Did a VCDS scan and it came up with:
Code:
1 Fault Found: 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 135 Mileage: 69755 km Time Indication: 0 Date: 2016.11.18 Time: 18:11:24
On the working mirror it's what you'd expect; 0v when off and 12v when turned on.
On the broken mirror it's a constant 4.5v, with no change when the heater is turned off or on.
So, any suggestions?
My next guess is to trace the cable back further to see if it's getting 12v at an earlier connection, and my guesses on the break location would be where the mirror bolts on to the door (in the folding hinge), or where the door bolts on to the car body.
