This is your chance to protect the precious underbelly of your Audi, just in time for winter, at a fraction of the cost of new! PM me, call/text 201.602.7670, or email [email protected] if interested
From Evolution's Site:
"The Thor A4 Skid Plate Kit Includes:
SKU A1007- 1 Thor Aluminum Skid Plate.
SKU A2006- 1 Thor Audi A4 Hardware Kit, containing:
2 Aluminum Thor Side Wings.
1 Thor Rivet Nut Installation Tool.
1 Thor Audi A4 Bolt Kit
Fits:
1996-2001 Audi A4, Sedan, Avant & Wagon (B5 Platform)
1998-2002 Audi S4, Sedan, Avant & Wagon (B5 Platform)
2002-2008 Audi A4, S4, Sedan, Avant & Wagon (B6 & B7 Platform)
WHY YOU SHOULD BUY EVOLUTION'S THOR AUDI A4 ALUMINUM SKID PLATE!
Audi's oil pans are made of a paper-thin cast aluminum that is easily cracked by many objects such as road debris, manhole covers and speed bumps. While your car may be at stock height, there is only approximately 4 inches of ground clearance with your oil pan. If you are lowered from stock height, there is very little room for error when negotiating an object in your path.
Here is some information on this Evolution Aluminum Skid Plate for those of you that haven't seen it before.
The plate is 5052 grade aluminum and is 4.8mm (.191 inches) thick.
Weighs 16.7 pounds
Protects your cars oil pan, a/c pump, radiator & transmission (does not cover the transmission fully).
Bolts to you vehicle with 3 structural mounts and up to two additional plastic mounts.
45 to 60 minute install.
Once the plate is installed it is only 4-5 bolts that need to be removed for your oil change(1-2minutes).
Fits all engines and transmissions. A4, S4 V8 engine owners must read the info at the bottom of the page.
Never rusts.
Maximum amount of ground clearance possible provided.
Air duct to allow air flow onto the transmission.
Specially designed so you won't have to worry about air forcing your plastic tire well lining back and into your tires.
CNC Machine Manufactured."
