Results 1 to 11 of 11
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    What's the deal with oil pumps???
    So since I'm doing a stroker build, and my engine had 120k on it, I decided I should replace the oil pump along with it. I've looked everywhere for a good deal and I'm just confused now.
    I started on eBay, found a few OEM oil pumps for $50-$60. I ordered one, got some Chinese oil pump, so I sent it back. Ordered another one from a different seller, same thing. They both assured me that it was OEM, even though it was made in china...
    Decided to order an oem from a parts retailer. Paid $170 for an oem pump... got the same Chinese pump...
    Has Vw/Audi outsourced this part to the Chinese??? Are there any good deals on reputable pumps that anyone knows of?
    19' Glacier S4 Black Optics
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Has it got the rings on it? If so then I guess VAG must be getting them made in china now. If not... well...
    Aug 26 2007
    The sprocket on the front and the pickup tube do, the pump itself doesn't. One of the eBay pumps had rings on the pump, but it looked like a 4th grader chisled out the shape.
    Aug 15 2016
    Western Canada
    Hmm how's it compare to the pics on ECS?
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    A lot of VAG replacement parts are made in China unfortunately. Strange that they are having replacement parts made in a different location than parts they use to manufacture the car initially. Probably cost cutting effects.
    Aug 12 2011
    Palmdale/CA
    Do you guys know if the engine has to be lifted to get the oil pan off?
    Aug 26 2007
    Quote Originally Posted by 5ktq View Post
    The genuine oem on Ecs looks like the same one that came out of my car, but $200 is quite a bit for a pump. The only thing is, some of the other places had the same pictures as Ecs does, and I still got the Chinese one.
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Quote Originally Posted by ss10zidane View Post
    That or the sub frame lowered.
    Oct 02 2006
    Wadsworth,OH
    Oil pumps in these cars are mechanical. There's really nothing that can go bad on the oil pump itself. The pickup tube can get clogged but that's due to sludge and not a mechanical issue. The biggest thing is checking the clearance. Which you can read about in the link below.
    http://www.audizine.com/forum/showth...leshooting-DIY
    I'd say as long as the clearances check out go ahead and run whatever pump you bought.
    Jason
    Aug 26 2007
    Jason
    good info there,
    either way i will return in, theres no way in hell im running a $170 chinese pump haha, id rather buy the $60 kolbenschmidt you guys sell.
    Are any of the non OEM pumps you guys sell made in germany? i.e. Febi, Hudson, etc?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by FromS60toB61.8t View Post
    good info there,
    Febi is made in Germany.
    You can see from this pic the last 3 letters in Germany through the sprocket :)
    Jason
