Results 1 to 36 of 36
    Aug 04 2016
    Athens,GA
    S6 turn signal problem
    This is the last thing I need to get fixed before inspection, my turn signals are working but it only lights up halfway. What I mean by that is it only lights up halfway in the drl lens. My dash indicators are blinking really fast, so I know something is wrong. Could it something simple as a bulb? I have the full led headlights, both sides do this and hazards are the same way.
    Video : https://youtu.be/eZY6LuNjYoo
    Feb 25 2014
    Texas
    This is a generalization but typically when the indicators are blinking more rapidly, as you're describing, it means the bulb's life is low and needs replaced.
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Dead bulb usually results in the relay being thrown off and the resultant rapid blinking.
    Aug 04 2016
    Athens,GA
    Okay, gotcha. So, all I have to do is replace the bulb and problem solved?, it seems weird that both sides died at the same time. I'll break into the headlights and so what I can find.
    Feb 25 2014
    Texas
    Yes. Replace bulbs.
    10.65 @ 129mph
    Senior Member Two Rings DB22's Avatar
    Feb 12 2014
    So Cal
    If you have full LED then you don't have a bulb.
    2014 A6 Prestige. VCDS, Chipwerke.
    Aug 04 2016
    Athens,GA
    Does that mean it's not repairable?
    Mar 26 2010
    US
    Quote Originally Posted by averagejoe26 View Post
    It might be a module that would get replaced.
    Have you checked for codes with a VAGCOM?
    Also looking at the lights do you notice any asymmetry between left and right turn signal lights blinking?
    BMW M3 Competition X-drive
    Aug 04 2016
    Athens,GA
    I have all new modules installed. Also getting a vag com this week. Lights light up evenly as far as I can tell
    Mar 26 2010
    US
    It may just be a loose connector.
    Did you change to full LED lights?
    The controller setting for the blinking may be different with full LED versus bulbs. There may also be a setting you can acess with the VAGCOM.
    Aug 04 2016
    Athens,GA
    No, it came with full led, just the modules were missing (salvage), I'll go over everything including the plugs on the modules this afternoon.
    Aug 04 2016
    Athens,GA
    Well, I checked plugs and modules are they look good. Still getting the same thing, but hopefully it may need some settings changed via vag com.
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    When asking for help it's best to disclose these sorts of details at the outset...
    Aug 04 2016
    Athens,GA
    Quote Originally Posted by Alister View Post
    Sorry, I am fairly new with these types of cars. I'll get the hang of it in a little while.
    Nov 07 2005
    RS6, M5
    Are you sure the replacement modules are the exact same part number as what was originally fitted to the car?
    Coding differences could also be the cause of the problem. I certainly wouldn't be assuming that the problem is with the headlights themselves.
    Aug 04 2016
    Athens,GA
    Modules I used for each headlight:
    1 x 4H0907472
    1 x 4H0907472E
    1 x 4G0907697F
    1 x 4H0907472B
    I went by the diagram on audiusaparts
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Does the white DRLs light up all the way across or does it stop at the same spot as the turn signal?
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
    Aug 04 2016
    Athens,GA
    Quote Originally Posted by rayray View Post
    Drl's go all the way, low beam and high beam work as well.
    Aug 04 2016
    Athens,GA
    All right, a little update; vag com came in today, and i went in and checked for codes. Seems to be a wiring issue, but i am not too sure. here is what i got.
    Saturday,12,November,2016,14:35:35:41138
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 16.8.3.1 (x64)
    Data version: 20161010 DS267.0
    www.Ross-Tech.com
    VIN: WAUF2AFC8DN091763 License Plate:
    Address 09: Cent. Elect. Labels: 4H0-907-063-V1.clb
    Control Module Part Number: 4H0 907 063 CG HW: 4H0 907 063
    Component and/or Version: BCM1 2.0 H12 0130
    Software Coding: 09072091073C9FE0A90008C4A0003800CF9CD208A208022180 01085C7B00
    Work Shop Code: WSC 02391 785 00200
    VCID: 6FEDB26DBE3DBE3A55-803A
    9 Faults Found:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 56878 km
    Time Indication: 0
    Date: 2016.03.09
    Time: 07:58:00
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 134
    Mileage: 56878 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 10:58:00
    01493 - Bulb for Blinkers; Front Left (M5)
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 14:40:00
    01497 - Bulb for Blinkers; Front Right (M7)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 14:40:00
    03188 - Bulb for Side Marker Light; Front Left
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 132
    Mileage: 56878 km
    Time Indication: 0
    Date: 2016.03.09
    Time: 07:58:00
    03189 - Bulb for Side Marker Light; Front Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 134
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.08.06
    Time: 16:50:00
    02258 - Door Opener Transmitter
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.08.06
    Time: 16:51:00
    03847 - Bulb 2 for Blinker Front Left
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 14:40:00
    03848 - Bulb 2 for Blinker Front Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 134
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.08.23
    Time: 18:37:00
    i won't be able to work on it until monday, but ill look over the codes and see what i find.. if anyone has any insight that would be fantastic.. , but if i dont have any luck, what am i looking at in terms of price at the dealer for this sort of problem?
