Results 1 to 4 of 4
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    RS6 cold start issues
    Having a lot of cold start issues when it is very cold in the morning.
    Will have low/rough idle on start up and cannot rev motor. Does this until motor starts to warm up, then must turn off car and turn back on. Will return to normal idle, can rev and drive normally.
    This morning was a bit different in that the car started at low idle but lights began to dim/turn off until the car died. Points to alternator issue?
    I jumped the car. Battery voltage meter on jumper pack showed 12.5V and as the car idled longer it rose to 13.8V.
    At this point the car ran normally and I was able to drive to work.
    Ideas?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by mr_dave View Post
    Did you scan for any codes?
    Note yet. Vagcom end of this week.
    Thanks for the links.
    I guess a leak test ('smoker') is called for if the vac system is considered a potential culprit.
    I had the venture vac jet Y thing fail on other cars before. On the 2.7T and 1.8T I typically 'clean up' the evap/recirc monster and get rid of it.
    05 Golf TDI
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    Quote Originally Posted by vtraudt View Post
    The RS6 does not have the vac Y in the most convenient spot...
    -Avantwerks Audi Customization Specialist
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
