Results 1 to 40 of 73
    Established Member Two Rings DAYTA's Avatar
    Dec 30 2014
    Carbon cleaning - average cost?
    What are people paying for a full carbon clean (i.e. walnut blasting) service? I had anticipated to pay around $1k for the service, but some of the quotes I've received were MUCH higher than I expected.
    Though I'll probably wait until the spring (maybe longer since my car feels pretty stout) to get mine done, I still wanted to be prepared when the time comes.
    May 20 2010
    My B7 A4 cost me $550 to get carbon cleaned. What was involved was removal of intake manifold, manually scrubbing down and cleaning the valves (by hand), then, after reassembly, running BG44K cleaner through the system do some additional cleaning.
    So to me for an RS4, $1000-$1200 sounds reasonable.
    Mar 02 2016
    Los Angeles, CA
    2.0T FSI/TSI = $450
    4.2 FSI (RS4/A6/A8) = $750
    Same work as Audibot mentioned up here in Minneapolis MN. I would keep looking.
    May 20 2010
    Quote Originally Posted by jtlund View Post
    2.0T FSI/TSI = $450
    Probably cost of living differences. Everything costs an arm and a leg in the DC metro area
    Veteran Member Four Rings Chuuey's Avatar
    Mar 06 2010
    E36
    your daddy - user on here and a shop owner quoted me around $1K.
    He's in MA and I think you're in the ballpark. Few places near me are in the same range as well.
    1998 E36 M345 T | 2017 B9 Allroad | 2002 996 GT2
    Previous:
    2001.5 B5 S4 Avant
    2009 B8 S4 6MT
    2008 B7 RS4
    1991 200 20v Avant
    2010 997 C2
    1988 E28 535is Dinan Turbo (RIP)
    2019 B9 A4
    Apr 20 2009
    Orange County, CA
    OP- where are you located? I think $1k is a reasonable estimate but as you can see, it can be a bit lower to a good amount higher. Make sure an oil/filter change is included in your price and it is also a good time to swap plugs, maybe coil packs, and also add on intake manifold spacers and a TB coolant bypass. Not to mention you will need a new OEM intake gasket.
    So, you can see that it can add up. Doing it yourself is not all that hard, just time consuming. But after you do it once the next time should be "easy".
    2007 Audi RS4
    Milltek exhaust//Stasis MS suspension//CPT control arms//TTRS steering wheel//JHM shifter/intake spacers//Apikol trans mount//034 diff mount/rear sway bar/endlinks
    Dec 30 2014
    Sorry, I should clarify that I expected to pay $1k for a carbon cleaning but the quotes I got were well above that (> $1500). That sounds like too much, even factoring in COLA?
    Senior Member Three Rings Dirtracer603's Avatar
    Aug 15 2012
    Custom stunt CRF250 supermoto, 06 CBR600rr
    Fredericksburg, Va
    I live in Fredericksburg and badly need to carbon clean the intake on my RS4. I was going to do mine myself, and while at it also look into my intake manifold as I am throwing a code for flap position. I already have the walnuy blast media, just need time to do it.
    Sent from my SM-G900P using Audizine mobile app
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    Dayta, call XLR8. They just ran a $999 fall special. See if they'll still apply that price.
    Not sure what their regular price is these days, but when I had mine done a couple of years ago, it was about $1100.
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    If you are located around norcal, jhm will be the best price around for that, i think they charge way below 1000$
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    I thought $600~$800 are fair price. Those 335 only $250.
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Seattle I paid about $1200, Dallas $799. Both great shops. Thus include spacers (JHM) + oil bypass and all new gaskets etc.
