1. Start in the back seat by removing the rear AC vents
2. I used a trim removal tool slid into the side of the vent. You can also use a Audi/Merc pull tool (looks like a hook) that you pull from the inside of the vent. It slots into a hole in the side, you can see it in the pic
You should be done with the back of the console and now we need to move to the front of the car.
1. Make sure your car is on a level surface
2. Block your wheels with a wheel chock in case your parking brake is worn
3. Start your car and engage the parking brake. Then shift the car into Neutral
4. Turn the car off. (I then took the key out of range of the car so I did not mistakenly turn the car on while any of the electrical components are disconnected). DO NOT START THE CAR WITH CABLES DISCONNECTED. This will cause fault codes that you will have to remove.
