Results 1 to 17 of 17
    Senior Member Two Rings jwallace0988's Avatar
    May 16 2016
    None
    Rochester, NY
    Help with spark plug install!
    So first time I am changing plugs in my S4 - not the first time I have done plugs before. As I pulled out the first coil, there was a rubber thin o-ring about the size of the coil wall. It was basically ruined. My question is - is it normal these come out? When I got to the second spark plug and pulled the coil - this one was half way ripped out where the other came completely put. Pics below for reference. I don't see any feasible way to get this rubber Oring back in as they look warm out and will not fit back into the groove they were in.
    13' S4 - Ice Silver (DSG, B&O, Carbon Inlays, Black/Magma Leather, Sports Diff) - EPL Stg. 1 ECU w/ DSG tune, Roc Euro Intake, DeAutoKey Full LED interior(white), Red (Front floor), LED Exterior lighting (Turn/Reverse). Eurocode poly mounts, Soundakor DELETE!, Xpipe mod, Carista!
    Past: 12' GTI Autobahn, APR Stage 1, CM FX350 w/ flywheel, Magnaflow CB exhaust :: 06' Scion tC: Full Bolt-ons to turbo build at approx. 300 WHP/TQ on 8-10 psi, Konig After-burners, RL Coils, poly mounts etc.
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    Looks like part of the valve cover gasket. Sorry broseph, appears to be that you're gonna be pulling them valve covers.
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Jun 28 2016
    US
    That's either a pinched gasket seal for the spark plug holes or Audi uses a gasket sealer instead for that and that's what you see. If it's a sealer, it may not be a big deal since that's just excess that squeezed after the valve cover got screwed down, but since I've not seen this on mine, I wanna say it was a pinched seal for that cylinder. If you don't replace it properly by taking the cover off and replacing all the seals, you could have an oil leak that goes into that spark plug channel and eventually will cause issues with the coil in it. (It won't leak past the spark plug and into the combustion chamber, so you don't have to worry about that, but it will probably kill the coil over time and maybe even overflow and drip out of the top hole past the coil seal, but that seal is pretty tight itself. Anyway, I'd do the job right and correct it.)
    May 16 2016
    None
    Rochester, NY
    So just an update I just finished all 6 - I now confirm it seems like more of the black gasket you apply on an oil pan which I believe seeped through - it was like this on both sides of the plugs. There was a small amount of oil residue on the middle drivers side coil pack. I know it shouldn't be there - however it didn't seem excessive by any means (it was only on a spot half way up the coil. Idk not happy seeing this black gasket - anyone else have experience removing the head and what that process looks like for gasket seal- is it the tube that can smush or is it a rubber actual gasket.
    Veteran Member Three Rings Krusty's Avatar
    Sep 18 2012
    long beach
    Just did my plug and sparks and never saw a thing similar to this, I would get to the bottom of this mystery if I were you.
    2011 sprint blue s4, EC subframe stabilizer, ECS short shifter, Euro Impulse weighted shift knob, custom air intake, RS grille, CR-15, 034 rear diff mounts/rear diff carrier mount inserts, Apikol rear diff mount insert, 10mm(f)/12mm(r), ECS strut tower brace, ECS front adjustable end links.
    Feb 20 2004
    I'm telling you, it's a valve cover gasket or something used to install a gasket. But, maybe not as bad as you'd think.
    Obviously, the OPs car has had valve cover gaskets replaced at some point. As you can see in the image above, the gaskets are rubber, and not a liquid gasket.
    Not to worry.
    Many shops will use a dab or two of silicon/gasket maker on the spark plug holes to hold the gasket in place as they flip the cover upside down and onto the top of the cylinder head.
    I would say pull one gasket cover (passenger is easier due to the crap placement of the coolant overflow), inspect the gasket and see what it looks like. If the gasket looks okay, re-install the cover and move on. Should only be a few bolts...10/13mm if it's similar to basically any other valve cover in history. When you reinstall the cover, be sure to torque in a start pattern to minimize the risk of leaks.
    -DL
    Previously:
    May 16 2016
    None
    Rochester, NY
    Quote Originally Posted by Lensch09 View Post
    Not to worry.
    I would say pull one gasket cover (passenger is easier), inspect the gasket and see what it looks like. If the gasket looks okay, re-install the cover and move on. Should only be a few bolts...10/13mm if it's similar to basically any other valve cover in history.
    -DL
    Thanks for the quality response Lensch! Much appreciated. I may just end up calling the dealer - I do have the extended powertrain warranty and I feel like that sort of work should be covered, especially if this is not the norm. and especially if the car has had this work done prior to me purchasing it! I'll post back when I have more info so we can all learn together for future people. Bummer! But this is absolutely the reason why I enjoy doing work myself, I'm sure a dealer would have done the plugs and been like f*** it!
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    It's clearly excess RTV. I wouldn't worry about it at all unless you develop a measurable oil leak.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jun 28 2016
    US
    Quote Originally Posted by Vogz View Post
    This is what I was thinking also because of the way it looks.
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Quote Originally Posted by jwallace0988 View Post
    Just below the oil filler cap then ;)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    So ran into the exact same issue today as I swapped out my plug's for the first time. Oil in the same spot, middle cylinder on drivers side (bank 2 cylinder 5 I believe) and pieces of black gasket overflow coming out of most the cylinders. Question, how big of a concern is the oil leak in the cylinder? There wasn't very much, kind of hoping to ride it out for a little while until I have more free time to tackle the valve job.
    Sent from my SM-G955U using Tapatalk
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    Same thing happened to me yesterday same spot. Hardly any oil but the gasket or rtv was slightly ripped. Didn't mess with it cleaned the oil which was enough to turn a paper towel in one sport slightly brown. Installed everything and kept trucking. I wouldn't worry about it it's not going to leak bad it at all. If your worried use some rtv and slap some in there.
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Quote Originally Posted by evil35r View Post
    Yeah that was the plan and thank you puts my mind at rest to hear others with the same outcome. Weird though that there's a leak in the same spot on several different cars, leave it to Audi to be consistent lmao
    Mar 22 2016
    73 Jimmy 496 BBC
    Yea haha. When I pulled out the coil I was like wtf. But after reading a lot r8's have had the same issue and if those guys are ok I'm ok lol.
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    I have an oil leak in the same spot. I made a thread asking about it a while ago. I ended up buying two valve cover gaskets off RockAuto for like $9 for the future.
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Quote Originally Posted by ShelbyM3 View Post
    Crazy... wonder just how common this really is
    Jul 21 2004
    South Florida
    Yup, this is exactly the same on my car when I changed mine. I checked the notes and the car had decarbon cleaning about 5k miles before I got it (at 25k miles or so). Its nothing to worry about.
    Mike
    2018 Audi S5
    Gone-
