Page 1 of 4 123 ... LastLast
Results 1 to 40 of 138
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Thumbs up New Products - CETE Automotive Air Suspension + Exhaust Valve Controller Packages...
    Europrice is working with CETE Automotive in Germany to bring and support their innovative controller packages in North America...
    Air Suspension Controller Package
    • Complete full range control of ride height
    • Drive Select stays fully functional
    • Intuitive and simple to use app
    • Fully programmable system
    • Speed sensitive suspension programmability
    • Show mode allows for a fully slammed appearance
    • Plug and Play - No Cutting/Splicing is Required
    • Instructions Included for Installation
    Air Suspension Controller Package -
    Information:
    With this active suspension control module you have the opportunity to use the full range of your air suspension and control it according to your wishes without using the drive select controls. Since the system uses wifi and a smartphone app no additional buttons or controllers need to be fitted to the interior of the car. The full drive select system stays intact along with all other wireless and Bluetooth functions. Works with all models that have factory fitted air suspension, C7 and C7.5 included.
    • Full control over keeping exhaust valves open at all times
    • Exhaust valves open immediately on startup
    Information:
    With this exhaust valve control module you have the ability to keep the exhaust valves open fully in the dynamic drive select setting at all RPM. The exhaust valves will also automatically be set to dynamic when the car is started if it was shut-off in dynamic mode. In automatic mode the exhaust valves behave as they would stock and in comfort the exhaust valves remain closed until 5000rpm. Works with all models that have factory or aftermarket exhausts with valving that are utilizing the factory control systems, C7 and C7.5 included.
    Questions, Quotes:
    If you would like a quote including delivery, have any questions or needs other than those posted above please don't hesitate to PM or email: [email protected]
    Cheers!
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    i will be buying an air controller, but waiting until spring time :)
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Wasn't aware of the exhaust valve module :).
    Since it doesn't have buttons, i suppose this only a module that reprograms it to ALWAYS keep open with no way of manually controle it i assume?
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by Dasquade View Post
    I have better described how the exhaust controller works above. It doesn't merely just keep the valves open all the time. In dynamic it keeps valves open all the time and a neat feature is it will keep the exhaust in dynamic mode if the car is shut-off that way and then restarted.
    In auto the exhaust valves behave in their standard fashion and in comfort the valves stay closed until 5000rpm.
    Cheers,
    www.europrice.us
    [email protected]
    Oct 16 2012
    pa
    Quote Originally Posted by Alex@Europrice View Post
    Cheers,
    Seems pricey compared to the awe solution but I guess if you want it integrated into the modes I could understand
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by saxon View Post
    I believe the AWE system is limited in that it only opens and closes the exhaust valves. No other automated/factory functions exist anymore. Plus you also then have to have a remote in the car and manually control the valves.
    The CETE system is more costly because it is working with the factory systems so you don't have to have a remote in the car and you have 3 choices just like the factory allows, however the functions are modified:
    Dynamic - Full Open at all RPM (Also starts with valves open when car restarted, no need to open them again)
    Automatic - Standard Factory Behavior
    Comfort - Closed until 5000rpm
    Personally I prefer to have the ability to adjust the settings with the drive select system. If I wanted the exhaust fully open without restriction I can set that now, automatic if driving around town and comfort for those times when I'd prefer to car quieter.
    Cheers,
    www.europrice.us
    [email protected]
    Jan 31 2009
    2016 RS7-P
    Bump for Alex and Cete. Have done the VAGCOM lowering and had a H&R module which works as advertised but way over priced if you buy it new.
    Feb 25 2014
    Texas
    Alex, PM sent!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by widebodyfx View Post
    Always glad to help with your project, thanks again! Looks awesome
    Quote Originally Posted by AudiS4B8 View Post
    Alex, PM sent!
    PM sent back.
    Cheers,
    www.europrice.us
    [email protected]
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    Alex, would I need to alter my current setup with the CETE lowering module if I added the valve control?
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Jan 31 2009
    2016 RS7-P
    I'm not sure if that module requires can bus but I asked Ferdi about the Akrapovic needing access to the same pin location as his suspension module, he said any open pins near slot 12 that he calls for in the suspension installation can be used.
    Jan 31 2009
    2016 RS7-P
    Here are the install instructions for the valve control from Ferdi, he only has it in German right now. Easy to tell what to do.
    https://www.dropbox.com/s/dr3bnzz3ey...ng_de.pdf?dl=0
    Below is a snip from the Akrapovic installation instructions, the open pin right next to 12 can be used for the valve control.
    Instructions for the suspension module in case anyone wants to see it before hand, it is easy. Hardest part is getting the can bus harness out of the pocket so you can pin it but it is possible when you stop being too gentle with the harness.
    https://drive.google.com/file/d/0B6c...JTSzhhOVU/view
    Feb 25 2014
    Texas
    You've been a big help, thanks! I'm most likely ordering the lowering module today. I want to hear feedback on the exhaust valve module before pulling the trigger.
    EDIT: Just ordered
    10.65 @ 129mph
    Deactivated Two Rings
    Jun 28 2015
    Southern Pines, NC
    Very interested in this as I actually like how the stock exhaust on the S6 sounds! My only question..how much of a difference is it with sound in dynamic mode? Essentially, it appears I will be getting new lower RPM sound (I've read the flaps in dynamic open at around 3500 RPM) and a louder startup (Open at startup)? Just want to see if anyone has any experience yet with this or if this is in fact accurate before I drop $500 on this. Thanks!
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by richib86 View Post
    Since you have a facelift model you will need to splice the CANBUS wires together for both modules. This only applies to facelift models as the pre-facelift air suspension controller does not use a CANBUS connection.
