Results 1 to 40 of 68
    Veteran Member Four Rings brandonpham's Avatar
    Dec 06 2014
    Bi-Xenon Projector Removal For ZKW-R Lens
    Hey guys,
    Midway through the black housing, CC and ZKW-R Lens mod. Wanted some input on how you guys remove the projector. I attached some photos. I was looking at the torx bolts in the back of the housing as shown in the photos. These are AFS. Do I remove these to get the projector and shroud out?
    Also I wanted to get the trim around the turn signal out to paint it. I know Phil used a tried screw driver but is there any other option? Mine seems much more of a tighter fit than in his photos.
    Sent from my SM-G920T using Tapatalk
    May 20 2010
    You losing blinker fluid? I see that brown spot...
    Seriously, though, curious on this too
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Instead of removing the entire projector housing, I just removed the lens cage. It think there are 4 torx screws that hold the metal lens cage in place. Remove that and you can swap lenses and do any cut off shield mods you need.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Dec 06 2014
    Quote Originally Posted by rongeur View Post
    Is the 4 silver T25 torx you see in my photos?
    Dec 06 2014
    Jun 04 2011
    Clayton, CA
    Dang, I am trying to remember since it has been 2 years or so since I have opened my lights, I though they were on the same side but I may be wrong. Try loosening it up and see if the cage loosens. I do remember trying to remove the entire projector and couldn't get it to come out completely so I just removed the lens cage instead.
    IIRC, removing those silver torx will free the entire projector and from there you will get access on the other side for the lens holder screws.
    Build Thread
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Blinker fluid ?
    What is that brown juice ?
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    You have to remove the entire brown cage
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Dec 06 2014
    A bit of confusion here. The only screws visible are the ones from the back as shown in the first pictures, and the two to the right of the projector in the last picture. Not sure which ones to remove or begin removing. I'm assuming I should start at the ones int he back of the housing?
    In addition, how has everyone removed the shroud for the turn signal? Did everyone actually get a shaved torx driver like Phil did? My shroud seems like a much tighter fit compared to his.
    Jun 27 2011
    I used an allen key to get the torx screws out. Yea it didn't fit perfectly, but it fit well enough to get that extra fussy one snugged up.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 06 2014
    So it is indeed the 4 torx keys I have circled?
    Jun 27 2011
    I was referring to the clear corner torx, not the projector.
    My only experience putting clear lenses in the projector was on my b6 but I know we just removed the whole projector through the backside of the headlight (since you can't easily remove the front plastic lens on a b6 headlight) and it was pretty simple.
    -CP
    2017 Q7 3.0t
    Jun 04 2011
    Clayton, CA
    Quote Originally Posted by brandonpham View Post
    Yes, start with those screws and that should allow you to move the entire projector enough to access the lens cage screws on front side. I was never able to remove the entire projector for whatever reason but ended up not needing to swap the lens.
    Fly300kts (Phil) used to have a very elaborate STI lense swap DIY that had some great pictures for reference since he actually chops up the lens cage to re calibrate the focal length since the STI is not a direct swap. I assume since he does sell them on the side, he removed the DIY due to hobby profit conflicts (my guess). Maybe he will drop in and shed some light since he is probably the most knowledgeable about these lights.
    This was the thread: http://www.audizine.com/forum/showth...ictures-added)
    Here is another thread with some of my insight back then (2013): http://www.audizine.com/forum/showth...-Xenon-Upgrade
    Build Thread
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Are these the lens cage screws you're talking about? If so, how on earth did you get those out?? There's nowhere close to enough room to get them out with a regular t20 screwdriver
    2007 Porsche Cayman | 5MT
    Nov 15 2011
    Montreal | I sell in USD
    Quote Originally Posted by Ashtonts View Post
    You're supposed to remove the whole projector assembly. You then remove the chrome shroud of the projector from the rear (two tabs) and accessing these is now really easy.
    Removing the projector assembly is 5 T20's. Disconnect the harness from the rear access trap first.
    *****I sell in USD*****
    Dec 06 2014
    Quote Originally Posted by Axis View Post
    Saw the harness and threads earlier thanks guys I will try again. I believe I had T25 but I'll double confirm.
    Jan 17 2015
    Are they on the front? I removed the 4 T20's in the pictures above already and I don't see any more back there to take out.
    These ones? Or different screws?
    Nov 15 2011
    Yes and you have two on the other side.
    I'm saying that by memory. I've been taught to do it by an headlight guru.
    Jan 17 2015
    Then these two? I don't see how I could get these ones out either [banghead]
    Nov 15 2011
    3 on the left, two on the right.
    Jan 17 2015
    Okay I had initially thought that those were the ones and I took em out, but I guess I just wasn't pulling hard enough, so I figured they weren't the right ones. Thanks though, got it out finally haha
    Nov 15 2011
    Push the bottom motor from the rear trap untill it pops out of its "track". Its a dimple in the bottom of the housing.
    Once out, you'll have to remove the adjuster by pushing from the inside. (Push freaking hard) You'll understand once the projector is out.
    Jan 17 2015
    Yeah that was a total bitch to get out. Got it all back together though and the other side should be a total breeze since I know what I'm doing. Maybe I'll even do a write up when I do the second one.
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Yes please document with photos!!
    Nov 13 2015
    Ottawa
    Please do as i want to do this mod in the spring time. :)
    Jan 17 2015
    Quote Originally Posted by QuattriumMT6 View Post
    Quote Originally Posted by 706f7061 View Post
    Will do! Can't promise exactly when I'm going to get around to it, super busy with class and work lately, but I'll definitely document the process when I do it, hopefully in the next week or so.
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    No rush, thanks in advance. Really want to do the clear lens swap and would very much appreciate the documentation.
    Aug 24 2013
    Stockton, CA
    Can you take a comparison picture of the OE lens and the ZKW-R lens? I'm curious to see the difference in clarity. Supposedly out stock lens has a cataract finish.
    Jan 17 2015
    Already did. These are iPhone pics in bad lighting, but they show a decent comparison I feel. I'll try for some better pics on the next go around.
    Stock:
    ZKW-R:
    Together (stock on bottom):
    Jun 27 2011
    Here's a direct comparison shot:
    The OEM lens is cloudy.
    -CP
    2017 Q7 3.0t
    Aug 24 2013
    Stockton, CA
    How is the light directed with the ZKW lens without the cutoff?
    Jan 17 2015
    The cutoff isn't in the lens, it's the edge of the high beam flap inside the housing. I'm assuming the line in the lens is there to blur the cutoff slightly to make it look less harsh, but at the expense of light output.
    Jun 27 2011
    Yea. It's there to diffuse the cutoff a bit I think.
    -CP
    2017 Q7 3.0t
    Dec 06 2014
    Dec 04 2011
    Kansas City, KS
    Would the cut off be sharper if we removed the "RV" flap that is riveted onto the highbeam flap motor?
    Aug 24 2013
    Stockton, CA
    Ohhhhhhh that clears things up. Aside from the clarity of the lens in the comparison pictures that was the biggest difference I noticed between the two.
    Jun 04 2011
    Clayton, CA
    I cut my RV shield off.
    Build Thread
    Dec 01 2007
    San Jose CA
    Jesse I'd be very interested to see a pic of your cutoff with the RV shield removed.
    Dec 04 2011
    Kansas City, KS
    x2
    Jun 04 2011
    Clayton, CA
    I will snap a shot next chance, just go her back on the road today and need to realign them.
    Build Thread
