Results 1 to 19 of 19
    Veteran Member Three Rings DavidD's Avatar
    Jul 02 2008
    2010 Sprint Blue S4
    Northern Va
    Battery coding??
    Tried searching the forum but can't find anything on this.
    My 2010 S4 with 42k miles is in for service. They tell me my battery is only holding a 56% charge and should change the battery. Cost was close to $500 for the battery and coding/associating the new battery. They said I can't just drop a new one in there bc the car won't know it has a new battery....
    Any help is appreciated.
    Thanks
    Dave
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    I just purchased the OE battery and coded myself. Here's a decent tutorial from RossTech that shows the process. Don't spend that much for the dealer to do it.
    https://www.youtube.com/watch?v=IJAScg6JrYI
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    i got a battery from advance auto parts, its an OEM battery with the audi rings on it and all. same brand. has the BEM code on it to code it.
    i swapped mine on my 2010 and it did not need coding.
    battery was $123 after all of the discounts.
    http://www.audizine.com/forum/showth...hlight=battery
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jul 02 2008
    2010 Sprint Blue S4
    Northern Va
    Thanks guys, after more searching I also found this thread with more info:
    http://www.audizine.com/forum/showth...-battery-S4-B8
    - - - Updated - - -
    Jlaudio - why do you say yours didn't need coding?
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by DavidD View Post
    - - - Updated - - -
    because the car did not throw any hard or soft codes when i made the swap, so i left the old BEM code in the computer.
    so far i have not seen or heard of any negatives to this.
    '21 SQ5
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    I didnt code mine either, no issues.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    Battery coding??
    The car really need the coding to know the battery you are putting into it and all of its information. You can change them and leave the old coding in place unless it was having a problem then you would need to at least clear any codes. The battery system learns the battery's health as it goes but responds to the coding to know how the battery should be acting.
    To sum it all up. The proper way is to add the new coding and clear out codes. The fast was is to toss in the new one and go, clearing codes if needed. Side note, you can use a non OEM battery from anywhere also.
    Being a Audi, the best way to do things is the right way.
    Jun 05 2013
    Massachusetts
    Quote Originally Posted by infinkc View Post
    I needed to re-code in order to get the battery meter in the mmi display to show 100%. Otherwise it stayed at the 20% mark of the old battery.. Am sure over time the computer would have eventually made the update.
    The battery I used was an exact copy of the OEM, but did not have the BEM code. I just used a BEM code from a battery shown in some of the links above and it worked fine.
    Jul 25 2010
    WI/IL
    Same with my friends S5. Until we recoded it wouldnt show 100% and it was stuck in power management mode.
    Nov 13 2012
    Chicago
    Battery coding??
    Yeah, you need to clear the codes in the power management. If not it will stay like that.
    Veteran Member Four Rings jschrauwen's Avatar
    Aug 08 2013
    08 R8 TT, 08 A5 3.2 QTip, 90 300ZX TT 572whp 590wtq, Ducati TT2
    Frankford, Ontario, Canada
    Quote Originally Posted by jlaudio View Post
    Why did you change the battery in the first place?
    Sent from my SM-N900W8 using Tapatalk
    2008 A5|Ice Silver|3.2 QTip|Premium Pkg|Technology Pkg|B&O & JL10W0-4 sub|15/20mm spacers|HID Fogs|Ext. & Int. LED's|RS5 grill|AWE/K&N Intake|Quad tipped OEM mufflers|CF Mirrors, Spoiler & Diffuser|Facelift Ecode Tail lights|CR-15 Strut Bar|Ecode headlights|Alu Kreuz|ProdigyWerks 6pot 2pc 356mm front 350mm 2pc rear BBK|Eibach springs
    2008 R8|Ice Silver|R-Tronic|Huffman TT Conversion|Focal/Mosconi stereo upgrade|H&R Coilovers|HRE wheels
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Never coded mine.Got new battery at Autozone. But if you go online and order you battery from Advanced Auto,you will get a discount. Then just pick it up at the closest store. Return the old battery for credit
    Aug 08 2013
    Quote Originally Posted by Dr GP View Post
    Regardless of sourcing, all new battery installs require coding. Not an option thing. Many say "no issues without coding" or no problems but those people will usually not get the normal 7+ years use. Some have experienced severe battery malfunction in a very short time after install.
    What confuses me is the resistance and/or vague justification to not wanting to code a new battery.
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by jschrauwen View Post
    ^ This. Just change one digit if you don't have a new BEM code.
    May 31 2014
    Alabama
    Probably because it costs over $500 from the dealer to get a new battery installed and re-coded. Yes, I was quoted this.
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I beg to differ with you. So saying it is required is not really accurate. There are so many of us that never recoded their replacement batteries and I dont remember anyone ever reporting any issues from failing to do so. I dont want to get in a pissing contest with you,but I believe the "smart " electrical system eventually adapts to the uncoded new battery.
    Aug 08 2013
    And the resistance with vague justification continues.
    If battery coding is not necessary why is there a vcds coding procedure in the first place.
    https://youtu.be/cxOK_DczRGg
    Jul 05 2015
    Lower Hudson Valley
    Hmmmm 🤔
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Good point.
    I have no dog in the fight, as I haven't had to change the battery in either of my S4's ( yet ) but.....
    one would think, that it might be important to recode/reset an energy management module ( or whatever it is called ), since it is obviously designed to do so many wacky things, especially when a battery has gone low/bad.
    Maybe coding just speeds up the relearning process? It obviously can't do any harm.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
