Page 1 of 3 123 LastLast
Results 1 to 40 of 89
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Weight Reduction Thread
    Hi All.
    I'd just like to start a little thread to see what people have done as far as weight reduction out there! Everybody talks about wheels, rotors, LWFW's, but what about the rest??
    My car sits at 3960 on a full tank (B8.5 6MT). What is a realistic goal for these? What have others trimmed theirs down to? I'm talking a race setup, not a very street-friendly setup. I have to believe there's 200 lbs to be saved between removing rear seats, replacing fronts, and putting the battery on a diet.
    Apr 05 2016
    Portland, OR
    Westwest has done a bunch and documented it.
    There is a thread over at AudiRevo about it.
    Here is the link: https://goo.gl/Ya4yws
    Geoff
    Aug 04 2010
    Queenz/Westchester
    Lol sorry, had to.
    Carbon body parts. Namely hood, roof and trunk, which also have a small negligible effect on lowering center of gravity helping with handling.
    Sent from my SM-G928V using Tapatalk
    Oct 20 2008
    Denver
    there's only so much you can do to shed weight whilst keeping the car functional for the street. obviously removing seats and interior will get the most weight off, but not for a daily. you could replace your battery for something like a braille battery to save 20-30lbs, but being the rear of the car will throw off the weight distribution. BUT shedding weight also depends on where and how it's used, for instance less unsprung weight at each corner will help you accelerate faster and corner and handle better - while carbon body parts, lightweight seats, stripped and gutted interiors will lower the overall weight and center of gravity.
    My daily wheels are 22lbs a piece, coupled with aftermarket BBK, in my case Stoptechs, which are A LOT lighter than OEM BBK, as with the JHM rear rotors. I don't run anything in the spare wheel well, and of course aftermarket stainless exhausts weigh significantly less than OEM exhaust.
    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    i wouldn't want to do anything extreme to mine, but on previous cars i ran lightweight batteries. one odyssey and one braille. i'm debating on whether to remove the spare and jack, and keep a tire repair kit and fix-a-flat in there instead.
    it might sound crazy, but one thing i noticed is the weight of the stock grille vs the chinese rs grille. maybe half? and that's on the nose of the car. wish i weighed them both, but wasn't thinking about it
    i don't think i would do it on the s4, but i would rather hear the exhaust than listen to music, and i wonder what the savings would be removing all the speakers of the b&o system. i don't need nav, either, but it's unfortunate that the mmi does a whole lot more than nav and sound
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    My car was 4182 with me in it, forget how much fuel. I think it was less than half a tank since I was at the track.
    Joking aside, the drivers seat is often where the larges reduction can be found. I dropped 40lbs and as a result had to run my CRX, race/street toy, at almost a full tank to make weight for class. On a 1987lb car it has an impact!
    I am all for lighter weight parts though. My wife jokingly asks, when I buy a new car part, if it is lighter. I did lighter weight wheels, VMR 803s and ECS two piece rotors on my S4.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I removed that chassis brace over the driveshaft tunnel because my exhaust was hitting it. Easily dropped 2lbs.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Got divorced, that saved a good 150 lbs, I'm guessing I never really knew.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Senior Member Three Rings draekin13's Avatar
    Jul 14 2014
    08 GTI, 11 F-350 King Ranch
    Kennewick, Wa
    Quote Originally Posted by Sudz View Post
    Hey this worked for me too, though it was in the 220+. Though she has been replaced with someone new that is a LOT less :) Best weight loss plan ever.
    2011 R8 v8 Manual Ice Silver
    2019 S4 Prestige Glacier White, Black Optics, S Sport
    Jun 12 2015
    CA
    The solid state aftermarket crank pulleys save weight over the oem crank pulley. (Insert debate about safety)
    Aftermarket exhausts save weight over stock.
    Test pipes and headers weigh less than stock cats.
    Aftermarket shocks like KWs weigh less than stock.
