Results 1 to 36 of 36
    Jan 26 2015
    Clemmons
    ECS Slotted rotors vs StopTech
    So I order and already have the ECS Slotted Rotors front and back, they are planned to put on in a few weeks.
    I have two concerns, how do these stack up against the StopTech version? Also the ECS are pretty silver looking. I ordered and installed some new Harman wheels which are dark gray and I can see the rotors clear through now and I am concerned the brighter silver might look weird against the gray wheels.
    Nov 28 2015
    Montreal, QC
    with all due respect to ECS, they are a reseller.. not a brake manufacturer.. I don't know why ppl can believe a reseller can stack against a real legit brake manufacturer !
    S4 B8.5 no track, just enjoying spirited driving.
    Apr 05 2016
    Portland, OR
    I highly doubt ECS actually makes them.
    Rotors should look great behind your wheels
    Geoff
    Jan 26 2015
    Clemmons
    Quote Originally Posted by whiped View Post
    I am sure this is the case, but I could not find any other way to reference them by.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Elderan View Post
    That was for Waxxon
    FWIW, the people I have seen with ECS rotors seem happy with them.
    Geoff
    Nov 28 2015
    Montreal, QC
    That was for Waxxon
    totally agree ! I'M sure they don't, but I bet it doesn't come from stoptech/brembo factory either lol.. let say it comes from zimmerman factory.. might as well stick with zimmerman for cheaper then isn't ?
    Nov 28 2015
    Montreal, QC
    One of my favorite brand is DBA or Brembo. Unfortanely, DBA don't make any rotor for our application but brembo JUST came out with a rotor option for the 345mm option which I should be ordering in th enext few months when mine is due (unless something else came out like 2piece brembo or dba application)
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by waxxonMTL View Post
    because racecar
    ECS branding has to be good for at least 5 HP.
    Geoff
    Apr 14 2016
    2014 Cayman S, 2004 A4, 2005 4Runner
    Eastern PA
    I've had slotted ECS rotors for 6 months. They perform well on my dd, but one thing that bugs me is that their internal vanes lean differently for each side.
    Yes, the slots are directional, but the internal cooling vanes are slanted in the same direction for both left and right sides. So once installed, one side's vanes lean one way (forward, for example), and the other side's the other (backward).
    Minor annoyance, but it bugs me. Why bother slanting the vanes if you're not going to do it correctly? (Cost savings, is the answer)
    Jan 26 2015
    Clemmons
    Thanks for the comments, just wanted to make sure before I went ahead with the install.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by S4Flyer View Post
    Cost savings is right. I can't fault ECS (and their manufacturer) too much though, because Audi OEM does the same thing. Even on the $160k R8 V10, the same rotor is used on both sides, meaning one side is not getting full cooling...
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jul 26 2014
    Yeah, the funny thing is they weren't like that in c5 rs6 times. It had different left / right rotors, which by the way are interchangeable with the newer non-directional rotors...
    2011 S5 Sportback
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    i have ecs drilled/slotted on my fronts, and stoptech cross drilled on the rears. because racecar
    more importantly akebonos all around!
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Oct 06 2014
    Cleveland, OH
    Two sets of ECS rotors on two different Audi's, A4-slotted, S5-slotted & drilled. Both cars saw 3 days of road course racing, no issues at all.
    New brakes this Fall, Stoptech ST60 and trying out Adams rotors for the rear. You should be fine with the ECS.
    Oct 02 2006
    Wadsworth,OH
    Every single aftermarket OE replacement rotor is manufactured the same way. The only brand I know of that redesigns the internal vanes is StopTech and they are just straight vaned.
    Though our 2-piece rotors are directionally slotted and internally vaned!
    Jason
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Quote Originally Posted by LINDW4LL View Post
    That's not what it means. Which direction the slant of the slot is in has little to no affect on the cooling potential. The only thing that matters is the direction of the directional vanes, which you'd want pointing toward the rear of the car.
    Are you saying that the rotors you use have directional vanes that are both pointing the same direction? It probably won't ever really make a difference, but they should either be created with no slant in the vanes, or each side should be made differently.
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    Quote Originally Posted by hotleadsingergu View Post
    Yes, all the Audis, even the RS cars, use the same rotor left and right, including the vane direction. So yes, one rotor does get less cooling than the other. Most of the time no issue, but a little disappointing that its a half assed job by Audi, even on the high end S and especially the RS cars.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by Race Shooter View Post
    The OEM rotors on RS4's are internally vaned, but they're straight vanes, so they're not directional.
    2017 Camaro SS 1LE
    Dec 10 2011
    CLT | MKE
    Please read next time. I never said anything about slots- only the internal vanes. One side does in fact receive worse cooling.
    Obviously Audi SHOULD make them that way, but they do not.
