Results 1 to 17 of 17
    Established Member Two Rings saw76's Avatar
    Nov 30 2012
    2010 Audi S4 3.0T-2011 A3Quattro,2005Passat
    Marlborough, MA
    2010 S4 bad supercharger
    So after many years and not to many problems my beloved b8s4 has a new noise .
    I'm wondering if anyone else has seen or heard of a supercharger going out ? Yesterday at a stoplight I heard a groaning noise at idle .
    I asked my friend who is a very good master tech at a dealer and he said he's never seen one go bad . It sure sounds like it . Car has 62,000 miles and is stage 2 APR , roc euro intake and miltek exhaust . It's going in Monday for a proper evaluation. Anybody see this before ? Or heard of one going bad ?
    2010 ibis white s4 6mt 3.0T APR STAGE 2 with Snow Performance stage 3 Methanol Injection* 2011 A3 Quattro 2.0t s-line deep sea pearl blue metalic,APR full load tune.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    It sounds like a bearing problem. Without being there in person or a stethoscope i couldn't tell you. Sounds like a rough bearing.
    Nov 30 2012
    Marlborough, MA
    Ya that's what I thought to , a bearing in the supercharger has gone bad . It's still making normal boost but it sounds horrible . My tech said same thing . He's not sure if it's rebuildable or not as he's never had to price one out before .
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Quote Originally Posted by saw76 View Post
    yes the front bearing just behind the pulley can be replace...
    But it come with the whole front snout.
    tks
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Nov 12 2015
    Here
    Smaller pulleys = Higher risk of SC failure
    Mein ist grau
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I've only heard of a handful of superchargers failing in total- so it's not common.
    However the good news (if an internal supercharger bearing is indeed bad), is that used superchargers are priced quite reasonably; even with low-ish mileage.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Nov 12 2015
    Here
    Wonder how many in that "handful" had been running reduced-diameter pulleys...
    Mein ist grau
    Jan 02 2011
    2018 4M Q7, 996 Turbo, 2014 Q5 3.0T
    MN
    2018 Audi Q7 3.0T: Glacier White Metallic/Black, Prem +, Driver Asst. Pkg, Vision Pkg, 20" 10-spokes - Dadwagon 3.0
    2014 Audi Q5 3.0T: Moonlight Blue/Black, S-Line, Sport Interior, Nav, Adv Key, VAG-com's, 034 Intake tube Wife's Daily Driver - Momwagon 3.0
    2001 996 Turbo: Black/Black, Tip, Diamond Black BBS RS-GT's - Summer Car
    Nov 30 2012
    Marlborough, MA
    So it's confirmed, bad bearing in the charger . 750 for supercharger front assembly and 6 plus hours labor to replace . They have never seen one go bad .
    Nov 30 2012
    Marlborough, MA
    Just a quick update, replaced with a used supercharger with 30k miles for 650.00 f rom LKQ . car is running great. I have the old on on my bench waiting for me to take it apart and see what failed and why. Not sure if methanol had to do with this or not. I talked to eaton , who makes them for audi and they said methanol should not hurt it . smaller pulley would make more sense
    Apr 05 2016
    Portland, OR
    Probably just bearing wear. I doubt the meth had anything to do with it.
    Here is a tear down of the SC that might help you: http://www.audizine.com/forum/showth...arger-Teardown
    Geoff
    Nov 30 2012
    Marlborough, MA
    yeah I agree it was bearing wear. 2010 audi S4 , had 59,000 miles on it and was stage 2 apr for 30k of those miles. my current miles on the car now is 62,000 and now has a used charger with 30k lol
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Quote Originally Posted by whiped View Post
    If anyone is interested I still have the snout and internals from that teardown! 10k miles on them.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Nov 30 2012
    Marlborough, MA
    So is that the newer style charger with the front snout ? . My first attempt from lkq was one of theseoff a 14 Q5 and it did not fit. This style decoupler pulley and snout is for the newer style and not to be put on the 2010-13 cars I believe. It is completely different than the one on my 2010 s4. What car did it come off of ?
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    It's been demonstrated that the supercharger can benefit from some love despite claims to the contrary. If you're at about 75K it's time to start thinking about it. imvhfo.
    Sep 19 2012
    Easton, PA
    Quote Originally Posted by LeadToRome View Post
    Can you elaborate on what type of preventative maintenance is recommended for high-mileage supercharger? I'm not doubting you. I just don't know.
    My 2012 is right at 78K miles and I'm planning to keep the car. So, I am trying to compile a list of all the maintenance items I should address to keep things running right. Thanks.
    2012 S4 Premium Plus | Phantom Black | Black/Silver Nappa | Carbon Atlas | 6MT | Sports Diff | Advanced Key | 18" OEM Wheels | Rear Side Airbags | V1 Hardwired | Roc-Euro Intake | Borla Exhaust | CR-15 Strut Brace | Up next...BBS CH-R 18"
    Nov 30 2012
    Marlborough, MA
    Quote Originally Posted by Captain Tuttle View Post
    ECS tuning sells the oil for the supercharger and my friend who is a tech was saying it's not a bad idea to change the oil once in a while . It seems pretty simple . They have a drain and fill hole .
    Sent from my iPhone using Tapatalk Pro
