Results 1 to 30 of 30
    Jan 09 2013
    ___
    Upper control arm removal - Pinch bolt problems
    I was in the process of removing my upper control arms and the pinch bolt broke inside the steering knuckle....of course. Does anyone know if the inside of the knuckle is threaded where the pinch bolt goes through, or is it like the tie rod's connection to the knuckle which isn't threaded and the bolt is held in place by a nut on the outside? Just wondering because before I just drill through I want to make sure there are no threads, because otherwise I'll have to get a screw extractor. From the tiny bit that I can see where the bolt head broke off there are no threads, but I want to make sure there aren't any deep inside.
    Thanks
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2011 Police Interceptor
    Stinky Island, NY
    Quote Originally Posted by tmh88 View Post
    Thanks
    It's not threaded, but it's long. Be mindful to drill straight or you'll be
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
    May 20 2010
    Have you considered using a punch to tap it out? I know it's sort of tight, but could help...
    Jan 09 2013
    ___
    Quote Originally Posted by deusilan View Post
    Great, because I was dreading having to extract that pinch bolt if it was threaded. Hopefully this won't be too painful. I'm sick of this damn car. I'm impatiently waiting for the engine to die so I'll finally have an excuse to get a B8.
    - - - Updated - - -
    Yep, I beat the hell out of it with a punch and a 20 lb hammer before I thought that it might be threaded. Didn't budge at all, which made me think it might have been threaded.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    remove the spindle completely and put it in a vise , it'll give you more space to work on the broken bolt.
    make yourself comfy, you do not want to screw up.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by jakeoboy67 View Post
    Do that, then drench it in PB Blaster and go have 3 beers, then come back and wail on it some more.
    Established Member Two Rings K2R1D3R's Avatar
    Jun 16 2015
    NorCal
    If understand what your having trouble with correctly then you need to Torch it till the metal expands and then it'll come out with a nice bang
    2015 Audi A3 TDI
    2012 VW Golf TDI (sold)
    2014 Audi S4 Moonlight Blue (sold)
    2013 Audi S4 White (sold)
    2001 Porsche Boxster S (sold)
    2007 Audi A4 (sold)
    Jan 09 2013
    ___
    The tie rod is already removed so I have the knuckle turned as far as it'll go and zip tied to the coilover. I've got plenty of room to drill.
    Quote Originally Posted by 924Carrera View Post
    I've been spraying it with PB blaster a few times a day for the past couple days and have sufficiently beat the shit out of it with a punch. Tried using a torch too, but no luck. It won't budge.
    Quote Originally Posted by K2R1D3R View Post
    Already tried that a couple of times with no luck. I couldn't get it too hot because the control arm bushings were starting to smoke and I didn't want to damage them. I did everything I could to avoid the flame from coming close to them, but the heat transferred through the metal and at that point there wasn't much else I could do without burning them up.
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    if you back off the nut on the other side and hit it with a hammer you'll get is started... I wouldn't drill if at all possible...
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    Why don't you try heating the bolt up in small doses and putting wax or use a candle. The heat will suck in the wax through capillary action and act kind of like a lubricant it's similar to how you solder copper pipes together.
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    Good luck. I got fruatrated at one point and was completely over it. It does get better and you'll be pleased you never gave up. I marvel at the Audi engineers and then feel pleased with myself when all is fixed and working properly.
    Sent from my SM-G920F using Tapatalk
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Seconded on taking the spindle completely out if the bolt is truly stuck. It's a bit more work but so worth it, especially if you have to drill. I just disconnected the upper control arms from the strut end and left them connected to the spindle. Soak it long and frequently with PB/kroil.
    I actually jacked mine up even worse trying to beat on it in the car and it mushroomed slightly and then bent and pushed part of the threads into the aluminum spindle... I spent an entire weekend removing one damn bolt. Had to drill a bunch, then hammer it through the other way, cutting it off every 1/2" or whatever to maintain clearance. It was like 4 years ago but it still get's me going thinking about it. Went through a few drill bits and a set of punches.
