Results 1 to 26 of 26
    Jun 06 2016
    Florida
    How To: Replace HPFP Cam Follower
    Hello everyone! I decided to replace my cam follower today and thought why not document in case others want/need to also? I come from a B8 A4, and cam follower failure can lead to a damaged cam/motor, and their lifespan on the A4 is 30k but most people recommend changing every 10k because they're so cheap, and not replacing them can be costly.
    For those who are unaware, the high pressure fuel pump creates fuel pressure off the camshaft lobe. Everytime the cam spins, it causes the hpfp spring to push in and out, creating a metric shit-ton of fuel pressure as required for direct injection. The cam follower is the mediary between the hpfp spring and the camshaft.
    TOTAL TIME: 30 - 45 minutes
    PARTS
    You will need a new cam follower listed here , I went with the INA follower. Although not required, I HIGHLY recommend getting 2 brand-new bolts that hold the hpfp onto the vacuum pump. You can find them here, make sure you choose the right bolts for your production year!
    INSTRUCTIONS
    STEP 1: Locate hpfp/clear surrounding area
    The high pressure fuel pump sits directly behind a black metal shield. I have a USP intake and had to remove it, you may need to as well.
    STEP 2: Remove black shielding
    Get a 10mm socket and remove the 2 bolts below. The black shield will just pull right off.
    STEP 3: Disconnect fuel lines
    Use pliers to take off the black hose and hold a rag as fuel will spray, then use a 17mm wrench to loosen the bolt holding down the metal fuel line next to the black hose. Fuel will spray here too, but not as violently. Use rags/tampons/your cat etc.
    STEP 4: Disconnect ignition coil harness/sensors
    I found that this made things much easier and faster. Use a T15 to remove the 2 bolts holding the ignition coil harness to the valve cover. Disconnect the 4 sensors that run to the ignition coil harness (2 on top, 2 connected to the hpfp underneath. I didn't take pics of this step but it should be easy enough!
    STEP 5: Remove hpfp bolts
    Use a size 6 hex bit to remove both bolts holding the hpfp onto the vacuum pump. Once you do so, the hpfp will be loose and everything should look like the below picture.
    STEP 6: Remove hpfp
    Pull the hpfp directly out. I had to slightly bend the metal fuel line upwards to fully release it. If you're lucky, you will catch the cam follower as it slips out. Unfortunately I didn't...
    Here are pics of the hpfp removed. The pics aren't really good for anything, but I've used pics from other how-to's to cross reference other unrelated things I'm doing, so why not take them?
    STEP 6: Install cam follower
    Note the groove in the below picture, it is very important as you need to line up the notch on the new cam follower into it.
    ALSO, VERY F****ING IMPORTANT!!!! Install the new cam follower JUST LIKE THE PIC BELOW! The "roller" side should seat INSIDE of the vacuum pump, and the spring on the hpfp should sit INSIDE the flat part of the cam follower. If you look at the 2nd pic below, that is how the cam follower is to be oriented. DO NOT MESS THIS UP!
    STEP 7: Reverse install
    Read all steps up until this point and reverse them. Use the new bolts (or reuse your old ones) and install the hpfp to the vacuum pump. Connect all sensors, and connect the fuel lines. It took my car about 10 seconds to fire up as there was no fuel in the lines. Once you start her up, check for any fuel leaks and tighten down anything if you do.
    Random thoughts
    Ever since I've owned this car, no one could tell me anything about cam follower replacement, or when it should be done. I've talked to lots of vendors at car events, and none could tell me anything. Most have never heard of a cam follower failure on the S4, although it does happen on the A4. I've put 45k miles on my car since I've owned it, and the cam follower I removed still looks useable. On an A4, I would have shit myself at the thought of a cam follower being in there that long. It is completely possible that the S4 cam follower requires no maintenance, but for my ease of mind it is replaced.
    Also, if anyone is doing an AUTOTEC hpfp spring upgrade, you would follow the exact procedures here, but then disassemble the hpfp and install the new spring.
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    I'm happy to see yours had the same wear marks as mine! Was worried it wasn't normal. Realistically it's not necessary on our rollers but I saw the stripes/wear on mine and replaced it as well.
    Jun 06 2016
    Florida
    Quote Originally Posted by LittleDozer View Post
    I was pleasantly surprised when I saw mine. When I replaced my A4 after reading a thread on cam follower failures, I immediately did mine and it was in much worse shape. My car has 116k and who knows if it was ever replaced before I bought it at 70k.
    Jul 21 2004
    South Florida
    Thsnks for the writeup. Could you tell the service life yours may have?
    Mike
    2018 Audi S5
    Gone-
    Jun 06 2016
    Florida
    Quote Originally Posted by bhvrdr View Post
    Mike
    Honestly I couldn't. I've owned the car and put 45k on it without changing the cam follower, and it still looks useable. I wouldn't be surprised if it's never been changed out, til today.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    How necessary is this? I came from the B7 works where follower replacement was a must. I replaced 5 over the 75k I had it. I thought the new roller design wasn't supposed to need maintenance?
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Jun 06 2016
    Florida
    Same with the B8 A4, requires constant replacement. I couldn't find any info in regards to the S4 cam follower or replacement schedule, so I just did it anyways. Like I said in the post above and my original post, it's entirely possible that the cam follower is a lifetime item just based off the low wear on mine.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I'm going to install my autotech soon after the holidays. After just reading your post I ordered a new cam follower and new bolts for the job! Thanks for the detailed info. Good piece of mind while I'll have it apart anyways.
