    Apr 11 2012
    2008 VW R32 Audi TT 225 mk1 audi B7 A4 1999 Jeep Xj B6 a4
    Corning NY
    changed out climate control module now get the following-
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    Went to vags site but didn't see anything on climate control other than the error. Is there a way to re program with VAG. thanks
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Quote Originally Posted by rfelker View Post
    35-00 - -
    You should be able to correct it by going to the Adaptation for the climate control module. Click on the drop down, and there "should" be something there to reset it to the correct VIN. My terminology might be off but there should be something there.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Apr 11 2012
    Corning NY
    thanks for the post I will check it out. thanks a lot. friggin code annoys me. Climate control works though. The bad one kept my fans running 24/7.
    Feb 27 2011
    Winnipeg
    http://wiki.ross-tech.com/wiki/index..._Data_Learning
    Do this
    Sent from my XT1058 using Tapatalk
    Aug 26 2005
    Yes, if you enter the correct code value in the adaptation channel, the VIN will be correctly adapted in the control module.
    The code value is given in the lable file in VCDS with the title the part number of your controller, under the Adaptations section. Use notepad to view the text lable file. C:/Ross-tech/VCDS/labels/[controller part number.lbl]
    Example: /labels/8E0 820 043.lbl:
    ; VCDS Label File
    ; Copyright © 2005+ Ross-Tech, LLC
    ; Audi A4 (8E)
    ; Component: J255 - A/C Heating Electronics (#08) - Climatronic
    ; P/N: 8E0-820-043-???
    ; includes measuring blocks, coding and adaptation
    ; created on 06/Sep/2005 by Sebastian Stange ([email protected])
    ; last modification on 22/Aug/2014
    ; requires VCDS 805.0 or newer
    ; measuring blocks & basic setting
    001,1,A/C Valve (N280),Current
    001,2,A/C Valve (N280),Duty Cycle,Range: 0.0...100.0 %
    001,3,High-Pressure,Signal (G65),Specification: 12.0...87.5 %
    001,4,Refrigerant Circuit,Pressure,Range: 2.6...29.0 bar
    B001,0,Potentiometer && Flap Alignment
    B001,1, , ,
    B001,2, , ,
    B001,3, , ,
    B001,4, , ,
    002,0,Compressor Shut-Off Criteria
    ; 0 = Compressor ON
    ; 1 = Compressor OFF: Refrigerant Pressure too High
    ; 2 = Compressor ON: Reduced Performance Requested by Engine Control Unit (ECU)
    ; 3 = Compressor OFF: Refrigerant Pressure too Low
    ; 4 = Compressor OFF: Fault Code stored
    ; 5 = Compressor OFF: Engine not running or less than 300 RPM
    ; 6 = Compressor OFF: ECON Mode active OR Basic Setting not performed
    ; 7 = Compressor OFF: System deactivated (by Driver)
    ; 8 = Compressor OFF: Ambient Temperature too Low
    ; 9 = Compressor OFF: Supply Voltage too Low
    ; 10 = Compressor OFF: Supply Voltage too Low
    ; 11 = Compressor OFF: Engine Temperature too High
    ; 12 = Compressor OFF: Requested by Engine Control Unit (ECU)
    ; 14 = Compressor OFF: Refrigerant Pressure too High OR High Pressure Sensor (G65) faulty
    ; 15 = Compressor OFF: Evaporator Temperature too Low
    003,0,Left Temperature Flap Control Motor (V158)
    003,1,Current Value,,Specification: 9...251\nTolerance (to Spec.): 3
    003,2,Specified Value,,Specification: 10...245
    003,3,Minimum Position,(Cooling),Specification: 9...71
    003,4,Maximum Position,(Heating),Specification: 189...246
    004,0,Right Temperature Flap Control Motor (V159)
