Results 1 to 40 of 55
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    What is a normal 0-60 time on a Dual Pulley s4?
    I recently test my 179/57mm EPL dual pulley s5 started on the fwy shoulder from a dead stop to 60.
    I measured 0-60 through Torque pro+crista adaptor to be 4.2 sec.
    Was it normal?
    LC was used, and traction on the 1st gear WAS an issue but the result is still too slow to my expectation.
    I couldn't find a similar setup s4's 0-60 time so I have to ask.
    Any replies will be appreciated. Thanks in advance!
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    I could run mid to high 3s Stage 2 E85. Haven't tested dual pulley yet.
    LC used - first issue. Upswing method is the fastest.
    Traction issue in 1st gear: kind of hard for us to say if this is slow or not when we don't know how long you didn't have traction.
    Also not familiar with Torque pro/crista and if that's a suitable method compared to vbox.
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by yjypm View Post
    Was it normal?
    I got a 4.3 with my stage 2, still feeling slow
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    I've done 4 seconds flat (according to my P3 gauge) on stage 2 GIAC. And that was with a bit of wheel spin.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Jun 12 2015
    CA
    3.71 with my VBox Sport at an NHRA 1/4 strip. But I drive a Q5, so I'm 500 lbs heavier.
    2015 Q5 3.0T | EPL E85 | APR SC pulley | KI 194mm crank pulley | CTS Turbo intake | AMS Alpha cooler | EC headers | Milltek valvesonic exhaust | KW V3 coilovers | 034 X-brace | 034 Trans mounts | 034 Rear sway bar | 034 ACAs | Girodisc LW front rotors | JHM LW back rotors | HRE P104 21x9.5 | Michelin PSS 285/35/21 | Autotech HPFP
    11.788 @ 115.64mph [ KI 194 / APR 57.73 | 104 | -350 ft. D/A ]
    11.950 @ 113.61mph [ KI 194 / APR 57.73 | E85/91 | +300 ft. D/A ]
    0-60 in 3.71
    Veteran Member Four Rings adamkb26's Avatar
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    The S4 has been reviewed and tested as low as 4.5 stock. I've seen pics of people getting 3.7 to 3.8 on stage 2 so you should be able to get mid 3s in ideal conditions. Testing it on a regular local road probably won't get the best times.
    2018 Mythos Black TT RS
    034 Stage 2 ECU/TCU | IE Carbon Intake/Inlet | AWE Switchpatch | Forge Motorsport FMIC | 034 Parts: HFC DP, Dogbone Mount/Inserts, RSB/End Links, Subframe Inserts, DSG Catch Can | Euro OLEDs | AP Carbon Wing/L Blades | HRE FF11
    2018 RS3 | 2018 S5 | 2017 TTS | 2015 RS5 | 2013 S4
    Aug 01 2013
    Washington DC area
    JHM/APR dual pulley. I got 3.2 and 3.3 with my Vbox at MIR just this past Saturday and 0-100 was 8.2 and 8.3. They are pretty much what I got a couple of weeks ago on a relatively flat "private road" in slightly colder temperature.
    Veteran Member Three Rings ajm0903's Avatar
    Mar 28 2010
    Westchester NY
    I've done 3.4 with my EPL dual pulley in relatively warm/humid weather on a summer night.
    2016 S4, Mythos Black, DSG, Black Optics, Tech Package, B&O, Sports Diff | Some mods...
    Nov 28 2015
    Montreal, QC
    Since stg 2 usually average 4 sec and best result are around 3.8
    I would HOPE the dual pulley tune to do approx. 3.5 The best i've seen is 3.2 if I'm not mistaken.
    Obviously, theirs a difference between 179mm and 194mm ( about 30whp), and theres a difference between 93 vs E85 (another 30ish whp).
    And then theres different TCU tunes and finally theres tire traction ( when we're talking about 3.2-3.5, a little traction issue can easily loose a few tenth)
    but surely 4.2 is a deception !
    S4 B8.5 no track, just enjoying spirited driving.
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    3.6/3.7 revo stage 1+
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Oct 08 2015
    Thanks for everyone's reply. Just wondering, what tire sizes are you guys running? I am running with 255/30/r20.
    Current: '18 M3 ZCP
    Feb 05 2016
    UK
    245/40/18 around 21lbs (9inch wide)
    20's may well slow your acceleration a touch
    Apr 05 2016
    Portland, OR
    2 Pulls at stage 2.
    You can see the time from the P3 on the windshield.
    Geoff
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Can someone explain what the upswing method is?
    Apr 05 2016
    Portland, OR
    It's like launching but release the brake a bit early.
    Here is primetime doing it, watch the needle and listen for it.
    I wasn't doing it in the above video as I was losing traction even launching normally.
    Geoff
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    I don't think anyone would believe mine or primetime's 0-60 times
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by Loe View Post
    LOL. I think most of us believe every damn word you say. Pretty much anything dual pulley is WWLD.
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    What is your 0-60?
