Results 1 to 11 of 11
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Question Codes from VCDS - What does it all mean?
    Hi Everyone,
    I'm trying to figure out what all this means from Ross-Tech VCDS Lite.
    I'll be doing some research too, but figured I would start a thread so I can discuss further with you all.
    Original Owner expressed that the O2 Sensor was causing the Engine Light. I don't see that here.
    I do want to say that I cleared the codes so they will repopulate as the engine light has been on since I purchased a couple weeks back.
    I figure clearing the codes and seeing what comes back might be helpful.
    Can you tell me what i'm looking at here? is there anything else I should be doing in VCDS to help me research problems or identify problems?
    VCDS-Lite Version: Release 1.2
    Sunday, 13 November 2016, 10:23:58.
    Control Module Part Number: 8D0 907 551 M
    Component and/or Version: 2.7l V6/5VT G 0002
    Software Coding: 06651
    Work Shop Code: WSC 13368
    VCID: 341B9FD31723
    5 Faults Found:
    17834 - EVAP Purge Valve (N80): Open Circuit
    P1426 - 35-10 - - - Intermittent
    17539 - Shareware Version. To Decode all DTCs
    P1131 - 35-10 - Please Register/Activate - Intermittent
    17965 - Shareware Version. To Decode all DTCs
    P1557 - 35-10 - Please Register/Activate - Intermittent
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-10 - - - Intermittent
    16885 - Shareware Version. To Decode all DTCs
    P0501 - 35-10 - Please Register/Activate - Intermittent
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    You need to learn to google p codes.
    Sent from my Jailbroken iPhone 6s iOS9.3.3 using Tapashit
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 11 2016
    Connecticut
    Google P Codes. Got it.
    Any insight on the repairs for these fault codes?
    Oct 09 2012
    Quote Originally Posted by JustManson View Post
    Any insight on the repairs for these fault codes?]
    Google them and put here what they each mean.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Nov 07 2010
    South of Heaven
    Have you cleared these and see if any will come back or are they persistent?
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    It's usually considered to be in bad form to just drop a pile of codes on someone, and expect them to the do the leg work if figuring out what codes mean what, especially if you're using shareware VCDS.
    17834/P1426/005158 - EVAP Purge Valve (N80): Open Circuit
    Possible Symptoms
    Malfunction Indicator Ligh (MIL) active
    Possible Causes
    EVAP Purge Valve (N80) faulty
    Wiring/Connectors from/to EVAP Purge Valve (N80) faulty
    Fuel Pump Relay (J17) faulty
    Possible Solutions
    Check EVAP Purge Valve (N80)
    Check Wiring/Connectors from/to EVAP Purge Valve (N80)
    Check Fuel Pump Relay (J17)
    17539/P1131/004401 - Oxygen/Lambda Sensor Bank 2 Sensor 1: Internal Resistance too High
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Possible Causes
    Wiring and/or Connector(s) from/to Oxygen/Lambda Sensor Bank 2 Sensor 1 faulty
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    18058/P1650/005712 - Powertrain Data Bus: Missing Message from Instrument Cluster
    Possible Symptoms
    Possible Causes
    Fuse(s) faulty
    Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285) faulty
    Possible Solutions
    Check Fuse(s)
    Check Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285)
    Check/Replace Instrument Cluster (J285)
    Check Measuring Value Blocks (MVB)
    16885/P0501/001281 - Vehicle Speed Sensor (G22): Implausible Signal
    Possible Causes
    Wiring/Connectors from/to Vehicle Speed Sensor (G22) faulty
    Wiring/Connectors from Transmission Control Module (J217) to Engine Control Module faulty
    Malfunctioning Left Front wheel speed sensor (in vehicles that don't use a physical G22 sensor)
    Possible Solutions
    Check Wiring/Connectors from/to Vehicle Speed Sensor (G22)
    Check Wiring/Connectors from Transmission Control Module (J217) to Engine Control Module
    Check Vehicle Speed Sensor (G22)
    Check ABS Brakes for faults and diagnose malfunctioning Left Front wheel speed sensor if applicable
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Senior Member Three Rings DoesntCare's Avatar
    Feb 28 2016
    SEPA
    Take each p code you got and put it into google. One of the first results for each should be a Ross-tech page. The Ross-Tech pages should tell you what the code definition is, what you would be seeing because of that code, and what generally causes the code.
    Avant Nate's post is copied from their page, so you can get an idea of what information you'll see on the site.
    You'll also be able to find threads posted by people who have had those codes and were unable to solve them with what was in the Ross-Tech page, which can give you some information about indirect causes or uncommon causes for the CEL.
    In the time I was writing this, Avant Nate was nice enough to search the codes for you.
    Oct 11 2016
    Connecticut
    Sorry for my "bad form". I didn't get a chance to decode them yet, but I whole heartedly appreciate what you have contributed to this thread.
    Let me read up on everything and I'll certainly post back more educated results.
    Thank you!
    Oct 11 2016
    Connecticut
    Ok... so after much reading and searching and using the Ross Tech Lite version I determined that these codes are bogus based on the fact that I ran the car with no guage cluster while it was being repaired. Mind you it was driven just started.
    Possible Symptoms
    Possible Causes
    Fuse(s) faulty
    Possible Solutions
    Check Fuse(s)
    Possible Causes
    Possible Solutions
    So those are out, but these other 3 I have to work on.
    For the N80 I just purchased a new one. We'll see if that makes a difference considering they do go bad.
    Possible Symptoms
    Possible Causes
    Possible Solutions
    I have purchased an O2 Sensor and the OEM O2 tool kit so I can replace the O2 sensor, drivers side which looks like it could be difficult, but nothing I can't handle.
    Possible Symptoms
    Possible Causes
    This last code is causing my Audi to go into Limp Mode so I ordered another from ECS Tuning after reading about the sensor for hours.... there sure is a lot out there on this.
    Possible Symptoms
    Limp mode
    Possible Causes
    Possible Solutions
    I'll post back some results once I replace the parts and I thank you very much for doing the leg work for me. I learned my lesson ... :)
    Dec 05 2007
    Quote Originally Posted by Corrado_Guy View Post
    OP, you followed this advice too correct? You could be chasing phantoms, meaning irrelevant DTCs (diagnostic trouble shooting codes).
    Oct 11 2016
    Connecticut
    All codes came back except the P1650 and P0501.
    N75 is over boosting to 24psi should 21 then to 19 on the tune. I think prior owner installed "race" valve from ecs from a first conversation with him I recall something like that. It makes sense for what it costs to replace to try it.
    O2 is consistent comes up within hours.
    And I haven't ordered the N80 yet but I think I will tomorrow... just need to research it a bit more, but will probably just get it from ECS as they are reputable.
    Hopefully it's that easy... but it's a B5 so ... probably not Hahaha.
