Results 1 to 18 of 18
    Established Member Two Rings obec0001's Avatar
    Apr 03 2015
    SW Fl
    Best OBD2 dongle and app for iOS
    Hey guys have been searching and reading a lot on this but which dongle and app have you guys found to be the best out there for our platform that offers the best features and functionality for iOS phones and devises.
    2012 b8 S4 Ibis white CTS Exhaust with AWE resonated DP with TAMPA Autosports race cats and Ported supercharger , ECS luft technik carbon intake, APR cps system with reservoir,GIAC stage2 dual Pulley ,FD187mm crank GIAC Tcu tune with duel pulley file and GIAC fuel pump kit.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by obec0001 View Post
    I would have said Carista, and probably still would, but I have had nothing but issues lately. I am certain that Carista would say its because I'm not using their dongle, but I personally think otherwise with the iPhone. Apple limits apps to wifi connectivity though, so I guess you could maybe say there is blame on both sides. Just as an example, I needed to have my car inspected yesterday, but had forgotten that I disabled the amber corners in the headlights. It took at least 30-45 times of trying to connect to the car with my Amazon dongle (comes up as VLINK) for it to actually pull up the settings for the car. Maybe this would have been different with Carista's dongle, but it took a similar amount of attempts to disable them again afterward. I have found that for some reason, mine only seems to connect in airplane mode with the wifi on, but even then its a multiple attempt sort of endeavor. It was honestly very frustrating, because I keep the dongle in the car to read codes on the fly when I don't have my VAGCOM and a computer handy, but its hard to put faith in something that has so much trouble connecting to the car; it honestly really makes me wonder if I am negatively impacting my car in some way (but then I justify that's just me becoming paranoid IMO). Their support is generally pretty good on the other hand, but even then it can take some time to respond as they explore new platforms.
    5 out of 7.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Am I missing something? I thought Carista connects via blue tooth to the adapter and your tablet / phone
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Quote Originally Posted by jygesq View Post
    It does...and bake's point about limiting apps' connectivity to WiFi isn't true.
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by hotleadsingergu View Post
    Do you both have android phones? iOS is limited to Wifi only. OP specifically said using iOS.
    http://www.caristaapp.com/help/
    Post #92, the creator of Carista. http://www.audizine.com/forum/showth...-our-car/page3
    °2011 A4 | 6MT
    Mar 21 2015
    Ios and android connect differently, Ios is wifi
    Established Member Two Rings jjslegacy's Avatar
    Oct 14 2006
    2015 S4/2013 Q7
    Cleveland
    buy a cheap android device that works with obdeleven - seems to be a much better solution.
    JJ
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    I don't know if its the best but I use a KIWI 3 and OBD Fusion on my iPhone. I like OBD Fusion because you can create custom PIDs.
    The KIWI 3 with OBD Fusion use Bluetooth LE on iOS.
    2016 S6
    Mar 21 2015
    Quote Originally Posted by AudBoost View Post
    I was speaking for Carista, sorry about that.
    Oct 19 2016
    Austin, TX
    I use the Carista adapter with Bluetooth LE. iOS here
    Aug 23 2015
    Texas
    As someone with the Carista adapter and app on an iPhone 7 Plus, hotleadsingergu's answer is correct. The Carista app will connect via Bluetooth to the Carista adapter.
    And here's proof:
    Also my OBD Fusion gauges:
    Oct 19 2016
    Austin, TX
    How do you get the boost reading?
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Use Carista w/their BT dongle for my iOS - should be on sale in a few places for like $20/$25
    Worth it even is just used for electric rear brake pad DIY service
    Jun 18 2015
    Cleveland
    Quote Originally Posted by bakedziti View Post
    I didn't say Carista uses Bluetooth, I said the explanation isn't correct. Apple doesn't limit iOS devices from connecting to other devices via Bluetooth in apps...I've developed apps for iOS that utilize Bluetooth to its full extent. Imagine all of the pay apps/structures that wouldn't work if that were true (Paypal, Square, etc...), or the number of FM Transmitters that wouldn't work, or the number of Bluetooth Thermometers, etc... Apple doesn't limit it at all, the developer just never figured out how to make it work correctly, so it's shoddy. It works with most transmitters, but not all.
    Aug 23 2015
    Texas
    Quote Originally Posted by Jsalicru View Post
    OBD-II PIDs for Audi B8 / B8.5 S4 / S5 3.0T
    http://www.audizine.com/forum/showth...8-5-S4-S5-3-0T
    Aug 02 2019
    Alberta
    OBDEleven's newest generation is compatible with iOS and I will be ordering one eventually. They are currently out of stock for who knows how long. Might have to settle for the earlier Android only version, we'll see. But OBDEleven has the same functionality as VAG-COM, which is why I was looking at it.
    Sep 24 2019
    LA, US
    Each one has their own favourite app, only you can choose the best OBD2 app suitable for your requirements. This article list some popular apps along with detailed features, pros and cons: https://www.obdadvisor.com/best-obd2-app/, may be it will be helpful for you
    Oct 29 2015
    Los Angeles, CA
    Quote Originally Posted by omegis83 View Post
    And here's proof:
    Which SAE PID is the one for timing?
