The car is a 2016 S4 6MT In Mythos Black with Sports Diff, B&O, Carbon Atlas Trim, and Tech Package.
Here's my mod list...
Go-fast mods:
GIAC Dual Pulley Tune
GIAC LPFP Upgrade
AWE Supercharger Pulley
iAbed Industries 74mm Throttle Body Upgrade
AMS Alpha Cooling System
JHM Stage 5R Clutch
JHM Lightweight Flywheel
USP Stainless Braided Clutch Line
AWE Touring Exhaust
Crown Motorsports Intake
186mm Crank Pulley
Crown Motorsports Ceramic Coated Test Pipes
Crown Motorsports Ported and Polished Supercharger
Suspension:
JRZ RS Pro 3 Custom Spec Coilovers
Eurocode Front & Rear Sway Bars
Eurocode End Links
Eurocode AluKruez
ECS Transmission & Diff. Mount Inserts
034 Asjustable Upper Control Arms
CR-15 Brace
Cosmetic/Miscellaneous Mods:
Recaro Sportster CS Seats
Vorsteiner V-FF 101 19x8.5 et45 w/ custom Brushed Copper paint
H&R 10mm Spacers
034 Transmission Mount
034 Motorsports Density Line Motor Mounts
Eurocode Short Shifter
JHM Solid Shift Linkage
RS4 Piano Black MMI/Cluster Trim
RS4 Style Front Bumper and Grille
E-Code Headlights
Window Trim and Rear Valance Painted Mythos Black
P3 Vent Gauge
BlackVue DR650S-2CH Dash Cam
Beltronics STi-R+ Radar Detector
Laser Interceptor Laser Jammer
XPel Full Front Clear Bra
Gtechniq Crystal Serum Ceramic Coating
ECS Carbon Fiber Engine/Supercharger Covers
Track Stuff:
Neuspeed RSe10 Wheels - 19x9 et40 (primary set) with Hoosier R7 265/35/19 Tires
Neuspeed RSe102 Wheels - 19x9 et40 (backup set) with Hoosier R7 265/35/19 Tires
VMR V810 Wheels - 19x8.5 et35 with Bridgestone RE-71R 255/35/19 Tires
Naca Ducts
Macan Air Scoops
AP Racing Radi-CAL 370mm J-hook Rotors
AP Racing Radi-CAL 6-piston Calipers
AP Racing Stainless Braided Brake Lines
Macan Dust Shields
Almost all of the work was done by Crown Motorsports in St. Petersburg, FL. The quality of work they do is top notch and their customer service is unbeatable. If anyone in the Tampa Bay Area is looking for somewhere to get work done, definitely go see Evan and his crew.
Most of the pictures I have are crappy iPhone shots. Here are some of the better ones in chronological order, except for the first two. Those will always be the latest pictures - one will be the street setup and the other will be the track setup.
The night I picked it up. Parked next to the '14 S4 I traded in
Still stock other than APR stage 1
Coilovers installed. Sorry for the shitty quality pictures.
AluKreuz, Sway Bars, and Intake installed
AWE Touring exhaust w/ stock downpipes
Paint Correction, XPel, and Ceramic Coating complete
APR Pulley and Stage 2
AMS Alpha cooler installed
(I don't have these pictures on my phone. And for some reason I'm having an issue downloading them from my Photobucket account. Maybe I'll have to use my desktop instead of my phone. I'll give that a shot later )
JHM Stage 4 clutch and lightweight flywheel
Removed JHM Stage 4 clutch and replaced with Stage 5R clutch. Had to replace the flywheel friction liner as well.
Loaded on a trailer for my first ever HPDE. Went to Sebring International Raceway. Unfortunately U-Haul didn't properly maintain their trailer. A piece of metal was sticking up and pulled/ripped off my front bumper when I backed the car off.
RS4 Style bumper and grille (since the stock one was damaged), Killer Chiller, and custom brake ducting. I wanted to put scoops where the fog lights were, but there wasn't enough room after the Alpha cooler reservoir/pump and Killer Chiller. So we went with NACA ducts in the belly pan.
Switched from APR to GIAC Stage 2 with Stock, 93, and Race files. So I bought some MS109.
VMR track wheels
Vorsteiner V-FF 101 wheels (custom Brushed Copper painted finish). Also had the Audi rings, Supercharged Badges, and S4 Badge painted to match.
