Now to get into what you'll need:
-Rally Armor Universal mud flaps (Amazon ~$25)
-1/8" and 1/4" drill bits
-T25 Torx bit
-5mm Allen wrench
-Cardboard/foam board
-Sharpie
-M8x40 vw/audi self tapping screw OR #10-24 x 1" sheet metal screws at Home Depot (4)
-(with Home Depot screws) #10 washers (4)
-Trace the mud flaps on the cardboard.
-Cut.
-Now position it to your liking. Be sure to keep the cardboard steady for the next part.
-Without bending the cardboard up too much get the screws/clips to leave indents on the cardboard. These will your drilling points. (Front uses the larger drill bit)
-Do not move the cardboard yet. Trace where the fender and mud flaps meet. This will make aligning the other side of vehicle virtually unnecessary but I like to measure twice.
-Once you have those indents (7 total) you are set to drill. Be sure to note which holes belong to the rear (2 1/8" holes) and for the front (5 1/4")
-It helps to drill the rears simultaneously then do the fronts as well. uniform is key.
-Installing is straightforward but there are things to note. The clips in the front holding the fender liner can be removed by poking a 5mm through the center. Be sure to find the small piece of plastic that falls out. You will need those to tighten the clips. And for the rear the longer screws are needed.
Feel free to ask about measurements or clarifications, I probably missed something :p
Post your pics when you do this mod !
