Results 1 to 11 of 11
    Senior Member Three Rings Moose88x's Avatar
    Apr 13 2016
    B9 SQ5
    Ohio
    Hood release cable disconnected or broken
    Just got finished installing my crank pulley and PLM kit. I went for a drive and wanted to see the level of coolant to see if the bleed worked. All was good but when I pulled the hood latch it made a strange sound but I didn't think anything of it at the time. The coolant level was good I shut the hood (like and idiot) and then went to inspect the lever inside. The lever was loose so I assumed the spring slipped or lever broke. Well, I dug into it today and the spring and lever were in great shape, the cable was a little bent, but when I pulled it the hood still wouldn't release. Any ideas how to get my hood open to repair the cable? I could get my fingers on the inside lever under the hood but still nothing?
    I saw a video of a guy taking a Sawzall to the actual latch that connects the hood to the engine bay and replacing that. Any ideas?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    This is a pain in the ass to unlatch but it can be done. A guy from China used 3 guys and a broken pool cue to unlatch it. Happend to me and the guys at my body shop customized a wrench to undo the nuts that hold the latch to the top of the hood. I recommend taking it to a shop... It's a pain in the ass
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Apr 13 2016
    B9 SQ5
    Ohio
    Ya I'm thinking this is out and I'm going to a shop. A little over my head
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Quote Originally Posted by AllroadMass View Post
    Wrong model...grille doesn't pop out.
    Oct 30 2015
    Massachusetts
    Oh poop, sorry man.
    Sent from my Nexus 5 using Audizine mobile app
    Apr 13 2016
    B9 SQ5
    Ohio
    Oh poop, sorry man.
    No problem appreciate it though
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    There has to be a way without damaging too much.
    this guy cut his open, i would have done that last resort.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I am sure Audi has a way to get them open.
    I have to say the video of the guy, I am guessing a soldier, using a reciprocating saw on his RS4 is priceless. This is totally something my brother-n-law would do. He is a CSM in the Army. LOL
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by cspcrx View Post
    It's an A4 and he just kept the RS4 badge...
    @OP, cutting may be your best bet as that part is pretty easily replaced.
    I was looking at it last night, I don't see how you can manually activate it without using the cable.
    After some research here is what I would do:
    Remove the scratch guard on the bottom of the car. (Held on by a handful of screws)
    Once that is off you should be able to use a belt wrench to access the 3 bolts on the back of the latch.
    With those out you should hopefully be able to open the hood enough to slide the clips holding the cabling near the drivers headlight off and gain better access.
    Good luck
    Geoff
    Jun 21 2016
    Tampa, Fl
    Not sure if this will help. This happened to me last month. My hood would not unlatch. I took it to my work and attempted to look at it but realized quick that was not going to happen. I called my local audi dealer and explained what it was. The quoted me a diagnostic fee of 150$ plus labor. It took there mechanic 4 hours to get hood popped. When the service manager came up to me with the bill I was expecting 400$ at least. He said it was 175$ total after tax. He explained that it was part of the diagnostic to pop the hood for inspection. For once a dealer didnt try and screw me over. I will always check hood before closing from here on out.
    2012 S4 6mt EPL DP 189/57 11.6ET @ 121
    1995 Supra Single Turbo 600hp 11.5ET (AEM)
    2004 350z Twin GT3076 E85 600hp 11.3ET ( Haltech )
    2012 Genesis Coupe PTE 5858 e85 500hp 11.9ET ( Haltech )
    2006 GSX-R 750 Track Bike