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    Quote Originally Posted by Chuuey View Post
    thats with gaskets, and walnut shell blasting. no scraping with screwdrivers, and filling with carb clean. I recommend JHM spacers, and bypass. its no extra labor. also a great time to do an oil separator, and oil change.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Mar 06 2010
    E36
    Quote Originally Posted by your daddy View Post
    ^ very fair and knows their stuff. This is where I'm going when it comes time
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Previous:
    2001.5 B5 S4 Avant
    2009 B8 S4 6MT
    2008 B7 RS4
    1991 200 20v Avant
    2010 997 C2
    2019 B9 A4
    May 20 2010
    Quote Originally Posted by DAYTA View Post
    That was clear. And yes, it's too much considering COLA. Euro-centric shops should be able to get you better prices than a run-of-the-mill. Wish I was more familiar with your area to help you out.
    Oct 11 2007
    Suburbia
    1000$ give or take 200$ is pretty much the going rate. Try to find an experienced tech that has done them before.
    Jan 28 2016
    San Mateo, CA
    FYI https://store.034motorsport.com/serv...d-engines.html
    Fun note: the pictures and dyno chart on this page are from my car.
    May 29 2007
    Quote Originally Posted by WinterRunner View Post
    <3
    Dec 12 2016
    Southeast
    Bring it to Florida, I'll do it for $400 plus actual parts. ;)
    Just bought another RS4 and about to dig into this one, too.
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by stanglife View Post
    Where in Fl are you?
    "Brake last, finish first."
    Dec 12 2016
    Southeast
    Tampa area.
    Jun 25 2018
    Sarasota
    Do you know of any places in Tampa - St Pete area that carbon clean reasonably, hard to fine anyone in my area.
    Thanks.
    Nov 24 2018
    Houston
    I'm thinking the more this becomes available, the cost has come down. Mine is in for this at the dealership at the moment and will run $500. Note, also getting 1 fuel injector replaced and the other 7 cleaned.
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    Quote Originally Posted by pointybird View Post
    which stealer is this? i should get some quotes from the dealers here in the ATX area...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Aug 31 2020
    Minneapolis
    Where in Minneapolis did the Clean out quote come from?
    Berg performance in Denver area just gave me a quote for $1400 for CC and another $300 to replace the oil housing gaskets.
    Ouch
    Hardeys motorwerks in Parker, CO at $1300 for cc.
    Apr 24 2017
    NH
    Quote Originally Posted by kRussia View Post
    Ouch
    Another option might be Black Canyon Performance. Not sure what they quote but they seem reputable. Price should be closer $800-1000.
    07 RS4 - Glut
    07 GT3RS
    96 Ram Indy
    Past: R8 GT, 11 Z06, 957 GTS, L320 RRS, 996 C4S, W202 C43 AMG, B7 RS4 (x6), JLUR, C7 Grand Sport, S550 Mustang GT, B8.5 S4, 981 Cayman, MK7 GTI, e46 323Ci
    IG: @glossed.auto
    Veteran Member Three Rings Chandler's Avatar
    Jun 07 2014
    Recycle Bin
    South East
    800-1200 is usually "reasonable".
    If you have leaky valves, some of the inlets can be "sticky" and a walnut blast make not work very well for the top slugged layer, manual cleaning will add a bit of time. Shop rates here are 90 (low end) - 165 p/hr. Any Indy shop in my area is going to be 135-165, so the shops at 90 p/h won't even touch it.
    For a a tech who has done it before, it doesn't take terribly long. If it's your first time removing the intake manifold and PCV, it may take a full 10 hours to so to remove and reassemble where as I can remove and re assembly in less than six on the high side.
    "People who think they know everything are a great annoyance to those of us who do."
    Nov 01 2019
    2007 RS4
    Sneads Ferry, NC
    I just got quoted $2,000 plus tax (OUCH) from my local Audi dealership in Milwaukee, WI. Anyone know of a good independent shop in the area?
    Jun 15 2017
    Wisconsin
    Quote Originally Posted by mjraudi View Post
    Brown Deer or Audi Milwaukee? North Shore quoted me “about” a $1000 and I’d trust Seth and their techs, far more than than the other bunch.
    We’re hugely short of decent Audi shops in Milwaukee. If you’re going to get something as big as a CC done, you might want to consider Dynarev in IL. They have experience of doing RS4’s and their rates are decent.
