Results 1 to 13 of 13
    Senior Member Three Rings hrpfg2's Avatar
    Aug 18 2015
    911, Tesla MYP x2
    Florida
    need your inputs on camber.
    hello all
    my S5 is lowered on H&R sport spring with spc camber kit. The camber is sitting at negative 2.1 (max out camber) and toe at .10 and tires are wearing out pretty bad.
    Ive read on the forum to set the toe to zero but the shop said by do so it would cause more wear..?
    So I need inputs from those of you that are lowered.
    What degree of camber/toe are you sitting and does toe indeed help with the wear.
    Senior Member Two Rings mufflerman's Avatar
    Jan 08 2009
    '01 S4 Avant 6 speed, '13 RS5, 993, '99 360 coupe 6 speed
    Sacramento
    Zero setting will wear the outside of the tire from cornering forces, it will also cause the car to resist turn in and push under faster corners. I would go somewhere in the 1.0 to 1.5 negative on a DD.
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    Where are your tires wearing? It is the inner shoulder of the tire? Right at the transition from sidewall to contact patch? If so, then that is from too much toe in.
    Here's a handy image for tire wear.
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Why have you 'maxed out' the camber? 2.1' is far too much and will destroy the inner shoulder of the tires, it will also make the car very nervous feeling on turn in.
    Ideally you want to be looking around -1.3' for the camber and a toe of 0.10' left and right so a total toe of 0.20'.
    Who set the car up when the SPC arms were fitted, it sounds like they didnt know what they were doing, the arms are supposed to correct the camber when you lower the car, not add more in.....unless you only track the car?
    There are a few confusing pictures on the Internet on how camber wear manifests itself on your tires and a few guys on forums who swear camber doesn't wear tires, I can hopefully assure you it most definitely does!
    He's a picture to conflict with the one above:
    And here's a link to a tire manufacturer who hopefully is up to speed on this subject, look at the description on shoulder wear.
    http://www.bridgestonetire.com/tread...ad-wear-causes
    Aug 18 2015
    911, Tesla MYP x2
    Florida
    Quote Originally Posted by mufflerman View Post
    thats the thing. camber kit is maxed out. 2.1 is the best they can get it.
    Quote Originally Posted by NaiveTurtle View Post
    here a pic of my last sets of tires. chucks are coming off..
    Aug 18 2015
    911, Tesla MYP x2
    Florida
    Quote Originally Posted by JamesRS5 View Post
    the camber was at -3.X before the spc camber kit. now that the camber kit is installed, the car sits at 2.1. the arms cant be adjusted anymore or else it will hit the inside of the fender.
    from what I am gathering, thats more than just camber wears.
    Feb 27 2014
    Dubai
    Are you sure these guys know what they are doing? Those SPC arms have enough adjustment to pull the camber out if they are adjusted correctly.
    Do you still have the original arms? I would pull the arms out, set them to the original arm length and then start again making sure they adjust them to make the SPC arms longer.
    Feb 27 2014
    Dubai
    Quote Originally Posted by hrpfg2 View Post
    Wait, what! -3' from a set of H&R springs, that's not possible, what else have you had fitted, something isn't right here!
    Aug 18 2015
    911, Tesla MYP x2
    Florida
    yea only mods are the H&R sport springs and spc camber kit
    May 20 2013
    Vancouver, WA
    That looks like toe wear to me.
    Jan 06 2008
    Dacia Sandero
    Arizona
    Toe kills tires. Not camber.
    I'd find another alignment shop. Springs with control arms should not be killing tires like that.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Aug 18 2015
    911, Tesla MYP x2
    Florida
    hmmm. toe is set at 0.1 where does it need to be?
    oem spec is .28-0.04
    Feb 27 2014
    Dubai
    Quote Originally Posted by 4RingRook. View Post
    Sigh