    RS5/R8 rotors
    -Hayden
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    oops
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Nov 28 2015
    Montreal, QC
    also, as i said earlier, brembo xtra was released in europe.. these might be directional too since they are a performance rotor.
    Oct 08 2012
    Jason
    GYRO DISK are directional internally, to pump more air. I have no association with them other than happy customer. http://www.girodisc.com/Technical-Info_ep_45.html
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    those may be, but i can confirm the ones we talked about a few weeks ago are not directionally vaned.
    I bought the Brembo OEM Replacement blanks from Amazon. Prime has them super cheap.
    Front:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Rear:
    I don't see the logic buying a slotted or drilled rotor unless you upgrade to a BBK. For the price these brembo blanks cannot be beat.
    $303 shipped to your door for all 4 rotors? The rotors i received are made in italy too. These with Akebono's from amazon made for an extremely cheap while maintaining high quality 4 wheel brake job.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by jlaudio View Post
    Front:
    Rear:
    it's different. new release from 3rd quarter of 2016 .. not sure if I will go with or without drill. I usually prefer blank or slotted, but I like to believe brembo did their class and when they say the drilled one offer better performance than the blank one than it really does lol
    https://www.bremboparts.com/europe/e...vt-ventilation
    https://www.bremboparts.com/europe/e...isc/09-B039-1X
    Senior Member Three Rings Symko's Avatar
    Jun 10 2011
    ‘12 Glacier S4 ‘19 SQ5 (wife’s)
    Reston, VA
    Front:
    Rear:
    ^^^with improved braking over Stock or about the same?
    Mar 26 2009
    SLC, UT
    you can get fronts for about $315 USD shipped on ebay it looks like
    honestly i think its only worth it if you track or really hoon the car daily. i can get all 4 of the regular rotors for the same prices as the 2x fronts. they look nice though, and the only correct directional vaning unless going 2 pc rotors.
    http://www.ebay.co.uk/itm/2-x-BREMBO...-/302110850566
    '21 SQ5
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by Symko View Post
    the akebono euro ceramics are a massive learning curve coming from stock/oem pads
    instead of the instant on/off initial grab of the oem i have a nice progressive pedal feel, which i tend to prefer
    upgraded performance? not sure. about 1/3 of the cost of OEM parts while having zero brake dust and italian forged rotors? you betcha.
    i daily drive my car and canyon run on the weekends. so far they have worked perfectly for my needs.
    '21 SQ5
    Jun 18 2009
    Phoenix, AZ
    RS5/R8 rotors
    That's the rear rotors, which are directional. The fronts are not.
    2017 Camaro SS 1LE
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by FWP! View Post
    No, these are fronts.
    You're right that the B7 RS had straight vaned, however the new cars do not. Mk2 TTRS, RS5 (normal and wave), R8, B8 RS4 etc are all like this.
    -Hayden
    Junior Member One Ring
    Mar 28 2014
    St Catharines, ON, Canada
    Hello everyone, Quick question. I have a 2015 B8 Q5 TDI with 330mm rear rotors. Stop tech makes a set ‎127.33137L which indicates Left. Does anyone know if Left and right are the same? From what I remember from the past, having bought Zimmermann, they were both the same. Any thoughts? Thank you
    Sep 16 2020
    West Michigan
    Quote Originally Posted by fstrdr View Post
    It is possible that the internal cooling vanes are directional. Which would make them side specific.
    My lady's factory BMW front disc's are this way.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Senior Member Four Rings
    Jun 08 2021
    PA
    I don’t think it matters what direction the vanes go. On way will pull air from the inside out. The other from outside in. Just like if you reverse a fan. It still moves the same air just in a different direction.
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    ECS SUCKS. They use to be great years ago but all they care about now is profit margins. I would never buy one of their parts they manufacture ever again. Its cheap China BS.
    Their customer service is horrid.
    I have the painted and coated Zimmerman rotors on my car and they are fantastic. You don't need slotted or vented rotors unless you are tracking the car.
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    ECS is by far the worst VAG parts company around.
    Service has dropped off.
    Parts are overpriced.
    In house parts are of ebay quality.
    I don't even consider them anymore. Pure garbage.
    There are many others out there nowadays.
    DAP
    FCP Euro
    Rockauto
    German parts - Canada
    German OEM - Canada
    Sep 16 2020
    West Michigan
    Quote Originally Posted by Nillious View Post
    This is incorrect.
    The air is meant to go from the inside of the hat to the outer edge of the disc.
    Look at F1 brake duct for examples.
    Apr 04 2012
    MSP
    Quote Originally Posted by f1torrents View Post
    DAP
    FCP Euro
    Rockauto
    German OEM - Canada
    I agree.
    I finally got all their brake components off my car.