    2007 Phantom Black RS4. Stasis Öhlins MS, Euro FBSW, Capristo, Wingbacks, Hotchkis ARB, MkII RNSe.
    2013 Daytona Grey Q7 S-Line Prestige.(Retired but in good hands)
    2018 Navarro Blue SQ5 Prestige.
    2020 Daytona Grey SQ7 Prestige.
    Nov 01 2019
    2007 RS4
    Sneads Ferry, NC
    Quote Originally Posted by Kenny147 View Post
    Thanks for the info. Seth is my guy at North Shore. I like him a lot and trust him. He talked to one of the techs and quoted me that price mostly due to labor - said it would be an all day project.
    Jun 15 2017
    Wisconsin
    The problem with getting a dealership to do the CC, is that you really want to do the injectors and possibly PCV while you’ve got the manifold off. Going somewhere like Dynarev, gives you the option to use your own purchased parts. If you get the additional stuff done at a dealership, you’re looking at a bill that would be at least double, if not more. Audi would charge around $1200 for the injectors alone, whereas you can pick up 8 brand new OEM Hitachi injectors for around $500.
    Nov 01 2019
    2007 RS4
    Sneads Ferry, NC
    Awesome, thanks much for that additional info.
    Jun 07 2014
    Recycle Bin
    South East
    Does the local Stealership even use the walnut blasting technique? I know for sure mine will only for a chemical cleaning, or if requested a "manual" cleaning where they hand scape it. Labor is much more involved and the job is usually sub par.
    Jun 15 2017
    Wisconsin
    Yeah, one of the two dealerships we have in Milwaukee is more “reasonable” about how they approach RS’s and uses walnut blasting. It helps that they have good techs and a SM that’s smart, young and into his cars. It’s still an Audi dealership, so expensive compared to indies but that’s the price of owning.
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Mann.. a few years ago I had my RS4 cc'd for $400 at the same indy shop that swapped a new engine into my b6 s4 for about $1100 all in with a ton of extra parts installed at the same time.
    The owner told me after the fact a fair price for the job would have been about $800. They closed not long after (owner retired) and I sold my RS. Haven't owned a car out of warranty since lol.
    800 to 1000 is fair. 1100-1400 is expected. Anything over you're being overcharged and look elsewhere.
    Junior Member Two Rings
    Jul 21 2018
    Fort Wayne
    I had the same issues here in Fort Wayne IN, the local Audi dealership quoted me $2400 to pull the manifold and manually clean (two of the front end people hadn't even heard of walnut blasting!). The lowest official shop I could find was Reggie's Motorworks in Indy for $1600... thanks to this forum I was able to go to Wolfe Auto a local guy (and member of this forum) here in Fort Wayne and he carbon cleaned using walnut blasting for $600. Hard to find people who know how and then finding one at a decent price is even harder! Best of luck!
    Nov 01 2019
    2007 RS4
    Sneads Ferry, NC
    Quote Originally Posted by Chandler View Post
    I've got an appointment set up with Dynarev later this month. $800 for the carbon clean and an extra $400 in labor for replacing the injectors, pcv, spark plugs, and a few other things while they're in there.
    Jun 07 2014
    Recycle Bin
    South East
    What other things? There should be 0 additional labor for the PCV. About an hour (maybe 1.5) for plugs and injectors just because of how easily accessible everything is. I take off the rails to do my CC regardless, so really we are talking an extra 30 minutes.
    Jun 15 2017
    Wisconsin
    Unfortunately that’s the down side to Dynarev. They hardly ever adjust the price to do something that can be done easily, in addition to something bigger.
    I had them do the clutch on my car and a bunch of other things at the same time. I was mildly annoyed at some of the stuff on the final bill but they are trustworthy and there’s no one else within 60 miles of Milwaukee that has experience of RS4’s, other than the dealerships and I shudder to think what they’d charge for everything I had done.
