Thread: N75 valve test
    Jun 26 2008
    Chicago, IL
    N75 valve test
    What's the easiest way to test the n75? Do I need block two ports and apply air to the third??
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    VCDS logging is best way.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Jun 26 2008
    Chicago, IL
    Does VCDS show there pressure in those lines?
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    May 09 2012
    Virginia
    There's mechanical function and electronic function.
    Vag-com to log the electronic function. It looks at duty cycle
    For mechanical function you remove the vacuum line from the N75 to the wastegate acuator you are basically disabling the wastegate actuator - the wastegate will never open. The boost will be higher as it is no longer being limited. If you go WOT you run the risk of overboosting and running lean or detonating.
    If you remove the line and are able to achieve the correct amount of boost (while being careful not to over boost) then you may have a bad N75. If you remove the line and it runs the same then you have a wastegate problem, turbo problem, or a large boost leak.
    Nov 04 2012
    Reno
    N75 valve test
    Logging duty cycle will tell you how hard the n75 is trying to open the wastegate, no need to risk damaging your engine, although that method is probably more fun.
    Can also log requested v actual boost.