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Jan 05 2017
    Long Island NY
    Quote Originally Posted by whiped View Post
    2 Pulls at stage 2.
    Confident on the P3's accuracy? I have one too and got a 3.90 many times on my DSG equipped Stage 1- literally that exact time and on several roads. I had a separate thread on it a while ago. I wanted to make sure launch control wasn't making the gauge do something funky since getting 3.90 a lot of times seemed too consistent so I did one uphill and one downhill and thankfully the times did change accordingly
    My question more is, has anyone compared P3 to the more traditional methods of recording 0-60? I'm hyped if a car that I paid 36k for used can keep up with sub 4 second cars to 60 that cost much more money, but it just seems like such a fast speed for a car under 500hp that is still fairly heavy. Not complaining though
    Nov 28 2015
    Montreal, QC
    ^^ Best way is to race against GTR lol we all know they are under 4second. So it gives you a good idea.
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by waxxonMTL View Post
    My buddy has a 2009. Hmm.
    Apr 04 2015
    United States
    GIAC Stage 2 with DSG Tune: 3.65 best with LC used, cool summer night (70's). I have seen as low as 3.5 posted for stage 2 only.
    Nov 28 2015
    Montreal, QC
    I still think 3.5 is pretty darmn low for just a stage 2 and I'm a bit doubtful, but then again, its hard for our brain to catch the difference between 3.5 of 4sec lol. we're talking half of a second there..
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    A half a second 500 ms is to slow for voice over IP lol
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    3.21 for me with a 179mm 93/E85 mix. 60ft at the track was a 1.62.
    I would put Loe at about 2.7x - 2.9x.
    Jan 19 2016
    Harrisburg, Pa
    Quote Originally Posted by KnewJack View Post
    Sub 3's...holy crap!
    Sent from my SM-G900V using Audizine mobile app
    Aug 09 2015
    Sarasota, FL
    Great guess! 2.75 is my best to date. 1.58x 60ft times puts you in some serious company in terms of 0-45mph acceleration, i can be side to side with a tuned 911 Turbo S (991 body) through the first 60ft, but its downhill from there lol. Our cars can be serious off the line, even considering it being AWD on street tires, when launched correctly, I usually get people with higher powered rwd cars with DR/Slicks come up to me a bit surprised and asking what tires I run.
    My car upshifts the 1-2 at about 1.6 seconds, and the 2-3 upshift at about 2.9 seconds.
    Jan 19 2016
    Harrisburg, Pa
    Audi got the gearing right for getting up to highway speed for sure. Sub 4s with a tune in a 4,000 lb car that gets almost 30 mpg...pretty awesome.
    Apr 29 2013
    Detroit, MI
    Quote Originally Posted by 13jfp View Post
    30 mpg?!? I'm lucky if I get 20...
    2018 S4 8AT
    2012 S4 6MT
    2006 S4 6MT
    2000 S4 6MT
    Jan 19 2016
    Harrisburg, Pa
    Wow. I'm only 1+ but still get 28 hwy...23 overall
    Oct 08 2015
    2.75... that's crazy
    Current: '18 M3 ZCP
    Veteran Member Four Rings A5MD's Avatar
    May 21 2009
    2009 Acura MDX Tech, 2015 X5, 2014 Police Interceptor, 2018 Civic Sport Hatchback
    MD
    Agree...ridiculous
    Oct 08 2015
    Quote Originally Posted by A5MD View Post
    Agree...ridiculous
    I could imagine he parked next to a Ferrari F12 at red light and destroyed that beast.
    Current: '18 M3 ZCP
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Whoa Loe. Nice!
    And audi says the new s4 doesn't have a dsg because of the power. Liars!
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Jan 19 2016
    Harrisburg, Pa
    So I wonder what the real reason is? Anybody know? Saving DSG for the RS models?
    Mar 07 2015
    2003 SL55 AMG, Audi Q7
    San Francisco, CA
    2011 S4 here.
    EPL Stage 2, 91 octane, EPL DSG tune, light weight crank pulley (stock size), 20lbs 19" wheels, stock size tires....
    I did multiple times 3.8-3.85sec, without using LC.
    Just a bit better with LC. ... 3.75-3.8
    Oct 08 2015
    I believe it's more for cost and reliability concerns.
    Current: '18 M3 ZCP
    Apr 28 2016
    Yes. The ZF transmission is more stout and will hold more torque. I believe that is why it is not offered in the RS7 and the power potential of the S6 is somewhat limited by tuners (once you step up to the RS turbos) due to torque limitations of the DSG.
    I think the power potential of the B9 will far exceed the B8 with its twin turbo layout so the ZF should prove to be a wise choice, though I personally prefer the DSG.
    Senior Member Two Rings extratime's Avatar
    May 22 2016
    Portland, Oregon, U.S.
    Was it normal?
    This doesn't seem right. I just did 3.96 on my way to work with no L.C. and very little heart into it. I'm straight up stage 2 with stock dsg tune.
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    I feel like there should be a value for vehicle speed or something like that in VCDS for logging...
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
