I just got a new set of Raceland coilovers. I've seen people talking about torque values when installing coilovers. Is it necessary? Or can just tighten everything tight do it? If so I been looking around but haven't found a define answer. What are the torque values for:
Front:
1. Tie rod arm to steering knuckle. Both vertical and horizontal bolts.
2. Lower control arm sway bar end link.
3. Strut fork to hub bolt.
4. Top 3 bolts holding the strut to the vehicle.
5. 2 upper suspension arm bolts.
6. The single nut on top holding the strut assembly together.
Rear :
1. Bolt holding shock to the lower control arm.
2. 2 bolts holding the upper strut mount.
3. Upper control arm to hub.
4. Rear subframe bolts
I don't know a whole lot about suspension and everything. So bare with me. This is my first set of coilovers just looking to lower the car and that's it. Not gonna track it or anything like that. Any help is appreciated. Thank you.
Sent from my LGLS990 using Tapatalk
