Results 1 to 13 of 13
    Veteran Member Four Rings marked001's Avatar
    Feb 17 2004
    08 Subaru Impreza WRX; vr
    South Philadelphia
    compress springs while on car?
    ok... this may be a stupid idea, but its early..haha.. I think i want to raise my car up for the winter... I've got notched bilsteins... is it possible to compress the springs while everythings on the car...and slide the perch up a few notches? I dont remember how the perch moves out of the notches..any ideas on this? thanks.
    F the Jersey Jerks
    Jersey Jerk hata #1
    99.5 t28 A4 ....bye bye.
    www.REVI21ON.com
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    yes you can.... wish I took pictures this past weekend while doing that exact thing (on Coilovers anyway).
    you'll need a strut spring compressor tool.
    what's the difference in height between perch settings on your shocks?
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Feb 17 2004
    South Philadelphia
    I think its about an inch on the front..I believe theyr'e about a quarter inch apart...so I think its def. worth it..
    F the Jersey Jerks
    Jersey Jerk hata #1
    www.REVI21ON.com
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    is that a different tool than a regular spring compressor? I've only heard of a regular spring compressor.
    The harder I practice, the luckier I get.
    - Gary Player
    Feb 16 2004
    This thing:
    Here's another way a fellow AZ'er Moops did it:
    Too bad I didn't take a pic . I was getting the springs off of the perches by about 3/8". I probably could have got them to compress a little more - but it was enough for me to spin up my perches.
    Feb 17 2004
    South Philadelphia
    where'd you grab the spring compressor at? def. need more than half an inch though..
    F the Jersey Jerks
    Jersey Jerk hata #1
    www.REVI21ON.com
    Dec 07 2004
    This thing:
    that ratchet strap/come-along method looks scary...
    - Gary Player
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    It's a tight squeeze to compress springs while on the car. Pull the two color caps in the engine bay and then remove the two 13mm bolts. Then just remove the bottom bolt and the whole thing will basically drop down with some coaxing.
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    the ratcheting tow strap is ghetto. That doesn't mean I won't try it sometime
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Feb 16 2004
    I just rented them from my local auto parts store (Canadian Tire). They lend you the tools, you leave a deposit, when you return them, they give you the deposit back.
    I could have compressed the fronts more, while pushing down on the spindle arm (or whatever it's called). Be sure that the wheel on the other side of the car is unweighted also, such that you're not working against the sway bar.
    ... as for the straps - had I not found a spring compression tool - I would have resorted to that!
    Veteran Member Four Rings SeanF's Avatar
    Sep 13 2004
    Concord (LMS area), NC
    yea, i found out you dont even need to remove the upper arms from the knuckle to get the strut assembly out...
    you just have to push down on the hub to get the lower strut mount off and around the control arm...
    2007 Black Mica Mazdaspeed3 GT, w/ navigation
    Built, Blown, and Squeezin' on a 3071r
    Feb 17 2004
    South Philadelphia
    hmm..maybe i'll stop being lazy and pull the suspension.. I was lazy and had it installed b/c it was so damn cheap..
    F the Jersey Jerks
    Jersey Jerk hata #1
    www.REVI21ON.com
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    I have the notched bilsteins from ECS and h&R race. I did the exact procedure to raise the car a little bit last weekend. I completely removed the suspension. It would have been hell to try and do it while on the car. I am on perch 5 (countin from the bottom) on the fronts and back now. I had to compress the springs a good 2 inches because each perch is about 1/2 inch. Plus the rears are harder to compress because the coils are closer together to begin with.
    The perches move by just unclipping them and sliding them up or down. (needle nose pliers job) It's kinda hard to explain, but pull the ends apart from each other <-> like that instead of trying to pull them away from the shock body.
