Originally Posted by
fshkllrz
appreciate your comments. My thoughts were to use it this winter...in California....then in the Spring, attempt correcting the paint, wet sand and polish then use one of those 12 month + coatings. I don't have scratches as much as I have orange peel. May just hand that job to the pros
My advice is
not to wet sand. This is a daily driver not a traveling show-car. Unless your car is different for some reason, the only area of orange peel on mine is the rear deck-lid where the license plate is at. Even what little you "might" have on the sides is negligible and not worth trying to remove. I've been doing this for a long while and will tell you that wet sanding away good clear coat for the sake of orange peel isn't something most will recommend. It's not worth it. Clear coat is like tooth enamel in that once it's gone it's gone. Looking at your car, all you need is a good finish polish and refinement and then a coating. From there, regular maint. is all that's required.
When you remove factory clear coat on a daily driver, you're going to severely limit the future ability to correct imperfections that pop up. One good bird turd can/will likely compromise a sanded clear and after that's it's over. Get a good thickness meter and realize that the clear coat isn't but maybe a third of what you're going to measure.
Here's a refined finish with coating. My insight here would be to use a white pad, Essence as your base polish/prep for the coating and then have at it.
Hood:
Reflection off my roof:
Another example and this one isn't even coated, is a
21yr old absolutely hammered AMG 36 Before and After: No sanding, just compound with MF Pad and a basic polish.
