Results 1 to 1 of 1
    Registered User Three Rings
    Jul 27 2016
    Miami, FL
    LibertyWalk Alpha 9 Nissan GT-R | Vossen X Work VWS-3 20x11/20x12
    The Nissan GT-R even with it's 9th year in it's current body style is still a great tuner platform. Allen aka @LibertyWalkMe out in Atlanta, GA took his Alpha 9 GT-R even further and pretty much went ALL OUT! Wide-Body, 900AWHP, Air Suspension, Repainted in Nardo Grey and fully built inside out. I don't believe there was anything untouched! Check it out.
    You may have seen this car if you happened to be at #SEMA2016, it was a real head turner and very well put together. Enjoy the shots!
    Mod List!
    2013 Nissan GTR Black Edition
    Motor
    TSM 3.8L shotblock
    Callies Rods
    Diamond Pistons
    AMS Alpha 9+ turbo kit
    AMS Alpha Head Studs
    AMS Alpha cams
    AMS Alpha Ferrea Springs and retainers
    AMS Alpha Fuel Rail kit w/FPR, lines
    AMS Alpha Race Intercooler
    AMS Alpha Induction Kit w/TiAl BOV’s
    AMS Alpha Coolant Overflow tank
    AMS Alpha Boost Solenoid
    AMS MAP Sensor
    AMS Alpha Rear Badge and front fender decals
    AMS 90mm cast Downpipes
    AMS Carbon fiber Intake manifold
    ID2000cc injectors
    Dual Walbro 485 fuel pumps custom installed w/stock slosh tank
    Amuse 90mm titanium exhaust w/non-resonated Amuse mid-pipe
    TSM Oil catch system
    Powder coated valve covers matching engine cover wrinkle
    Full ARP fasteners on motor/engine compartment and oil pan
    Rexpeed carbon hood struts
    Transmission
    Shep Stage 2.5 Build with billet clutch baskets
    Body
    Fully molded liberty walk kit version 2
    Custom Nardo Grey BASF Glasurit
    Zele front fender carbon wheel vents
    2015 GTR DUAL LED HEADLIGHTS
    Brakes/Suspension
    Custom painted brembo calipers
    AP J Hook Rotors
    Endless MX72 front and rear brake pads
    Stillen Stainless brake lines
    Airlift suspension
    Stillen front and rear swaybars w/GotboostRacing endlinks
    Whiteline Eccentric Poly front control arm bushings for camber correction
    SPL adjustable rear camber and toe arms
    Sound/Radar
    JBL 660GTI 6.5” Components w/carbon trim rings custom installed front and rear locations
    Dual 8” Sundown SD2 8 long throw subs in custom sealed box in stock location
    JL Audio HD600/4 and HD750/1 amps (polished faces)
    Audison Bit One Processor w/custom install of control unit in front lower dash panel
    Custom rear trunk panel with amp/crossovers (polished faces) and processor
    Escort 9500Ci custom install with display mounted on rear view mirror
    Interior
    RSW Carbon center console overlay
    RSW Carbon door/window control overlays
    Rexpeed Carbon steering wheel center overlay
    Custom interior including
    Custom Recaro CS Sportsters with custom carbon fiber shells
    Titan Roll Cage
    LED lighting
    Click any photo for the full gallery!
    Nardo Grey is just amazing!
    20x11 front & 20x12 rear
    Airlift Air Suspension
    Liberty Walk Wide-Body
    Vossen X Work Collab Wheels
    Built up to over 900 AWHP for Show & Go!
