Results 1 to 19 of 19
    Established Member Two Rings someguy1.8t's Avatar
    Nov 11 2009
    Woodland Hills, CA,
    Torn fuel line. Please help
    So the upper fuel line has a puncture and is dumping a lot of fuel since it's high pressure. I found out when I smelled the gas from inside the car.
    Can anyone please tell me what the part number is for this hose?
    Can I buy this hose from an auto parts store like autozone or something?
    Has anyone changed this before? Can I do this with out dumping fuel all over the place while changing it?
    Thanks for your help
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    For a short term fix pick up a hose barb and two fuel line clamps. cut the hose at the pin hole and insert the barb. Clamp and done.
    There is a part number on the fuel line. Record the number and punch it in to ECS, Europaparts, etc for a replacement.
    Apr 15 2014
    Ottawa/Gatineau Canada
    What old guy said.
    Also, can you circle where the leak is? I bet it is from that broken hanger rubbing on the line. I would remove that hanger... just pulls right off.
    Nov 11 2009
    Woodland Hills, CA,
    That is correct Luxus Panzer. That's exactly where the hole is. Old guy. If you don't mind can you explain again what to do with the parts you mentioned.
    Dec 28 2006
    Western Maryland
    Cut the fuel line in half where its leaking. Insert the hose barbs into both sides of the cut hose. Secure the barbs in place with the fuel line clamps.
    Nov 11 2009
    Woodland Hills, CA,
    Oh I get it now. Thanks old guy I really appreciate it
    Jan 24 2010
    Paramus,NJ USA
    I would recommend replacing the line but the barb is a good temporary solution.I ran into a similar situation last year.Good thing the car was cold and kept cranking but didn't fire.I smelled fuel so I poped the hood and there it was in all its glory pissing like there was no tomorrow.Cant blame it original hose with 330k mikes on it lol.Anyways you can use the same clamps old guy listed and just buy some fuel hose.Make sure it's for fuel.Fuel hoses have a double wall and are made specifically for fuel also make sure the hose you'd get is rated for the fuel pressure.All of this info should be on your original fuel hose.I went this route cause the factory hose was close to $170.I got clamps and some fuel hose for $15 at a auto parts store.
    Ziddy Autowerks
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Looks like 8E0201541J, which also appears to be NLA
    Should be able to just replace it with the same size, not-moulded fuel hose
    Nov 11 2009
    Woodland Hills, CA,
    Thanks guys
    Senior Member Two Rings Captain_Panic's Avatar
    May 01 2015
    B6 A4T, VS800, C6 A6, Conversion Van
    Dublin, Ohio
    What you are wanting is FUEL INJECTION HOSE, not fuel hose. The regular fuel hose is for older vehicles with carbs. I used to work in parts stores.
    Also, what the hell is that blue thing where the hole is?
    02 A4 1.8t Quattro 5sp, APR stage 1, downpipe, forge splitter valve, Silicone boost hoses, K&N drop in filter, ECS vent boost guage, ECS 2.0 TSFI coil kit. Racetec FMIC. My A4 is proof that slow cars can still be fun to drive.
    Aug 15 2016
    Western Canada
    Yeah, the reinforced stuff for injection. Carbs are getting pretty rare these days, so i didn't think to mention that.
    that was the plastic holder for the hose but it's broken. Not sure why it has turned blue,
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Captain_Panic View Post
    8D0201449M Fuel line retaining clip.
    Dec 05 2007
    You can pick up 5/16" hose from Autozone for like $1/ft (probably more expensive, but not far off from $1). They have a lot of things behind the counter, and fuel (injection) hose in various sizes are there too. You only need one foot, and that will probably be cut down. But get like 3-5 feet, and store the rest at your home. It comes in handy. Been running Autozone lines on my high flow rail for a couple years now. Then I used GEMI rolled edge worm clamps.
    Apr 15 2014
    Buddy of mine is a master VW mech and he told me they have a tech builtin regarding this part...told me they just remove it. He was surprised to see it in my car.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Nov 11 2009
    Woodland Hills, CA,
    Thanks for all your help guys. Yeah that damn clip is was crumbled due to engine temps and old age. Then the sharp edge punctured the hose. I removed it now but only after it was too late.
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    Saw a b6 with an underhood fire on the way home tonight! Made me look up this post and see the posters location :)
    Lucky for you, not so much them!
    Fresh parts at the pick n pull!
    Nov 11 2009
    Woodland Hills, CA,
    It's crazy I think I drove 3-4 miles before I noticed the smell. Must have dumped like 3 gallons all over the engine. Yes, I'm lucky.
    May 01 2015
    Dublin, Ohio
    Oh! I remember something like that when I first got mine. I think it broke pretty soon after I started playing in the engine bay.
    Quote Originally Posted by heywier427 View Post
    Get 'em while they're hot!
    Jan 08 2010
    CT Shoreline
    Lol. Clever
