Originally Posted by
MRCT
i read somewhere that once the pills been activated or programmed to a car thats it.. cant program the pill a 2nd time.. is that true?
You're confusing the remote for locking/alarm with the Immobilizer maybe? The RFID 'pill' can only be programmed to ONE specific Immobilizer system. It can be re-programmed to that system many times, but not to a different one.
The remote can be programmed to as many cars as many times as you want. You can program a remote to several cars at one time- so if you have 3 B6's, you can program ONE remote to lock/unlock all of them.
You can try to do the owner-manual version of programming the remote, but it usually doesn;t work, especially for an initial programming. The easiest way is to use Vag-Com, log into the Central Elect. module, go to MBV...it's like 8 or 10. Press the remote buttons and see if it's recognized.
Or go straight to adaptations, then remote learning, and select #1 - #4 to assign the remote to. Press some buttons on the remote and see if the field cycles to 'recognized'.
If not then try a different remote. The CECM module was updated in 2003, so there are a bunch of B6 remotes that only work on the early model. So it can be tricky to verify you absolutely have a correct remote.
Beyond that there's no special tricks or anything.