    Quote Originally Posted by Wreed2039 View Post
    If you have the exhaust set in dynamic when you shut the car off it will come back on with the valves open/dynamic versus having to set the exhaust back into dynamic after start up. As for sound, guys that have this fitted now can likely comment to that.
    Cheers,
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    Just so buyers are aware. The CETE air suspension modules are sold out completely, even with CETE. It will be around 1 month before more modules will be available.
    www.europrice.us
    [email protected]
    Jan 31 2009
    2016 RS7-P
    Maybe you should get a GB going for the stock replenishment?
    Veteran Member Three Rings 3rdBNCC's Avatar
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    +1
    Just have a few questions before I pull the trigger.
    2014 RS7 Daytona Gray Pearl APR Stage 2
    10.319 @ 131.82 on GT260+
    Video:https://youtu.be/qnqCdZK3KnE
    IG: @Spikes_RS7
    2018 RS3 Mexico Blue Stage 2 (For Sale)
    2017 RS7 Performance Glacier White (Stock for now)
    2016 S5 Cab Black APR Stage 1 (Sold)
    2014 A5 Cab Black APR Stage 1 (Sold)
    2013 S7 White APR Stage 1 (Sold)
    2011 A6 Silver APR Stage 2 (Sold)
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    Quote Originally Posted by 3rdBNCC View Post
    +1
    I can help maybe since I just installed mine a week or so ago
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Established Member Two Rings Noizy Child's Avatar
    Jan 23 2017
    Pittsburgh, Pa
    yes this
    Veteran Member Three Rings Omnipotent's Avatar
    Jan 04 2011
    Windermere, FL.
    I would be in for sure!
    Alex...
    2013 A7 - Stage 2 - Gone
    2018 S7 - Tornado Grey/Arras red - ordered 7/20/17
    Aug 07 2008
    Dallas, TX
    Speaking with CETE about the possibility of a group purchase when these are available again.
    Cheers,
    www.europrice.us
    [email protected]
    Jan 19 2017
    Huntsville
    Quote Originally Posted by Omnipotent View Post
    Alex...
    That would make 2 people
    Jan 31 2009
    2016 RS7-P
    GB would be cool, everyone has to wait for stock anyways. Alex can get these over fast mail vs. waiting a bit for regular DHL.
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    Quote Originally Posted by cobrario View Post
    Sounds good. I will PM you once we have an answer on the GB. Thanks!
    IG: @Spikes_RS7
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    I could probably be convinced to join the GB, depending on the final price...
    Jan 22 2017
    Telford pa
    In for GB
    Veteran Member Three Rings Bassler's Avatar
    Apr 17 2016
    '14 S6, '18 XC90, '19 Raptor
    North Shore, MA
    I'm in
    2014 S6 Prestige DD/Kid Hauler | Glacier White, Lunar Silver & Aluminum/Black Wood | Black Optic | DA / Innovation / B&O
    APR DPs | Milltek resonated Valvesonic | EPL Stage 2 ECU/TCU | RocEuro | Forgeline 21s | Eurocode sways/links/AK/inserts | RS6 grill | Deval diffuser | XPEL/Opti/35% Llumar
    Nov 08 2010
    MD
    Count me in too.
    2021 SQ8 Prestige - Daytona Gray Pearl
    2018 Q7 Prestige - Samurai Grey
    Past: '19 Cayenne S | '15 S8 | '17 Q7 | '17 Macan S | '14 S6 4.0T | '14 Q5 3.0T | '13 RS5 Coupe | '13 Q5 3.2 | '11 S5 Coupe | '10 Q5 3.2 | '05 allroad 2.7t | '02 A4 3.0 | '00 A6 4.2 | '99 A6 avant 3.0
    Sep 07 2010
    Belgium
    I'm sure CETE would be in for a group buy (as i had a deal with them but since you became dealer of them i pulled the pull ;) ).
    Count me in!!.....if also european customers can take part of the groupbuy ;) (sad EU customer pay more in taxes then when a non EU customer buys one...).
    Veteran Member Three Rings darkstar's Avatar
    Dec 24 2004
    1998 silverado, 1986 c10
    Folsom, CA
    I'm in!
    Jan 23 2017
    Pittsburgh, Pa
    all the way in
    Aug 07 2008
    Dallas, TX
    Just an update for everyone. I spoke with CETE and they are looking at a mid-April release on the revised suspension module. I do not have further details on new capabilities or pricing unfortunately as of yet.
    CETE will contact me the second they have more details and pricing. I will post that up here as soon as I have it and am able.
    Stay Tuned!
    www.europrice.us
    [email protected]
    Jan 31 2009
    2016 RS7-P
    Nice, thanks Alex! Be sure to keep us current owners in mind. I know there is a mini USB port on the module, would be nice to upgrade our modules too.
    Oct 28 2014
    Northern VA
    I'll be following this as well.
    2018 Ara Blue RS3
    Jun 07 2016
    Europe
    Why anybody want to waste money on this Valve Control? It's much easier and cheaper just to cut wires and later if you want to sale the car wire it back.
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    Hmmm... I guess I can wait a little longer to see what's new.
    IG: @Spikes_RS7
    Oct 28 2014
    Northern VA
    Quote Originally Posted by Logtec View Post
    this is the active suspension controller, what are you talking about?
    2018 Ara Blue RS3
    Jan 04 2011
    Windermere, FL.
    Stay Tuned!
    Mid April.... so, I guess it's fine that my car isn't here yet.
    Feb 25 2014
    Texas
    Damn I just installed this thing last week! Hope we are able to update our current modules as stated above
    10.65 @ 129mph