    004,1,Current Value,,Specification: 9...251\nTolerance (to Spec.): 3
    004,2,Specified Value,,Specification: 10...245
    004,3,Minimum Position,(Cooling),Specification: 9...71
    004,4,Maximum Position,(Heating),Specification: 189...246
    005,0,Defroster Flap Control Motor (V107)
    005,1,Current Value,,Specification: 9...251\nTolerance (to Spec.): 3
    005,2,Specified Value,,Specification: 10...165
    005,3,Minimum Position,(Lower Stop),Specification: 9...71
    005,4,Maximum Position,(Upper Stop),Specification: 189...246
    006,0,Central Flap Control Motor (V70)
    006,1,Current Value,,Specification: 9...251\nTolerance (to Spec.): 3
    006,2,Specified Value,,Specification: 10...245
    006,3,Minimum Position,(Lower Stop),Specification: 9...71
    006,4,Maximum Position,(Upper Stop),Specification: 189...246
    007,0,Air Flow Flap Control Motor (V71)
    007,1,Current Value,,Specification: 9...251\nTolerance (to Spec.): 3
    007,2,Specified Value,,Specification: 10...245
    007,3,Minimum Position,(Lower Stop),Specification: 9...71
    007,4,Maximum Position,(Upper Stop),Specification: 189...246
    008,0,Air Recirculation Flap Control Motor (V113)
    008,1,Current Value,,Specification: 9...251\nTolerance (to Spec.): 3
    008,2,Specified Value,,Specification: 10...245
    008,3,Minimum Position,(Lower Stop),Specification: 9...71
    008,4,Maximum Position,(Upper Stop),Specification: 189...246
    009,0,Temperatures I
    009,1,Left Footwell Vent,Temp. (G261)
    009,2,Right Footwell Vent,Temp. (G262)
    009,3,Left Vent,Temp. (G150)
    009,4,Right Vent,Temp. (G151)
    010,0,Temperatures II
    010,1,Evaporator Outflow,Temp. (G263)
    010,2,Fresh Air Intake,Duct Temp. (G89)
    010,3,Calculated,Ambient Temp.
    010,4,Measured Ambient,Temp. (G17)
    011,0,Temperatures III
    011,1,Dash Panel,Temp. (G65)
    011,2,Temp. Sensor,Blower Speed,(V42) Specification: min. 2000 RPM
    011,3,Coolant,Temperature
    011,4,Idle Speed,Increase Request,Range: ON/OFF
    012,1,Engine Speed
    012,2,Vehicle Speed
    012,3,Compressor,Torque Status,Range: 0 = Valid/1 = Invalid
    012,4,Required,Engine Torque
    013,1,Fresh Air Blower,Actuation (V2),0.0...5.0 % = Fresh Air Blower (V2) OFF\n12.0...88.0 % = Fresh Air Blower (V2) ON
    013,2,Fresh Air Blower,Speed (V2)
    013,3,Status,Terminal 58d,Range: 0.0...100.0 %
    013,4,Status,Terminal 58s,Range: 0.0...100.0 %
    014,1,Radiator Fan (V7),Requested Value,Range: 0.0...100.0 %
    014,2,Radiator Fan (V7),Actual Value,Range: 0.0...100.0 %
    014,3,Air Quality,Sensor (G238),see Repair Manual
    014,4,Fresh/Recirculated,Air Request,see Repair Manual
    015,1,Rear Window,Heating (Z1),Range: R.wn.h.ON/R.wn.h.OFF
    015,2,Front Window,Heating (Z2),Range: ON/OFF
    015,3,Axiliary Heater,Actuation,Range: ON/OFF
    015,4,Convertible Top,,Range: Open/Closed/Not Installed
    016,0,Sun Intensity (G107)
    016,1,Sun Intensity,Left Side (G107),Specification: 0.2...4.5 V
    016,2,Sun Intensity,Left Side (G107),Specification: 0.0...1000.0 W
    016,3,Sun Intensity,Right Side (G107),Specification: 0.2...4.5 V
    016,4,Sun Intensity,Right Side (G107),Specification: 0.0...1000.0 W
    017,1,Status,Terminal 15,Range: ON/OFF
    017,2,Status,Terminal 75,Range: ON/OFF
    017,3,Status,Terminal 75,Range: ON/OFF
    017,4,Supply Voltage,(Terminal 30)
    018,1,Time
    018,2,Key Number,(Ignition)
