Results 1 to 12 of 12
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Exclamation Warranty extension natural vacuum leak detection pressure switch. (NVDL)
    Got a letter from Audi extending warranty on NVDL switch. Certain 2011-2015 audi gas vehicles. EPA required. If MIL comes on and stays ON within 10 years or 120,000 miles dealer will check at no charge to determine if NVDL PRESSURE switch is bad, if it is it will be replaced under the terms of this extended warranty. If something else is wrong then dealer will tell you and cost to fix. Looks like NO DIAGNOSIS FEE. If you go for emissions test with MIL light on car could flunk test.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Mar 21 2015
    Got mine today too
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    So that means if check engine light stays on I can go to dealer have it scanned without paying $145 scanning fee?
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Aug 22 2014
    bloomfield,ct
    Seems so.if it turns out to be that switch , they replace it, if something else they tell what it is and how much to fix, no fee for checking
    Deactivated Three Rings
    Aug 24 2015
    Got my letter too yesterday
    Established Member Two Rings CT-audi-S4's Avatar
    Nov 14 2016
    Got mine too
    Sent from my ONEPLUS A3000 using Tapatalk
    Jan 09 2009
    1of50
    Received as well
    Senior Member Two Rings robertstitt's Avatar
    Jul 24 2016
    Richmond Hill
    Add me to the "got it" list. Guess I'll put it in my S4 folder. Fingers crossed.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Natural Vacuum Leak Detection Switch warranty extension.
    Got this letter today, i'm not even sure what it is. Thought I'd share.
    Apr 05 2016
    Portland, OR
    I got mine last week as did many others.
    http://www.audizine.com/forum/showth...-switch-(NVDL)
    Also came with a reimbursement form if you had it fixed already.
    Geoff
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Got mine today
    Sent from my SM-G935V using Crapatalk
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Jul 02 2004
    FL
    Sorry for double post, I had not seen it as I have only been on the phone lately. :)
