I replaced my ignition coils about 2 years ago with cheap ones. One went bad while on a road trip, leaving me stranded and needing to be towed and then spending $250 for a dealership to replace the bad one. Just recently, while accelerating uphill at 70mph+, twice, I got a shutter that felt a lot like a misfire. So I'm thinking of replacing the coils and plugs again.
My question is, do high-end coils make any difference over OEM quality on a car that has no performance upgrades? Other than reliability and build quality? Doe high-end coils burn fuel any better, get you better performance/power/mileage or less carbon build up? Or should I just go with OEM level? A basic OEM level kit with new plugs from ECS. Or, I could spend $250 for Huco red coils with iridium plugs. There's another set (Karlyn coils) that comes with the same NGK iridium plugs for $130. Some of these sets say they are one heat range cooler for cars with basic performance mods. I don't have any performance mods. Would it hurt the car to use those?
Also, should I replace wiring, and if so, is that easy to do? I haven't even looked into that at all yet.
Thanks guys!
