Results 1 to 14 of 14
    Mar 30 2015
    Denver
    Recommended shop for caliper painting/powder coating?
    I'm thinking it's time to get rid of the boring black calipers and go with something a bit sportier looking.
    Any local shops that can be recommended for powder coating or painting them?
    On an unrelated note - any local shops/mobile guys that you can recommend for curb-rash repair? Don't judge me --- it was one dumb mistake :)
    Thanks in advance.
    2013 S6 - Estoril Blue - Lunar Silver
    Mar 30 2015
    Denver
    Bumping...because I'm bored. Anyone?
    Senior Member Three Rings ProfileX's Avatar
    Mar 12 2009
    S5 2011
    Denver, CO, USA
    The guy I've used a few times for wheel finish repair didn't do so great the last time so I can't recommend him anymore. I've never had calipers painted, but I was considering it and asked Berg Performance about it. FWIW they answered questions intelligently and seemed confident about painting them.
    Jan 01 2012
    2004 A4 Avant
    CO
    I've used mark at Colorado powder coating for two sets of calipers now. First set came out awesome, but they were remanufactured so they were flawless from the get go. Cost was $60 since no sandblasting was needed. Just had him do another set for me which were some pretty dirty calipers I sourced from an east coast car. $80 for powder and sandblast and they ended up out gassing and causing bubbles in the finish. Have taken these to applied plastics in Arvada now and having them redo for a considerable cost that I won't say here since I'm embarrassed I'm paying so much, but in the end I want them done right.
    Veteran Member Three Rings kobrian85's Avatar
    Oct 23 2012
    Quote Originally Posted by jjvwg View Post
    Do you feel you're paying so much for the re-do at Applied Plastics because of the amount of work to repair Colorado Power Coating's crappy work, or is Applied Plastics more expensive all together?
    2019 RS5 \ Sonoma Green
    IG: kobrian85
    Jan 01 2012
    2004 A4 Avant
    CO
    I'm paying a little more to have them strip the old coating off but even if I was starting fresh with them the price is way higher. They called yesterday and said my calipers are finished, so hopefully I'll be let out of work a little early for the holidays on Friday and can swing by to grab them.
    Mar 30 2015
    Denver
    Thanks for the insight, guys. I'll give Berg a call and see what they say. They're already my go-to shop, so I probably should have known to start there.
    jjvwg, please let us know how the redo by Applied Plastics turned out when you get them.
    Jan 01 2012
    2004 A4 Avant
    CO
    unfortunately the job done by applied plastics wasn't quite up to par with what i was expecting, especially for the price i paid. to top it off, the owner turned into a total asshole when i confronted him about the issues. apparently he didnt want to hear that the job wasnt done properly. He definitely took a very unfriendly tone with me and started running his mouth trying to back track everything and say that i was being unreasonable, and that if he had known the sort of finish i was looking for that he would have either never done business with me in the first place or charged me $1000 dollars. apparently doing quality work is not a priority to them. To top it off, he tried to put the damage they caused on colorado powder coating and kept saying that i signed a paper when i brought them in noting the damage, which is untrue. I signed verifying that the last place had sandblasted them and when we talked upon dropping them off it was also spoken while he was writing that comment that they had gotten some overspray into the piston cups. nothing stated that there was damage where the dust boots press in. this leads me to my next topic of concern. when i dropped them off i made them aware of the slight overspray in the piston cups and asked if they could remove that. he responded saying that they would strip the calipers of the powder coat with a solvent and could take care of it. well when i got them back, the overspray was still in there, and he made mention that they "mechanically" stripped them, which is probably how the edges of the lip where the dust boots press in got damaged. it appears that they used some sort of blade/scraper to get the old powder off. its not too bad and i dont think it will cause issues (can probably clean up the small spots with some emery cloth) but that is probably the most critical area of the calipers as far as function goes. one would think they would have taken more caution. Moving on to my next concern, when i dropped them off initially, i showed him how the last place had gotten powder into the area where the dust boots seal and said i would like them to mask off the whole face where the pistons are on a line in the casting. apparently this was forgotten and they painted in there again...but he didnt want to here that. he said that i didnt tell them everything that needed to be taken care of to do them. Mind you the whole time we were dealing with these issues he was telling me that they do a bunch of "high end" car parts and he had even showed me another set of calipers he had done when i dropped them off. if you do "high end" car parts and have done plenty of brake calipers before, one would think they would know the basics of a brake caliper and what parts shouldnt get paint. not only did they get paint in there, they painted the threads where they mount to the upright and also in the holes where the slide pins go. and the icing on the cake was one of the calipers had some black overspray on it. he had his guy take that one into the back quick to do some touch up with a brush and some paint and the guy didnt even do the right spot. i didnt even say anything at that point because i was so sick of this guy being down my throat and barely letting me get a word in. in the end he had two ways of dealing with the matter, either i pay and take them or i leave them with him and he strips them and does a half ass powder coat job on them and gives them back to me the way i brought them in. i was so done at that point that i just paid and took them as i had no faith in leaving them with them and didnt want to have these redone again. in the end i would never go back to them and i would highly recommend others take there business elsewhere.
