Originally Posted by
VipinLJ
Exactly. Chrome breaks the monotony.
And OP. What are the 10 VCDS mods you did? Since we have the same specs, I'm guessing I could try some on my car too.
The VCDS mods I did are below. The start stop off by default, the lane assist timing, trunk close with remote and default ACC distance are all big deals to me and the rest mostly just for fun.
1) Enable window closing with remote (opening is already an option in MMI)
46 - Cent. Conv.
Adaptation - 10
Channel 62
Change value from 8738 to 48059
Test
Save
2)Changed Taillight on with DRLs
Tail lights on with front DRLs
[Select]
[09-Central Electric]
[Coding - 07]
[Long Coding Helper]
Click on byte 2 and enable bit 7
3)Enabled lane assist timing.
8E - Image Processing
Security Code: 20103
Adaptation
Menu for time of assisted steering
Activate
4)Enable coming home/leaving home function DRL
[Select]
[09 Central electric]
[Coding - 07]
[Long coding helper]
Click on byte 6 and disable bit 4
5)Disable Seatbelt Chime
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning inactive
6) Adjustment of the seat heater level lowering time (level 3 to 2)
[08] HVAC
Adaptation : Time until heated seat power withdrawal stage 3 to stage 2
Adjust value (default 10min)
(Value 0 = no automatic lowering)
Changed to 20
7)Changed ACC default setting menu enabled
Change the Adaptive Cruise Control Preset distance
[Select]
[13 Distance Regulation]
[Adaptation - 10] --> Distance Basic setting option
Change from off to on
8)needle sweep
Enable Gauge Test/Needle Sweep
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
9)Trunk close active see pic
Go to Module 46 (cent convenience), coding, long coding helper
byte 2, bit 2 "Comfort operation: Remote control active" should be checked, so no need to change it, just confirm that it's set.
No Change, Original Coding: Bit 2 checked
Then got to module 6D (Trunk Electrics), security access and enter security code "12345". Then still in Module 6D, click Adaptation, channel
and there are 8 options for "Activation using rear lid. . .". Change the two "number 4" settings to active.
Original Coding:
(1)-Activation using rear lid opening button in remote key - Touch function for opening: not active
(2)-Activation using rear lid opening button in remote key - Tap function for opening: active
(3)-Activation using rear lid opening button in remote key - Touch function for closing: active
(4)-Activation using rear lid opening button in remote key - Tap function for closing: not active
(1)-Activation using rear lid remote unlocking switch - Touch function for opening: not active
(2)-Activation using rear lid remote unlocking switch - Tap function for opening: active
(3)-Activation using rear lid remote unlocking switch - Touch function for closing: active
(4)-Activation using rear lid remote unlocking switch - Tap function for closing: not active
New Coding:
(4)-Activation using rear lid opening button in remote key - Tap function for closing: active
(4)-Activation using rear lid remote unlocking switch - Tap function for closing: active
10)Set start stop to default to off to 16 from 20
Disable/memorize/invert Start & Stop:
- module 09-Cent. Elec.
- enter Security Code (20113)
- Adaptation on Channel 34:
subtract 4 to the value --> Start&Stop always disabled
add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
- test & save
In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled
Change from 20 to 16
[Select]
[Coding - 07]
Adaptation
Activate
[Select]
[Coding - 07]
[08] HVAC
Changed to 20
[Select]
8)needle sweep
Original Coding:
New Coding:
- test & save
