Results 1 to 23 of 23
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    Flat bottom Steering Wheel Upgrade Issues B8 A4
    First of all i know there's so many threads out there for this problem. And im sharing this for someone else that might come across this.
    I purchased a flat bottom 3 spoke steering wheel.
    And then i purchased a new airbag.
    And then i go to fit it, i noticed that none of connections match.
    So from my research that i did, i was told that the b8 guys needs a "Dual Stage" airbag. So the seller made sure that it was a dual stage. Since no one was able to get me part numbers for the dual stage airbag, i purchased it and now im stuck with an airbag that doesnt fit my car. (For sale)
    Now for anyone that has done this swap before, please chime in and help us get this straight.
    Does anyone have photos of dual stage airbags and what are the part numbers.
    Thanks
    Garage:
    B5 S4 Santorin Blue Stage 2
    B8 A4 Premium Plus
    D4 S8 4.0T
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    i am in the same boat and i may, in fact, be a customer for your airbag.
    what is the part number of your wheel? would it happen to be either one of these two:
    8U0124
    4H0124
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    I just swapped to a FBSW and round airbag our of a B8.5 S4. Airbag part number is 8R0880201N6PS
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Mar 15 2012
    Quote Originally Posted by johnnySV View Post
    8U0124
    4H0124
    yeah, my steering wheel says: 8U0124C
    It came off the SQ5, it has light brown stitch and now i changed the badge to oem "sline"
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Mar 15 2012
    Quote Originally Posted by ToddBrunswick View Post
    Thanks for your input. So you purchased one from a b8.5 and it fit the b8 with that part Number?
    Would you happen to have any photos of the rear of the airbag?
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    any idea what the differences are between the 8U and 4H wheels?
    also, what is your airbag PN?
    since you got an 8U and your airbag doesn't work then if i get a 4H maybe your airbag will work for me !?
    Mar 15 2012
    my airbag PN is: 8K0 880 201 AE
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    with an 8U wheel i think you need an 8U airbag. i am shopping for the same thing
    Jun 08 2008
    Calgary AB Canada
    Why not just de-pin the connectors and pin it into the proper connector?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Mar 15 2012
    Quote Originally Posted by onceover View Post
    I hear what you're saying but when you de-pin something like this, they may not go in properly for a perfect fit, and being that small i think your would have trouble doing that.
    Plus, that goes into safety as well. The last thing i want is my airbag not to go off because it didnt make the right connection because i messed with it.
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I know this is off the topic but do they make the round style airbags in gray colour instead of just black?
    Dec 01 2011
    Quote Originally Posted by bluetori View Post
    i dont think ive seen that, i believe Audi stopped that ugly ass gray interior color with the facelifts lol.
    IG @theshawon
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Perhaps a Porsche steering wheel would work?
    http://www.ebay.com/itm/Genuine-Pors...tYASqa&vxp=mtr
    Jan 14 2010
    Georgia
    Damn so harsh :)
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by S4_SH1640 View Post
    I've done it before. It's a pretty affirmative click when the pin goes into the connector.
    Stock. For now...
    Veteran Member Three Rings Malk's Avatar
    Nov 17 2004
    Socal
    2013 A5 w/ Steel Grey interior:
    Jan 14 2010
    Georgia
    That's just the stock A5 wheel then, you know a part number?
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Maybe this you looking for:
    http://www.ebay.co.uk/itm/1523016388...191&rmvSB=true
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Nov 17 2004
    Socal
    Quote Originally Posted by Gunnark100 View Post
    Good find Gunnark100. Part # 8R0880201M from a Q5 (same connection as B8.5 A4)
    Nov 17 2004
    Socal
    Looks like "Flint Grey" which is darker than Steel
    This is an A6 with Flint interior
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    when depinning, you pull out the pink or purple lock connecter inside, use a special terminal tool and the terminals pull out of the connector. You then insert them back in with an audible click if they are seated. The only risk is not pinning it in correct order. just get a diagram of what each wire does and match to the other one. The black connector is likely steering wheel controls
    I think there is a vendor on here that sells harnesses
    Mar 15 2012
    Sooo how about my controls from steering wheel, after i disconnected it to try my wheel, now they dont work. Do i need to program them with vagcom or something?
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Mar 15 2012
    Can anyone chime in to why the dual stage airbag isnt working for my b8 a4?
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