    in all honesty, the job by colorado powder coaters was pretty good minus the bubbles from the outgassing and the overspray in the piston cups. when i had them do my 17z's they masked off a large area on the piston face and got no powder anywhere near the cups or where the dustboots press in. i think maybe the guy wo painted these last calipers for me wasnt part of the A-team. the one good bit of info i got from applied plastics was that they do indeed have powder primer which should stop outgassing on the final coat. if i get another pair of calipers done again i will go back to mark at colorado powder coating and discuss having primer laid first for an extra charge. he did great on my 17z's and ive seen a bunch of other stuff in his shop that had a quality finish. i dont blame them for the outgassing as that was out of there hands. i should mention that i had applied plastics do a ceramic coating vs powder coating as it withstands heat better and especially with going white i didnt want to risk the powder yellowing. plus ceramic coating gets baked at a way lower temperature which also alleviates the potential for outgassing. downside is that its a thinner coating so you see more of the casting imperfections. I ultimately chose to go that route to avoid outgassing issues, but the price would have been the same to do powder plus a primer.
    applied plastics issues:
    painted threads
    painted slide pin holes
    overpsray
    paint in dust seal groove
    damage on dust seal lips (that is not paint, those are slight gouges in the metal)
    just as a proof that colorado powder coaters do a great job, even though my experience with this last set wasnt great ($60 powder job FYI, and you can see how much they masked off around the piston cups here)
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Jan 01 2012
    2004 A4 Avant
    CO
    i dont know, maybe im being "unreasonable" and knitpicking every little detail as the store owner accused me of doing but i feel these were all things that i had a right to be dissapointed in, especially for the cost of the job. let me know if you guys disagree.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Nah I agree, even if you don't see it the way of the customer, you should be polite and try to help get the results they want, not turn them away telling them that they have unreal expectations of the quality of work that a cheaper shop did.
    Sorry to hear about your experience with them, but it definitely helps us make sure never to go there
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    I have used quite a few shops and so far the best I have been to has been Pristine Powder coating. I have had him do multiple jeep parts and car parts over the last 8years. I can tell you that they have always held up with no flaws and he is priced very well.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Jan 01 2012
    2004 A4 Avant
    CO
    thanks for the recommendation seth, maybe id check them out for my next PC needs. all said and done i think these will look pretty good on the car, just need to clean up those problem areas shown above.
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    I'm sorry.. You paid $1k to have your calipers PC'd? I'd go fucking NUCLEAR if it wasn't absolutely perfect..
    That's 10x what it should cost.
    '18 S5 - BBS / EPL
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by JD S4 View Post
    absolutely not, there is no way in hell id pay that to coat them when you can buy brand new oem calipers for less than that. thats what the guy at applied plastics said he would have charged me if he would have known how picky i was going to be about his quality.
