I did something stupid.
I was browsing through the options in VCDS and came across the Tire Pressure Monitoring System (TPMS) under "03-ABS Brakes". After successfully entering the module unlock code, I enabled the check box for both:
Bit 3 Tire Pressure Monitoring 1 (TPMS) active [PR-7k6] and
Bit 6 Auto-Hold Function (AVH) active [PR-UH2 / NOT FOR PR-B34/B35]
in the Byte 1 (second byte) window.
This led to the error "TPMS Tyre Pressure! System Malfunction" error to appear on my Driver Information System (DIS) display. As such, I went back to VCDS, unchecked the two check boxes back the way they were (see screen shots of the instruments module and ABS module, below). Again, the error remained on the dashboard. So then I did a auto scan with VCDS and cleared all the codes. Unfortunately, the error still appears on the dash (see below). After driving for 30min or so, the error remains. Doing a new auto-scan with VCDS reveals no error (only with one of the wing mirrors which is unrelated).
Would anyone have any suggestions on how I can clear the warning from the dash?
Code:
Chassis Type: 8K (8T0) Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72 VIN: WAUZZZ8K28A0123456 Mileage: 215840km-134116miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 B HW: 03L 906 022 B Component: R4 2,0L EDC H01 3210 Revision: --H01--- Coding: 0104002C18072118 Shop #: WSC 06325 123 12345 ASAM Dataset: EV_ECM20TDI03L906022B A01014 ROD: EV_ECM20TDI03L906022B.rod VCID: 245FFADB7EDB06A25B085A5-8070 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AQ HW: 8K0 907 379 AQ Component: ESP8 front H03 0210 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 06325 123 12345 VCID: 08078E6BE233C24257308E5-805C No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H70 0134 Revision: 00002001 Coding: 031100 Shop #: WSC 06325 000 00000 VCID: 2E4B18F32017BC72BDAC28D-807A Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C Component: ELVAUDIB8 H35 0039 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 8T2 820 043 K HW: 8T2 820 043 K Component: KLIMA 1 ZONE H05 0120 Revision: B0000000 Serial number: 0126.02.080837 Coding: 34040000 Shop #: WSC 06325 000 00000 VCID: 3A6324A3EC5F60D2112454D-806E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 HW: 8K0 907 063 Component: BCM1 1.0 H21 0253 Revision: 01021001 Serial number: 00000000102665 Coding: 690040B1001400000001000000005F5F001D020800000001000000 Shop #: WSC 06325 000 00000 VCID: 6CCFD2FBD68B0E62D358725-8038 Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 280208 H05 0060 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 B HW: 8K0 941 531 B Component: E1 - LDS H07 0070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H26 0410 Serial number: 0038JD13GBE2 Coding: 30363434363030303030554A3052384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C6F22BBE66B5E620338425-8068 Crash sensor for side airbag; driver side: Serial number: 6334MSME3A0258012 Crash sensor for side airbag; front passenger side: Serial number: 6344MSME3C632A44I Crash sensor for side airbag; rear; driver side: Serial number: 6352QSME4F482501G Crash sensor for side airbag; rear; passenger side: Serial number: 6362QSME4F470B19T Crash sensor for front airbag; driver side: Serial number: 63732SME57662C05% Crash sensor for front airbag; front passenger side: Serial number: 63832SME576B40291 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90315IFO0005Z Coding: 000006 Shop #: WSC 06325 123 12345 VCID: 3D692FBFFD7157EA3406779-8068 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 C HW: 8K0 920 900 C Component: KOMBIINSTR. H14 0216 Revision: 00200000 Serial number: 7VL12AW28 Coding: 2F05080002000008010000 Shop #: WSC 06325 123 12345 VCID: 2A4314E31CFFD05261C404D-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 D HW: 8T0 907 468 D Component: GW-BEM 5CAN H04 0084 Revision: GA801030 Serial number: 3000G082068267 Coding: 000003 Shop #: WSC 00887 209 82239 VCID: 42935C43848F281249F40CD-8016 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H03 0150 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 C HW: 8K0 959 793 A Component: TSG FA H10 0170 Revision: Serial number: 0000006891132 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 4097564B8A833A025FE0165-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H70 0134 Revision: 00002001 Serial number: 0109650308 Coding: 0100062000390040012001 Shop #: WSC 06325 000 00000 VCID: 2E4B18F32017BC72BDAC28D-807A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 C HW: 8K0 959 792 A Component: TSG BF H10 0170 Revision: Serial number: 0000006881779 Coding: 011002204C01410001 Shop #: WSC 06325 123 12345 VCID: 3F9555B7F77D45FA261A6D1-806A 1 Fault Found: 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 8 Reset counter: 98 Mileage: 215817 km Time Indication: 0 Date: 2016.11.20 Time: 23:26:04 ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 D HW: 8K0 907 801 D Component: EPB Audi B8 H04 0050 Revision: 00000003 Serial number: 00000000086993 Shop #: WSC 00000 000 00000 VCID: 3077068B3A23AA82AF80C65-8064 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-152-56.clb Part No SW: 8T2 035 152 HW: 8T2 035 152 Component: Chorus3 H19 0020 Revision: 00000001 Serial number: AUZ1Z2H6188088 Coding: 01000480040108000159070000 Shop #: WSC 06325 123 12345 VCID: 6ECBD8F3E097FC72FD2C68D-803A Subsystem 1 - Part No SW: 8T0 919 603 HW: 8T0 919 603 Component: Display H09 X017 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 A HW: 8K0 959 795 A Component: TSG HL H06 0170 Revision: Serial number: 0000006876731 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 4097564B8A833A025FE0165-8014 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb Part No SW: 8K0 959 794 A HW: 8K0 959 795 A Component: TSG HR H06 0170 Revision: Serial number: 0000006855709 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 3F9555B7F77D45FA261A6D1-806A No fault code found. End-------------------------(Elapsed Time: 02:39)--------------------------