    Veteran Member Three Rings blackjak's Avatar
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Great write up, this has never really come to mind as preventative maintenance but for $30, it sure is worth the piece of mind as you stated.
    11' S4 l Phantom l 6MT l Blk & Silver Napa l Sports Diff l B&O l GIAC Stage 2+ v2 l Stasis Touring l APR RSC l Alu-Kreuz l CR-15 Strut Bar lE-Codes l Stramosphere Intake l JHM Solid Short Throw l StopTech Drilled/Slotted Rotors + Akenbono l Black RS4 Mesh Grill l 034 Transmission Mount l F & R ECS Diff. Inserts l Hoen Xenon Fogs l
    Jun 28 2016
    US
    OK, so OP, why did you pick the INA one? Was it the design change that drove you to it or that it was cheaper, price wise? For comparison, here's a pic of the old design and new design of the VW OEM ones. Is it me or doesn't it seem like Audi cheapened out on the new design. Old looks machined and new looks stamped metal. WTF?! Obviously the INA ones is the old part number and they're still making it the same way Audi did originally. I have to wonder if INA was the original OEM and they since have changed to another manufacturer now who's making them cheaper. Normally I go with OEM parts, but in this case, I don't feel like putting in a cheaper designed part in that could fail sooner than the original design ones.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    For those interested, The OEM S4 cam follower on ECS was like $65, but if you look up the part number on ECS, it also brings it up under porsche, for 1/2 the price. I bought that one and have not had any issues. here it is:
    https://www.ecstuning.com/b-genuine-...06l109311~por/
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    Well spotted, BOTH followers are Linked in the OP's post under "Parts"
    The cheaper one is from INA the more expensive one is OE.
    The cheaper one you have linked is "Genuine Porsche" - what's going on here?
    Why are these followers a problem on A4's and not on other vehicles?
    Jun 06 2016
    Florida
    Quote Originally Posted by SwankP3RF3ct10n View Post
    There's no particular reason for me choosing the INA over OEM, I go to a store called Bap Geon which is basically an Auto Zone for euros/imports only and that's what they had. The OEM design looks like oil would circulate better than the INA, whether that actually matters or not is up for debate.
    Quote Originally Posted by PenttisHSR View Post
    The A4 cam followers have a plastic end which leads to failure, I don't know why it isn't fully metal like the S4.
    Compare the pics I posted to the A4 cam follower below.
    Jun 28 2016
    US
    If you check the part number (original, not revamped version) of the S4 follower, you'll see that many Porsche engines use the same part. That's why it looks the same and functions the same... but ironically, it cost less if you guy the it for a Porsche rather than an Audi... yet another example of bullshit Audi tax, even from the dealers/resellers.
    Quote Originally Posted by b8s4me View Post
    Um, no, if you're talking about the cam follower you posted a pic of, that's not plastic. It's all metal and has a low friction coating on the end of it (the black part) that rides on the cam. The reason it fails more is because it doesn't have a roller like the S4 one does, so it's basically metal on metal riding and the follower's coating up top is only so good. Eventually, it wears away and that's when more wear happens and eventually fails when the cam wears through the metal fully.
    Also, I think you might have missed the point on the previous thing about the differences between the INA one for the S4 and the new revised OEM one. Your original you pulled out is like the original Audi OEM one and the INA one.. the revised one just seems cheaply made to me for some reason since it's stamped steel and not nearly as robust looking as the original one. Make sense now?
    Dec 22 2016
    England
    Brilliant - thanks for the information.
    Oct 10 2012
    Zionsville and Saint John IN
    Do you have to dip the new cam follower in oil before installing?
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by richardm0025 View Post
    I would
    Jun 06 2016
    Florida
    No. Wouldn't be a bad idea though. Oil will circulate to it when you fire up the car.
    Junior Member One Ring
    Feb 11 2017
    Taunton, UK
    recently my HPFP fuel pump has developed a loud ticking noise so today I removed the fuel pump to investigate and found the cam follower jammed in the housing and unable to move along its guide track so I removed the cam sensor housing. Unfortunately in doing this the cam position plate on the end of the camshaft came off too. it looks like its just pushes back on but there are no indication marks as to what position it should be in can anyone advise please?
    Feb 16 2024
    Oahu hawaii
    Sorry to bump such a old thread. But I searched and could not find anything. Just like the poster above. I can't get my cam follower out. I do not want to remove the housing. Is there a way for it to slide out? It feels like it's being locked into place every time I pull it down. Moves quarter inch then nothing. I can move it quarter inch back and forth in housing.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Use a magnet. There should be no reason why it won’t slide in and out, outside of just some oil resistance on the sides. It’s like a piston in a cylinder bore, nothing special.
    Senior Member Four Rings
    Jun 08 2021
    PA
    If the bore and surface of the follower is worn it may be binding up in there. If you get it out make sure you inspect it thoroughly.
    Feb 16 2024
    Oahu hawaii
    Tried with a magnet. It's stuck inside. I ended up putting the new hpfp in since I needed my car back to drive. Works and no weird noises. Just concerning that I was able to remove the CF.
    Nov 20 2012
    NorCal
    this is weird - mine pretty much fell out with the fuel pump. 152k miles.
    Aug 05 2013
    N/A
    Yeah, that shouldn’t be stuck. It should come out. Even though the ones on this engine have an actually roller for the follower, they still need to be changed for high mileage cars, so you’re gonna wanna go back in there and figure out what’s going on before you really have issues.
    Feb 16 2024
    Oahu hawaii
    Yeah I totally agree. Might try again this weekend. Worst case is remove housing but was worried something might break like the other poster had.