    Even tires can save weight. PSSs are nice and light.
    I've shaved 170 lbs off my Q5, with 76 lbs of that coming off rotational mass: 56 lbs off my wheel/tire combo, and another 20 lbs off my rotors.
    2015 Q5 3.0T | EPL E85 | APR SC pulley | KI 194mm crank pulley | CTS Turbo intake | AMS Alpha cooler | EC headers | Milltek valvesonic exhaust | KW V3 coilovers | 034 X-brace | 034 Trans mounts | 034 Rear sway bar | 034 ACAs | Girodisc LW front rotors | JHM LW back rotors | HRE P104 21x9.5 | Michelin PSS 285/35/21 | Autotech HPFP
    11.788 @ 115.64mph [ KI 194 / APR 57.73 | 104 | -350 ft. D/A ]
    11.950 @ 113.61mph [ KI 194 / APR 57.73 | E85/91 | +300 ft. D/A ]
    0-60 in 3.71
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    I wonder why people would want to spend thousands of dollars to lose several dozen pounds off of their car while themselves are over 200 pounds.
    I am glad a few people in this forum knows how important a driver's weight can impact the car's performance. If you are skinny, no only does it make your car lighter, but more balanced left to right.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    1) Lightweight Battery
    2) Carbon Fiber Hood
    3) Lighter seats. Not many options here without making the car lose it's feel; I'm a big fan of the Recaro Sportster CS.
    4) Spare tire, jack removal
    5) Wheels and Tires
    a) Tires are probably overlooked by most, but the Potenza S04s weigh 5lbs more per corner than the Super Sports, for example (stock 255/35/19 size- 24 vs 29 lbs)
    6) Two-Piece Rotors
    7) Lightweight Flywheel
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 26 2014
    NC
    does anyone have an RS grille off the car that they can weigh? I've got a stock one in the attic that I can weigh. Curious as to the difference
    and one other thing I forgot is that, while not adding much, wheel spacers add weight, so if you're running stock wheels and spacers, lightweight aftermarket wheels will take weight out of both
    Jul 05 2014
    Houston
    I wouldn't do it, but you could lose the crash bar if front of the radiator. Probably a little better cooling too.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Aside from the items posted already, take into consideration a clean empty car free of clutter, briefcases, clothes, papers, etc helps too. Floormats, trunk lining, spare/battery cover and a low fuel level will help lighten you up. Also, taking a nice healthy shit before you head out knocks off a few pounds 😂
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    My BF reduction and weight management strategy consists of lifting 3-5x a week, 2-3x HIIT, and the obvious monitoring macros #fitfam #iifym #gainz #swolepatrol #cbl
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by LINDW4LL View Post
    5) Wheels and Tires
    6) Two-Piece Rotors
    With the S4 already being so front heavy I never worry about the weight in the back of the car besides additional fuel. At autocross I run with just over an 1/8th of a tank but never take out my spare/jack/tools. As for tires, in 2015 I ran PSSs and in 2016 ran RE-11s. The RE-11s are 4lbs per tire heavier but they didn't disintegrate like the PSSs did (down to cords and chunks of rubber peeling off the outer blocks). That was 9 events on the PSSs and 15 events on the RE-11s. But I do agree that if you can find a lighter tire that works for your needs then use it. All that extra weight is further out so I would think saving a couple of pounds in the tire is more important than saving that same weight out of the wheel...both would be ideal of course.
    Aug 04 2010
    Queenz/Westchester
    Although expensive, Carbon Ceramic brakes can shed a good number of pounds off unsprung weight. Also titanium lugs, titanium spacers. Replacing the roof with cf will also get rid the sunroof
    Oct 26 2014
    NC
    Weight anywhere is good to remove, right? Even if the S4 is front-heavy, wouldn't removing weight from the rear help rotation anyways? No reason to have to accelerate a spare tire, jack, etc. in a curve (or any other time for that matter).