    Nov 07 2005
    RS6, M5
    Still could be a coding issue (modules may be expecting a different variant of headlight for example).
    If the wiring appears to be untouched I would be assuming a problem with either the coding or module part number.
    Mar 03 2021
    Stow, Ohio
    www.Ross-Tech.com
    9 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 56878 km
    Time Indication: 0
    Date: 2016.03.09
    Time: 07:58:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 134
    Mileage: 56878 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 10:58:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 14:40:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 14:40:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 132
    Mileage: 56878 km
    Time Indication: 0
    Date: 2016.03.09
    Time: 07:58:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 134
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.08.06
    Time: 16:50:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.08.06
    Time: 16:51:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.05.03
    Time: 14:40:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 134
    Mileage: 56969 km
    Time Indication: 0
    Date: 2016.08.23
    Time: 18:37:00
    Hey I know this is a few years late on this but did you ever find a resolution to this? I am having the same issue on my 2012 A6 and can not figure it out, everything but the front turn signals works fine but they light up half way and occasionally flicker
    May 31 2007
    Beaverton, OR
    I'm also having this issue. I replaced my headlight and only half the turn signal works now.
    Junior Member One Ring
    Apr 13 2022
    newton ia
    half turn signal
    Quote Originally Posted by AgentHubcap View Post
    Has anyone found the fix to this problem?
    I work in a bodyshop and we recently worked on a 16 A6 and had the same issue on the L front turn signal. White DRL is fine but only half the amber lights up. We tried two new headlamp assemblies and tried all the modules off the right side and still no luck. $4000 headlight, not counting the modules and we can't get it to work.
    May 31 2007
    Beaverton, OR
    I’m on my third headlight and second set of modules. No luck here
    Apr 13 2022
    newton ia
    Thanks for the reply. we are sending the a6 to the dealer in the next week or so. Ill post back if I learn anything.
    May 31 2007
    Beaverton, OR
    Any updates on this?
    Apr 13 2022
    newton ia
    Not yet. The Audi dealer we took it to said we fried the headlight with a bad module. We told them that was funny because we swapped the modules from side to side and it didn't screw up the other headlight. I believe we are going to be taking it to a different dealer.
    The saga continues
    Apr 13 2022
    newton ia
    we took the Audi to another dealer and they said its a missing module. they orderd the part but we won't know for a few weeks if it fixes it. Evidently there are 4 modules in each headlight. a DRL module, corning lamp module, a main headlamp control module, and a turn signal (LED) module. I didn't dig to deep into the original lamp before it got tossed but I did find underneath one of the covers that comes on the assembly was a fan and module that needs to be swapped to the new lamp.
    I assume the turn signal module must be down inside the light somewhere. the main modules screw to the outside of the lamp and act as covers too.
    I'll post back when the repairs are complete.
    BTW, these Audi dealers are raping us bad. the diagnosis and labor charges are ridiculous. the first one charged us for a module it didn't need, the second one charged $700 to fix a broken two wire pigtail and refused to take back the first headlamp we bought because it wasn't defective. Anyone need a $4,000 headlamp?
    May 31 2007
    Beaverton, OR
    Quote Originally Posted by Mangogt View Post
    Thanks for the update! I only managed to find two modules in my headlight. I'm going to have to look at the old light again and see if there's a module in there that I missed.
    Apr 13 2022
    newton ia
    I wish I had our old light still here to take pictures. If I remember right, the fan and module are under a plastic cover in the center and I assume there is a smaller signal module hiding somewhere under of of the two side exposed modules.
    Apr 13 2022
    newton ia
    https://parts.audiusa.com/a/Audi_201...9-4044092937B1
    I believe # 18 is the module we are looking for.
    May 31 2007
    Beaverton, OR
    I think I found it! It slots into one of the covers. No idea how I missed it twice. I'm going to swap it in tonight/tomorrow. I'll post if it fixes my issues
    Apr 13 2022
    newton ia
    Awesome, hope it works.
    Apr 13 2022
    newton ia
    I just looked at the new headlamp we got stuck with. Sure enough under the outboard cover was the place for the 4th module. To bad we threw away our original broken lamp assy that still had the module in it.
    May 31 2007
    Beaverton, OR
    Just realized that I never followed up. My turn signal is working as expected again after swapping in the missing module
    Apr 13 2022
    newton ia
    Glad to hear you got it fixed. they really shouldn't hide modules like that.
