Results 1 to 12 of 12
    May 06 2005
    2015 Lexus RCF 2012 Audi R8 5.2
    Northridge
    Stuck Accelerator Pedal!!
    Was driving last night on the freeway and I mashed the gas pedal a little bit and it got stucked. It wouldn't come up again. The throttle was just going. Luckily, the freeway was kinda empty. Had to brake hard and pull over to the side and turn of the engine. And I had to reach down and pull the pedal out. I have a B7 3.2tip. Has this happened to anyone else?
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    No, sorry to say... That sucks! Did you get a chance to look down there to see what caused the pedel to get stuck?
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Registered Member Three Rings elgallo's Avatar
    Feb 20 2004
    Have you changed the stock floor mats? That happened to me too, but I had previously replaced the stock floor mats for sisal mats, and the mat moved forward and got stuck on top of the pedal and that is what caused the accelerator to get stuck.
    '06 A4 Sedan 2.0t Front Trak CVT, Quartz Grey Metallic, Ebony Interior, Premium Package, Sunroof Package, Technology Package, 17" Wheels, Bose Audi Simphony XM, Dark Walnut Wood Trim, Votex front wings & Votex rear valance, Vibrant 1304 exhaust tips.
    '06 A4 Sedan 2.0t Front Trak CVT, Moro Blue Pearl Effect, Beige Interior, Premium Package, Sunroof Package, 17" Wheels, Bose Audi Simphony XM, Polished Vavona Light Wood Trim.
    Veteran Member Four Rings RE5PECT's Avatar
    May 29 2005
    Gone:ABT B7 A4, Matte White 335, TechArt 997.2 S
    San Diego, CA
    dam homie...thats some scarry ish...
    TAG Motorsports
    Gone but never to be forgotten...My ABT AS4
    Eurotuner December 2007....CLICKY
    Veteran Member Four Rings A4rce1's Avatar
    Jan 19 2005
    London
    wow, glad you are ok
    May 06 2005
    Northridge
    I changed the mats to a rubber one. But that is OEM and it is buttoned down, so there is no way it would move. Someone mentioned that if you step on the brake, the ECU will detect it and adjust the throttle, it didn't do it in this case. I'm bringing it this morning to the dealer to see whats up.
    2017 S6 Prestige Arras Red Mods: AWE Track Exhaust On Order: EPL Stage 1ECU/TCU, Roc Euro Intake, RS6 Mesh Grill, Eurocode Sway Bars, End Links and Alu Kreuz, Signature SV301 Wheel
    2015 Lexus RCF
    2012 Audi R8 V10 5.2
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    It was me that mentiond about the brakes and gas on at the sametime, the engine should cut out if the brakes are applied while the gas pedal is depressed, or so it was with my previous A4.
    Mike
    Veteran Member Three Rings Irish311's Avatar
    Jun 28 2005
    2013 A8L 4.0T, 1995 Range Rover Classic
    South Shore, MA
    Dude, glad you're OK. Let us know what the dealer says as I think it would be useful for everyone to hear.
    2013 A8L 4.0T Phantom Black Pearl with Black Leather, Comfort, Cam, LEDs, and Huevos Grandes (but, hey, they're fuel efficient!)
    "There is no replacement, for displacement..."
    2008 S4, Deep Sea Blue w/ Silver interior - SOLD
    2004 A6 AT - SOLD
    2004 A4 6MTQ - SOLD
    2001 A4 4MTQ - SOLD
    Dec 01 2005
    Edina, MN
    Uncontrolable acceleration was a problem with Audi's in the late 80's. People used to get run over. No joke.
    ...the uncola
    Senior Member Three Rings obviouse's Avatar
    Jan 18 2005
    2005.5 A4 2.0T QM
    I still have a problem with uncontrollable acceleration... except my foot is pressing on the pedal heavily
    New: 2013 S4 3.0TFSI S-Tronic
    Sold: 2005.5 A4 2.0TQMS, APR Stage 3, Carbonio Airbox, CIM Boost Gauge, Cat Delete, IE Rods, APR HPFP, 25th Anniversary Front End, AWE FMIC, FK Grill, Enkei RPM2s
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    My problem too!!
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    This was because people were too stupid to remember to put their foot on the brake before shifting into Reverse or Drive. That's why all automatics have a 'shift-lock' mechanism.