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    West bought a $2000 battery to shave 40lbs, so you could start there. Or just realize the S4 is a boat and go about your day.
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by Victor Newman View Post
    At some point it would have to hurt more than help...I have no idea at what point that is though. But imagine taking 1000lbs just off the rear...that car would be horrible to drive I'd imagine. And I thought having a little more weight in the back would actually help the back end come around...it will at least continue to come around due to inertia. Maybe a light back-end on power would rotate better like a pickup with nothing in the bed?
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Quote Originally Posted by eurotic View Post
    I don't see how saving weight on the tires is more beneficial than saving weight on the wheels. Both are unsprung rotational mass. I'd rather get a very lightweight wheel and use the tire that best fits the conditions in which you will be driving.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by yjypm View Post
    so those over 200# shouldnt bother trying to get light weight parts? LOL
    as much as i love my car and increasing its performance, my body weight's effect on my cars performance has rarely crossed my mind
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by DBFL View Post
    I was just meaning that since the weight of the tire is further from the center that it has a greater impact on rotational forces. So if you had to choose either saving 4 lbs from the wheel or 4 lbs from the tire I would think the 4 lbs from the tire would be better. It's a stupid hypothetical.
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by KRp220 View Post
    And not every person that's 200+ lbs is fat/overweight. But there are some of us that are obese and we still like lightweight car parts even though we might see the irony in the situation.
    Jan 01 2016
    Tampa Bay
    In theory that is correct. In reality it won't work that way. If you are on a road course you need better grip. The 4 pound per tire penalty of an RE11 vs a PSS is worth it since you get better traction. You'd probably end up with a better overall time having more traction vs saving the 16 pounds. That's my reasoning for saving weight on the wheels over the tires. Now, if you found two tires with the same performance specs you would obviously want the lighter one.
    S4 Build Thread
    Apr 29 2013
    Detroit, MI
    Quote Originally Posted by shadycrew31 View Post
    Shocked it took this long to see someone mention West.
    2018 S4 8AT
    2012 S4 6MT
    2006 S4 6MT
    2000 S4 6MT
    May 27 2013
    West Chester, PA
    Quote Originally Posted by BaumerS4 View Post
    They mentioned him up top as well. These new people just don't even know...
    Jan 09 2008
    Winnipeg
    100% agree. Compound wins. Also the RE-11 just have a better sidewall (probably where the extra weight is) for the heavy S4 too. Trying RE-71's next year for yet another compound improvement and it is lighter too for the stock size, win-win.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Holy moly.
    Dec 21 2014
    Milwaukee
    You won't turn back. I'm going to A7s next year and I'm assuming I won't turn back yet again...
    Dec 21 2014
    Milwaukee
    So what did his car end up weighing?
    Dec 21 2014
    Milwaukee
    Minor differences in weight distribution (100 lbs either way) can be worked out rotation-wise with tweaks to suspension and alignment. But yes, when pushed to extremes it would significantly change handling characteristics.
    Apr 27 2015
    canada
    Quote Originally Posted by jbullin2 View Post
    yeah good question.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Here is a good start...
    Replica 20" rotors with Hankook V12's 255/30/20
    Vorsteriner V-FF106 with Michelin PSS 255/35/19
    2016 S6
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    So many threads so little time. I can't recall where actually I saw a thread with S5 peelers was a noticeable difference with unsprung weight compared to the S4 peelers. Obviously they're larger and outweighed but lost a bit with the handling characteristics.
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Over 200lbs and worried about weight reduction?
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Oct 26 2014
    NC
    Quote Originally Posted by AudBoost View Post
    thanks for posting that up. aside from the hurdle of getting the wife to approve a wheel purchase, the 106's are my dream wheel
    Dec 30 2015
    Sacramento, Ca
    Guys, if you're over 200lbs with +30% body fat you can afford to lose some weight by making healthier food choices. If you're like me and over 200lbs with 10% body fat, you're probably focused on gaining weight, not losing it.
