Florida
    Thanks for all the help guys.
    Unfortunately, it's a bit more complicated than spark plugs or coil packs from what the mechanic told me.
    They found oil in cylinder 3, and cylinder 3 had no compression. Not exactly sure what the cause is, but they're thinking the engine will have to be replaced entirely. Thank god its still under warranty. Will post a more in-depth update tonight when I speak to my mechanic in person
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    Hopefully your APR Stage 1 didn't throw a TD1 flag on your car.....
    1997 BMW M3
    CES Stage IV (651rwhp/615rwtq @ 24 psi)
    2020 S6
    Premium Plus, Black optic, performance exhaust
    2013 Audi A4 (sold)
    Prestige package, S-Line, 6-speed |IE Stage 2 | IE Performance Downpipe | S4 exhaust swap | ECS Luft-Technik intake | ECS Luft-Technik FMIC | RS4 grille | ECS SSK | ECS Trans/Diff Inserts |
    Jun 02 2016
    South Florida
    I just had it removed so I can take it to the dealership. I was under the impression that it won't set off the TD1 flag if you flash back to stock 99% of the time. Is that off base?
    Jun 02 2016
    South Florida
    So my shop said the piston(s) snapped and the cylinder wall is screwed as a result. Is this a common issue? Shop claims it happens all the time. I've been searching around but can't find much on it.
    Jan 19 2016
    Orlando, FL
    Quote Originally Posted by kcbar58 View Post
    The piston snapped, like in half? Rods are thin and usually snap, pistons will make contact with valves, or ring lands will break and destroy cylinder walls....but a "piston snapped" doesn't make sense to me
    1997 BMW M3
    2020 S6
    2013 Audi A4 (sold)
    Jun 02 2016
    South Florida
    Quote Originally Posted by BMWManiac View Post
    Sorry, wrong terminology. What was told to me was that it "exploded". Apparently due to the ringlands breaking.
    Here's the newer thread with updates:
    http://www.audizine.com/forum/showth...er-APR-Stage-1