    018,3,Windscreen Wiper,Status,1xxxx = via Rain Sensor\nx1000 = Wipe/Wash Mode\nx0100 = Wiper Speed 2\nx0010 = Wiper Speed 1\nx0001 = Intermittend Wiper Speed
    018,4,Fresh Air Blower,(V2) Duty Cycle,Specification: 45.0...54.0 %
    020,0,Seat Heating (Driver)
    020,1,Switch Position,(knurled Wheel),Range: OFF (0...10 %) / ON (10...100 %)
    020,2,Temperature,Actual (G59)
    020,3,Switch Position,(knurled Wheel),0 = Seat Heating OFF\n1 = 16...21 °C (or 18... 24 °C)\n2 = 22...27 °C (or 25... 31 °C)\n3 = 28...34 °C (or 32... 38 °C)\n4 = 35...43 °C (or 39... 46 °C)\n5 = 44...54 °C (or 47... 60 °C)\n6 = 55...65 °C (or 61... 69 °C)
    020,4,Seat Heating,(Passenger),Range: ON/OFF
    021,0,Seat Heating (Passenger)
    021,1,Switch Position,(knurled Wheel),Range: OFF (0...10 %) / ON (10...100 %)
    021,2,Temperature,Actual (G60)
    021,3,Switch Position,(knurled Wheel),0 = Seat Heating OFF\n1 = 16...21 °C (or 18... 24 °C)\n2 = 22...27 °C (or 25... 31 °C)\n3 = 28...34 °C (or 32... 38 °C)\n4 = 35...43 °C (or 39... 46 °C)\n5 = 44...54 °C (or 47... 60 °C)\n6 = 55...65 °C (or 61... 69 °C)
    021,4,Seat Heating,(Passenger),Range: ON/OFF
    022,1,Auxiliary Heater,(J364) active,Range: ON/OFF
    022,2,Auxiliary Heater,Signals,0001 = Aux. Heat. Activation Signal\n0010 = Aux. Ventilation Activation Signal\n0100 = Aux. Heating/Ventilation Activation Signal
    022,3,Fresh Air Blower,Requ. by Aux.Heat.,Range: ON/OFF
    022,4,Maximum Aux.Heat.,Active-Time
    026,0,Fault Code Conditions I
    026,1,Deactivation,Fault Code
    026,2,Refrigerant Circuit,Pressure
    026,3,Radiator Fan (V7),Requested Value
    026,4,Radiator Fan (V7),Actual Value
    027,0,Fault Code Conditions II
    027,1,Calculated,Ambient Temp.
    027,2,Vehicle Speed
    027,3,Coolant,Temperature
    080,0,Advanced Control Module Identification I
    080,1,Identification
    080,2,Revision
    080,3,Production,Date
    080,4,Manufacturer &,Test Stand Number
    081,0,Adanced Control Module Identification II
    081,1,Vehicle Identification Number (VIN)
    082,0,Adanced Control Module Identification III
    125,0,CAN-Databus Communication (Comfort)
    125,1,Instrument Cluster,(J285),Specification: Instruments 1\nRange: Instruments 0/Instruments 1
    125,2,Comfort System,(J393),Specification: Central 1\nRange: Central 0/Central 1
    125,3,Comfort System,(J393),Specification: Cent Elec 1\nRange: Cent Elec 0/Cent Elec 1
    125,4,Steering Column,Electronics (J527),Specification: St. Wheel 1\nRange: St. Wheel 0/St. Wheel 1
    126,0,CAN-Databus Communication (Comfort)
    126,1,Auxiliary Heater,(J364),Range: Aux. Heat 0/Aux. Heat 1/Not Installed
    126,2,Convertible Top,(J256),Range: Not Installed
    126,3,Voice Control,,Range: VoiceCmd 0/VoiceCmd 1
    126,4,CAN-Comfort,Status,Specification: 2-Wire\nRange: 2-Wire/1-Wire
    127,0,Version Numbers
    127,1,Network Managem.,Version Number
    127,2,Comm. Matrix Vers.,(CAN-Comfort)
    127,3,Comm. Matrix Vers.,(Climatronic)
    ; coding
    C00,Heating/Air Conditioning (J255) Coding
    C01,00?xx: Chassis
    C02,0 = Sedan/Avant
    C03,1 = Cabrio
    C04,00x?x: Heated Windshield
    C05,0 = Heated Windshield not installed
    C06,1 = Heated Windshield installed
    C07,00xx?: Sunroof
    C08,0 = No Sunroof OR Normal Sunroof
    C09,1 = Sunroof with Solar Cells
    ; adaptation
    A81,0,Learned Values (Vehicle Data)
    A81,5,Learned Values (Vehicle Data)
    A81,6,To start the process for vehicle data (VIN)
    A81,7,learning enter/save 26467 as new value.
    Vorsprung durch Technik
