Results 1 to 9 of 9
    Senior Member Two Rings UWbadger91's Avatar
    Apr 03 2016
    Wisconsin
    S3 Drive Select and Exhaust Valves
    I have a 2016 S3 P+ and recently did the resonator delete. The day I got the car I coded the exhaust flaps off and now am considering turning them on to quiet it down when I'm using the car to go to clients. My question is if I set my individual setting to dynamic engine sound will that make the flaps stay open always or will it be the same situation where they only open up over 3k? Any help would be greatly appreciated!
    Established Member Two Rings ahfunaki's Avatar
    May 23 2016
    Northeast Ohio
    I don't have the exact answer to your question, but if you want to be able to open and close the flap anytime you want you could always get one of these: http://www.awe-tuning.com/switchpath-exhaust-remote
    2016 S3 Premium Plus | Glacier White Metallic Exterior | Black / Titanium Gray Interior | Black Optic | Technology | LED | B&O
    Emmanuele Design Springs | 15mm Spacers Front & Rear | aFe Magnum FORCE Stage-2 Pro 5R Intake | OEM Resonator Delete | AWE SwitchPath Exhaust Remote
    Apr 03 2016
    Wisconsin
    Quote Originally Posted by ahfunaki View Post
    That's a good idea! I feel like the engine sound adjustment is just changing the soundaktor, but I'm not entirely sure. I love how my exhaust sounds but I'm not sure how other nerdy accountants will like it when we're going to clients
    Veteran Member Three Rings chrisdazzo's Avatar
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    When I had the coding done by a local guy, what I understood was: by changing that byte, I had caused the S3's system think there were no longer valves to open or close.
    Why don't you just change the Drive Select mode and rev it up? I'm sure you'd hear a difference if you kept it under 3k RPM.
    '21 Ultra Blue x Black Nappa ▉SQ5
    Prem+ : S Sport : Black Optics : Carbon Atlas
    21" Black Optic Wheels : B&O Audio : S Beam
    034 Res-X Res Delete + X-Pipe : IE Polymer Intake
    12.5/15mm Spacers : 034 Trans Mount Insert
    35% Ceramic Tint : 3M Front PPF
    [_SQZME] : Previously: MKV Jetta 2.5, B8.5 A5, 8V S3, B9 A5 SB
    Jan 15 2010
    Santa Barbara, CA
    From what I've read, engine sound has absolutely no affect on the valves - it only controls the soundaktor. It's not even clear to me if dynamic engine mode affects the valves - they may only operate based off RPM and engine load.
    May 17 2016
    Hong Kong/LA
    The valves will only open above 3k even in dynamic, the only reason why people even need to do the VCDS mod or otherwise can just go dynamic. And yes, it does affect the exhaust sound, soundkator is a total different can of worm.. Soundkator only generates sound that can be heard inside the cabin, exhaust valve, you can hear/see the difference inside and outside of the cabin.. "See" as in even carbon build up evenly on all 4 pipes instead of just the inner 2...
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    Is there a plug that can be disconnected on the exhaust flap/valves to try them out open all the time? I am just curious as to how much different it is than stock valve operation.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    May 17 2016
    Hong Kong/LA
    Yup, you can disconnect them but then it will throw an error code, not a big deal though. It's nothing major, just a bit more bass at low rpm, just YouTube for it.
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Code out the soundaktor before you change the exhaust flaps. That thing makes everything worse than it really is.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
