Code:
16502 Engine Coolant Temp. Sensor (G62): Signal too High : P0118 - static - No indication on display 17633 Fuel Injector for Cylinder 1 (N30): Short to Ground : P1225 - static - No indication on display 17635 Fuel Injector for Cylinder 3 (N32): Short to Ground : P1227 - static - No indication on display 17636 Fuel Injector for Cylinder 4 (N33): Short to Ground : P1228 - static - No indication on display 17634 Fuel Injector for Cylinder 2 (N31): Short to Ground : P1226 - static - No indication on display 17833 EVAP Purge Valve (N80): Short to Ground : P1425 - static - No indication on display 17955 Boost Pressure Regulation Valve (N75): Short to Ground : P1547 - static - No indication on display 17525 Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground : P1117 - static - No indication on display 17843 Secondary Air Pump Relay (J299): Short to Ground : P1435 - static - No indication on display 17938 Camshshaft Timing Adjustment: Short to Ground : P1530 - static - No indication on display 17829 Secondary Air Injection Solenoid Valve (N112): Short to Ground : P1421 - static - No indication on display 17697 Boost Pressure Control Valve (N249): Short to Ground : P1289 - static - No indication on display 17909 Fuel Pump Relay (J17): Short to Ground : P1501 - static - No indication on display
