Results 1 to 25 of 25
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Floor jack recommendation?
    Yes I used the search button, just looking to feel out what people are currently using or what you would recommend.
    What floor jack would you recommend for our low profile car? Looking at a 3-ton harbor freight or nappa.
    Also tool related, what kind of torque wrench are you using? Looking to expand my tools so I can swap out wheels in the winter/summer. Thanks!
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Interested as well. Been looking at options on Amazon for black friday
    2012 S4/ Prestige/ Black Optics Package/DSG/Red Leather/B&O sound
    KW HAS/RS4 grille/LED conversion/USP Intake/AWE Touring-resonated DP's/034 trans mount/Niche Stacatto 20x9/CF Stvbek front lip/Unitronic Stage 2 ECU/TCU/ECS CF diffuser/CR-15 Strut brace
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I like the Harbor Freight/Pittsburgh Racing jacks. They come in aluminum and steel; I have the aluminum (2.5 ton?) version and it works great.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    If your a Costco member they have a great 3 ton light weight low profile jack for $99
    [B]Current: Shopping now....
    Mar 21 2015
    Harbor Freight Aluminum is great and cheap.
    Jun 17 2010
    Madison WI
    Quote Originally Posted by k9lovr View Post
    I second this.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Veteran Member Three Rings Kenrevo's Avatar
    Aug 05 2013
    MA
    Quote Originally Posted by LINDW4LL View Post
    I have the same or similar one and the only "issue" I have is it can't jack it high enough to get my 3 ton jack stands under the car. I add a block of wood and it fine.
    '01.5 S4 F21 on meth -- DD
    '05 Touareg V8, loaded
    '00 A4 1.8t Avant SOLD
    '99.5 A4 2.8l 30v QMS SOLD
    Mar 21 2015
    Quote Originally Posted by Kenrevo View Post
    They offer the jack in a few different heights.
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    I use a pair of these Arcan Quick Rise-Low Profile Jacks - http://www.northerntool.com/shop/too...5429_200345429 -
    with these pinch weld pads - https://www.amazon.com/Single-Medium...R53M71FX0DWWPP - as the jacks provide the lift height (and two provide safe, even lifting, i.e. front lifting and then rear lifting) to use these race ramps - https://www.amazon.com/Race-Ramps-RR.../dp/B003ZAEUE4 - when I want to get all four off the floor.
    When I don't need to raise the S4 to that height, or need the wheels off, I use two to four of these aluminum jack stands - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Those is a Canadian tying, but I'm guessing it might be a rebadged version of something else.
    http://www.canadiantire.ca/en/pdp/mo...1047p.html#srp
    Jacks nice and high, fast and effortless.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Established Member Two Rings saw76's Avatar
    Nov 30 2012
    2010 Audi S4 3.0T-2011 A3Quattro,2005Passat
    Marlborough, MA
    https://www.ecstuning.com/b-schwaben...lZDhoCwmXw_wcB
    That's the one I have and love it . No problems
    2010 ibis white s4 6mt 3.0T APR STAGE 2 with Snow Performance stage 3 Methanol Injection* 2011 A3 Quattro 2.0t s-line deep sea pearl blue metalic,APR full load tune.
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    The reg 3 ton, rapid pump is 69.99 @ harbor freight this Friday-Sunday, I believe it is the non low profile version. Pretty good deal
    Sep 22 2015
    21 Q7, 21 X7
    Nashville, TN
    Another vote for Costco.
    Torque wrench I'm using Kobalt 1/2" from Lowes. No complaints. Going to try the Tekton Amazon 3/8" for Xmas.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    harbour Freight aluminum is awesome. Ive had one for 1 year and no issues. My dad has had his for 6 years and no issues. I've used it on many of vehicles and no issues.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    When I bought our S4, I decided to upgrade my floor jack from an aluminum "racing" racing jack I had used on my VWs. It was pretty lightweight, but didn't seem very rugged. I don't recall it's lifting capacity, but I didn't want to chance using it for lifting the S4's weight without using jack stands, even to just change wheel/tires. I ended up buying a DK20Q AC hydraulic floor jack, from Pelican Parts. It's well-made, made in Denmark, and has a 4400lb capacity. The wheels have polyurethane O-rings that make it smooth and quiet to roll around. It's got a low profile minimum height of 3.15" and a lift height of 19.7". AC also has a high lift model with a 29" lift. The only regret I have about this jack is that I store it in my basement and when I need to use it, I have to enlist my wife's help to carry it up the stairs (it's 68lbs of frikken heavy!).
    [IMG][/IMG]
    [IMG][/IMG]
    In action (NOT my car!)
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Oct 25 2016
    e46
    St. Louis
    The harbor freight ones are great and should be getting a good price with Black Friday coming uo
    Sent from hell
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by 13ttaz View Post
    I have the exact same Arcan jack and it works perfectly. Low profile and very robust construction.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Senior Member Two Rings MagillaGorilla's Avatar
    Nov 25 2015
    London Ontario
    Where do you guys put your jack stands after jacking the car up? The exposed part of the pinch weld is pretty small and my jack and jackstands don't both fit under. Do I need to find some extra skinny jack stands or am I missing something?
    Apr 11 2012
    been using OTC 2ton racing jack on the S4 and S3, with protech and schwaben pads:
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    bump for current recommendations. I have a b8 A4 but didn't see any threads started over there. I live in the city with off city street parking, though there are still cars on either side of me. There is also a slight slope (3-5 degrees) where I park
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    I've used the steel harbor freight one for 3ish years with no issues at all. Then schwarben pad adapters. I didn't like the alum one as much
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    Quote Originally Posted by will13k7 View Post
    OTC here as well. have had it for 5 years , no issues,. Have had wheels fall off a harbor Freight jacs before that. do not trust them on 4000 pound cars.
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by onlyaudis View Post
    you've got the 2 ton for a 3,600+ pound car? What's the recommended bump to the 2.5-3-ton at that point? Assuming the 17" max height on the jack stands is JUST ENOUGH to see something and not necessarily work under?
    Established Member Two Rings pabohoney1's Avatar
    May 03 2017
    Phoenix
    I've been using the Harbor Freight "3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump®" jacks for years. They're low enough to get under my wife's lowered GTI. For the price they're great, and you can get 20-25% off at HF on one item with the online coupon that's always available. Pinch weld pads are recommended as well.
    Oct 29 2010
    Phoenix
    I use this HF low profile, extended reach jack. The extended reach was important for use with my other lowered vehicles. For the money it's a great jack. Just beware that if you need to transport it anywhere it's a heavy beast. Of course there are better low profile jacks out there such as the Arcans, but this one is about one quarter of the price.
    https://t.harborfreight.com/2-ton-lo...ump-60678.html
