    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2004 B6 - cooling fans turning on randomly
    Car parked. Locked or unlocked.
    Cooling fans turn on at some time (can be few minutes, but also a long time) on their own.
    I think the fan speed even fluctuates (observed ones, can't confirm all the time).
    What might be causing it? Fan speed controller itself?
    What module controls the fans? ECU or Convenience control module?
    Possible that the ECU is bad?
    Or a relay? Where is/are the relay located that turn fan on/off?
    ECU is a 518AK.
    VAGcom output test seems to work. No codes.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    >> Moisture/water in the ECU compartment.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Veteran Member Three Rings Protection's Avatar
    Feb 24 2011
    Alfa Romeo Giulia Quadrifoglio, MK7 Golf R, B5 S4, B6 A4, B7 RS4
    Long Island NY
    Yes, what eljay said. It is a pretty common issue
    This was my rusted corroded relay (the relay block is directly beneath the ECU and Tcu units
    The fan relay is # 219
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    Ditto. Just had this issue 2 weeks ago. Had to replace the 219 and did the 373 just to be safe. That's the brake servo relay lol. Didn't want to find out the hard way if it was broken too.
    Feb 20 2010
    Brighton, MI
    Cool.
    I had similar issue on C6 A6 on passenger side relay (there it was the suspension system all messed up).
    Will pull relays this morning. Should be easy to spot/eliminate (likely have swap relay on hand if not special stuff).
    05 Golf TDI
