Results 1 to 6 of 6
    Veteran Member Four Rings MarcusDubya77's Avatar
    Feb 08 2013
    '19 Volvo XC60, '05 Honda S2000 ITBs
    Schonaich, Germany
    Exclamation Symptoms of failing transmission mount
    I have been noticing very heavy shaking of my shifter under acceleration. There is also extreme movement of the shifter when going over bumps, potholes, etc. There is also, what feels like, lateral movement at the beginning of 1st and 2nd gear. Lastly, it appears that my entire shifter has moved up (although I could be crazy). I am going to verify that the shifter is locked down after work today, but doubt its loose. The clutch and gears were very recently replaced. Are there any other possibilities other than transmission mount failure? The engine isn't shaking, so I do not believe the motor mounts have failed. Any ideas or suggestions would be great.
    18 Catalunya RS3 Unitronic Stg 2/TCU Stg 2, APR DP & Intake, CTS Intercooler, 034 MPs, ECE Dogbone (0-60-3.18 : 1/4-11.16 on 98 RON) & 05 S2000 w/ ITB setup
    Gone, but not forgotten- 19 C43 AMG / 12 Abarth (full bolt on) / 07 JHM SC'ed / 08 Evolution X (full bolt on) / 05 M3 Dinan SC'ed / 05 LGT w/ Hybrid Turbo ......and many others!
    "Bitches... Come over here and have sex with Charlie Murphy" ~ Rick James
    Sep 20 2015
    Do you have the original mounts for the rear diff and trans?
    Feb 08 2013
    Schonaich, Germany
    Yessir.
    Sep 20 2015
    Quote Originally Posted by MarcusDubya77 View Post
    Yessir.
    Try upgrading those mounts as they are probably worn out. Also if you have a single mass flywheel you might get a little bit more shake compared to a dual mass flywheel that will dampen vibration better. When I was upgrading my clutch it was advised to stay with a dual mass flywheel for a more smoother ride. Some mods do require sacrifice.
    Mar 05 2013
    CA
    Quote Originally Posted by simple_king View Post
    Peeking in from A4 subforum.
    I don't even know man. I hear the popular Valeo 1.8T SMF kit induces some chatter and that it may be fixable with Fluidampr, which is also available for 3.0/2.7T. IDK if they have or will make it for 4.2L, or if other ones can be modified to fit. My point is, supposedly 1.8T is unbalanced. And, it's an I4. Whereas you have a V8, which I'd guess is smoother. I also hear RS4 clutch kit is good, whatever that is. I assume that includes a DMF.
    B7 and V-engines are also 240mm, while B6 1.8T is 228mm. Someone just figured out how to fit 240mm DMF on a B6.
    My shifter does that too. I guess I'll see if it changes, since the car is high miles and on stock original mounts that I bet are worn. Not sure if I should use OEM hydraulic fluid filled, 034 SD, or 'Febi S4'.
    And I bet the suspension is not doing it's job of fully absorbing road shock, so instead it goes elsewhere. I hear the car was made with a smooth maintained Autobahn in mind, not a poor US road. It's no $100k new Mercedes S-class on air suspension, let's just put it that way. Leaves some to be desired. Maybe high quality coilovers will fix this? Or better yet cheaper Koni FSD?
    Might the rear be allowing rotational slack? ie rear diff bushing such as PowerFlex and 034 carrier inserts?
    My subframe bushings also seem to flex. Also hydraulic fluid-filled. I hear they go bad by 200k, and that the front subframe can also split at the seam requiring welding. Sport suspension gets a stiffer bushing than non. Lemforder. And 034 also makes metal ones, which JimmyBones put on his B6 S4.
    But that is just when I try working it with a prybar. IDK what that means in practical road-use terms.
    Unfortunately I have no answers
    Feb 08 2013
    Schonaich, Germany
    Any type of methods to inspect to compliment a visual inspection of the mounts ? Also, any good links for reviews between Apikol and/ or 034 mounts? Any other good options?
