Results 1 to 11 of 11
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    Automatic gear shift knob stuck
    I see a few threads explaining how to remove the automatic shifter handle, but they all state to pull the knob outwards. My shift knob is stuck inwards, and pulling it out is very difficult. Shall I continue to pry it out, or is there some other method I can try? FWIW, I tried tapping with a rubber mallet, but the knob still won't pop out.
    With this stuck, I can't get the ignition key out.
    Thanks.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    It pulls directly out. If you can get the shifter handle off you can use a compressed air tank to blow in the bottom and push the button out.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    May 31 2008
    Palm Beach, FL
    Quote Originally Posted by evo_ski View Post
    ... If you can get the shifter handle off ...
    This is the problem... with the button pushed in, I can't get the handle off. With a couple smalls screwdrivers I can pry it out a bit, but there seems to be some significant spring action sucking it inwards. Hoping someone knows a way that perhaps I can get in from the around the side of the shifter to push the internal up-down plunger up.
    Audios,
    -Neil.
    Jun 29 2014
    Dopest foot mobile you ever did saw!!!!
    United States
    The write up I used had a ziptie around the button when you pull it out.
    03 Avant 3.slow, H&R sways, custom 2.5" exhaust, RNS-e, Airlift with v2, Rotiform ccv 19x10 square set up, Recaros and S4 paddle shift wheel cause I'm old and my knees hurt :)
    Mar 15 2010
    Bothell
    It definitely has a good amount of pressure side to side. So you will have to pull or pry it quite hard. That said, that is the only way it comes out.
    May 31 2008
    Palm Beach, FL
    I went into the scrap yard and was able to pull off two of these so I know the process now... but mine won't come off! If the scrap yard ones were the same tan color as mine, I'd just cut mine off. I need to find some other way.
    Audios,
    -Neil.
    Nov 29 2016
    2007 Suzuki GS500F
    Connecticut
    Are you saying the knob is off but the button to shift is stuck in? That happened to me and I just put a piece of duct tape on it and pulled
    May 31 2008
    Palm Beach, FL
    The knob is deep in (where it would be when pressed in to shift). I can pull it out quite a bit, but I feel like the ones in the scrap yard came out a bit more (where I could see the white parts inside the handle) and as much as I got it out, I could not get the handle off.
    Audios,
    -Neil.
    Nov 29 2016
    2007 Suzuki GS500F
    Connecticut
    There's a spring under there so it may just be under tension. I'm saying to try putting a flap of tape on it then pull the whole thing out. Once it's pulled out enough grab a hold of the button or slide a screwdriver underneath to prevent it from being pushed in again.
    May 31 2008
    Palm Beach, FL
    Quote Originally Posted by yoitschavez View Post
    Yep... been doing that. I was holding it out with a couple screwdrivers stuck in opposite sides.
    Audios,
    -Neil.
    Nov 29 2016
    2007 Suzuki GS500F
    Connecticut
    What did I miss then...what's the problem you're trying to solve? :O