    Patience and beer is all you need. Then, be very generous with the antisieze before reinstalling. Coat it, then add some more for good measure, then a bit more, then reinstall . I've been able to push them out with my finger after breaking them free ever since.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Jan 09 2013
    ___
    I was able to get it out after about 6 hours of drilling, hammering, cutting and PB blaster. What a pain in the ass, I'm never doing that again. If my passenger side CV goes out I'll gladly pay whatever it takes for someone else to do it.
    Next step is to replace my tie rods, which are both shot (inner/outer). Does anyone know what size the ball joint/bolt is on the inner tie rod? I called my local autozone and they have an inner tie rod removal tool for rent, but the guy said it's meant for trucks and probably wouldn't fit mine.
    Jan 29 2010
    north ga
    Just FYI people, you should not be taking a torch to your spindles. Back on the B5's they were made of steel so using a torch was fine, and very common to do. The newer cars use aluminum and torching them could weaken them and make them more likely to break. I've already seen a couple pictures of people breaking off the piece where the pinch bolt goes. Torching it will only make that more likely to happen.
    Also, if you know that getting the bolt out is gonna be that much trouble, just buy a whole new upright. They can be had from part-out cars for $40-100. Spending that much is surely more worth it than wasting a whole weekend
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by BCsniper View Post
    That is probably also the source of the problem due to galvanic corrosion.
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    +1.... I bought uprights for my Passat for less than $80 from wolf auto on ebay. Once for the pinch bolt and also had to get one for a seize abs wheel speed sensor that I mangled pretty badly.
    It's overkill but I now take the pinch bolt out every year before the winter and clean them up and anti-Semite the heck out of them. Been doing that for past 4 years and it's one of my maintenance item for our vw/Audi.
    Sent from my Nexus 5 using Audizine mobile app
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by AllroadMass View Post
    LOL might want to check the autocorrect on that Nexus 5
    Oct 30 2015
    Massachusetts
    Lol. Sorry for my damn fat fingers.
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Good to know, I was going to suggest torching the spindle from my b5 experience, didn't realize these were aluminum. Not looking forward to tackling this again, I remember it being hell with the b5!
    Oct 30 2015
    Massachusetts
    Who wants to go halfsies? Looks like black magic.
    https://youtu.be/p5BLDNAepbs
    Jan 09 2013
    ___
    Good news. The entire upper half of my suspension is now disassembled! I took my coilover/upper control arms out today and disassembled them and it only took about 15-20 mins, which was a breath of fresh air after dealing with that damn pinch bolt. Just waiting for my new control arms and tie rods to come and it'll be back on the road by the weekend!
    Oct 30 2015
    Massachusetts
    Sweet! Don't forget to preload the suspension before you tighten the arms or you'll shorten the lifespan of the bushings.
    Jan 09 2013
    ___
    I finally got everything bolted back together and took it for a drive. The good news is the old cv/axle was the source of the vibrations, but the loud road noise still exists. I'm going to take it in for an alignment and have the wheel bearing replaced too. Hopefully that solves the problem.
    Nov 11 2010
    Rochester, MN
    This Autozone kit has the 38.4mm adapter that you need.
    19" B8 S5 Peelers
    Jan 09 2013
    ___
    I rented that kit and none of the adapter pieces fit tight enough. The 38.4mm was just slightly too big and would slip when I applied any pressure. The 1 7/16 was too small and I couldn't even get it over the inner tie rod bolt/ball joint. I ended up using a 1 1/2" wrench which was a better fit. I'm assuming the tie rod is actually 38mm, which is 1.496 inches, so the 1.5" wrench was basically a perfect fit. 38.4mm is 1.51", just a tad too big.
    Nov 11 2010
    Rochester, MN
    Well, that's a bummer. I apologize. I used that kit on my B5 and B6 A4's and B6 S4 and it worked great. I don't understand why it didn't work on yours, unless maybe the B7 has a slightly smaller nut?
    19" B8 S5 Peelers
    Jan 09 2013
    ___
    Quote Originally Posted by SlickFix View Post
    No need to apologize! I did it prior to even seeing your post. I have a B6 S4 and my inner tie rod was OEM. Strange!
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Lol broke mine and just replaced the entire knuckle
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    2021 SQ5
    2008 A4 Avant 6 speed
    Jan 09 2013
    ___
    I just got my wheel bearing replaced and that was the source of the loud road noise. No more vibrations from the bad CV and no more loud road noise!
