Results 1 to 15 of 15
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    2008 to 2017 B8/ B8.5 Audi A5 and S5 - Recommended Tire Pressures
    Update 1 - Added tire pressures for 2009 to 2012MY A5 and S5 models (North America). Added 2012 to 2017MY Audi A5 tire pressures (AUSTRALIA).
    Update 2 (2016-Oct-24): Added Tire pressures for 2013 - 2017 A5 and S5 Cabrio models (North America).
    __________________________________________________ __________________________________________________ ______________________________
    I have noticed that a lot of B8 / B8.5 A5 and S5 owners are clueless on the recommended tire pressures for their vehicles. Worse, they forget to look for the information in the Owners Manual. I am feeling generous today so here are the recommended tire pressures for the 2009 to 2017 B8/B8.5 A5 and S5:
    Note: What is shown on the tire label on the B-pillar (driver door jamb) are maximum load tire pressures when the vehicle is fully-loaded most of the time. Fully loaded means more than 2 front passengers most of the time.
    IMPORTANT: Always reset the TPMS system after you alter (add or reduce) the tire pressure for any reason (e.g., new tires) to prevent the system from giving you a false alert.
    FOR NORTH AMERICAN MODELS ONLY
    2009 to 2012 B8 Audi A5 and S5 models.
    Source: Page 296 of the 2009 Audi A5 Owners Manual
    Audi A5 with 2.0 4-cyl. Engine:
    225/60 R17 94H All-season
    Normal load (F/R): 32/29 psi
    Max. Load (F/R): 33/33 psi
    245/45 R17 96H All-season
    Normal Load (F/R): 32/29 psi
    255/35 R19 96Y XL High-Performance
    Max. Load (F/R): 32/32 psi
    265/30 ZR20 94Y High-Performance
    Normal Load (F/R): 35/32 psi
    Max. Load (F/R): 36/36 psi
    Audi A5 with 8-cyl. 3.2L Engine:
    225/60 R17 94H All-Season
    Normal Load (F/R): 33/29 psi
    Max. Load (F/R): 35/33 psi
    245/45 R17 95H All-season
    245/40 R18 93H All-season
    255/35 R19 96Y High-Performance
    Normal Load (F/R): 32/32 psi
    Max. Load (F/R): 33/32 psi
    265/30 ZR20 94Y XL High-Performance
    Normal Load (F/R): 39/38 psi
    Max. Load (F/R): 42/41 psi
    The following was taken from Page 250 of the 2012 Audi S5 Owners Manual:
    Audi S5 with 4.2L, 8-cyl. Engine:
    245/40 R18 93Y High-Performance
    Normal Load (F/R): 38/32 psi
    Max. Load (F/R): 41/38 psi
    265/30 R20 94Y High-Performance
    2013 TO 2017 B8.5 Audi A5 and S5 models.
    (Source: Page 217 of the Owners Manual)
    A5 with the 2.0L 4-cyl. Gasoline Engine with:
    225/50 R17 94H All-season Tires:
    Normal load (F/R psi): 32/29
    Max. Load (F/R psi): 33/33
    245/45 R17 95H All-season Tires:
    245/40 R18 93H All-Season Tires:
    Normal load (F/R psi): 33/29
    Max. Load (F/R psi): 35/35
    255/35 R19 96Y High Performance Tires:
    Normal load (F/R psi): 32/32
    S5 with the 3.0L 6-cyl. Gasoline Engine with:
    245/40 R18 93H All-season Tires:
    Normal load (F/R psi): 36/30
    Max. Load (F/R psi): 39/36
    245/40 R18 93Y High-performance Tires:
    Normal load (F/R psi): 38/32
    Max. Load (F/R psi): 41/38
    2013 TO 2017 B8.5 Audi A5 and S5 CABRIOLET models.
    (Source: courtesy of kmarei. Taken from Owners Manual)
    A5 CABRIOLET with the 2.0L 4-cyl. Gasoline Engine with:
    Normal load (F/R psi): 33/30 psi
    Max. Load (F/R psi): 36/39
    Max. Load (F/R psi): 35/38
    Normal load (F/R psi): 35/32
    Max. Load (F/R psi): 38/41
    S5 CABRIOLETwith the 3.0L 6-cyl. Gasoline Engine with:
    Normal load (F/R psi): 39/35
    Max. Load (F/R psi): 42/44
    FOR AUSTRALIA:
    2012 to 2016 (FL) Audi A5 2.0L TFSI Engine
    (Courtesy of julianwhitta. Taken from his vehicle's B-pillar tire pressure sticker label)
    225/50 R17 94Y
    225/50 R17 94H M+S
    245/45 R17 95Y
    Max. Load (F/R): 35/35 psi
    245/40 R18 93Y
    255/35 R19 96Y XL
    225/50 R17 98V XL M+S
    245/40 R18 97V XL M+S
    265/30 R20 94Y XL
    Normal Load (F/R): 36/32 psi
    Max. Load (F/R): 39/39 psi
    Note 1: Normal load is defined as having up to 2 front occupants in the car most of the time.
    Note 2: Full load is defined as having more than 2 occupants in the car most of the time.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Aug 30 2016
    Los Angeles, CA, USA
    Excellent!
    Feb 26 2016
    Melbourne, Australia
    Hmm, interesting. My owner's manual doesn't specify pressures, referring one to the placard on the B pillar instead. Pressures specified for my 2.0 are 33/29 (normal) and 36/36 (max). Which reminds me - I haven't checked the pressures in the last week!
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Quote Originally Posted by julianwhitta View Post
    That's because Australians, Europeans etc. can handle a door sticker with all the information on it. The US government has determined that that's too complicated for the average American, so they require that only the max load tire pressure be put on the door sticker with a note to consult the owner's manual for more information.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Dec 19 2015
    GVRD, BC Canada
    Hey JW! My mistake. I should have mentioned that the tire pressures are for North American models. I will make the correction. In the meantime, if you let me know the recommended tire pressures posted in your car's B-pillar, I will add those to the tire pressure table for future reference.
    Feb 26 2016
    Your wish is my command, plat:
    I confess I'm curious to know why the recommended pressures would differ from region to region.
    Dec 19 2015
    GVRD, BC Canada
    JW, thanks! I will add the Aussie tire pressures to the top post. I am curious to find out if the tire pressures for UK/Euro cars are the same as yours.
    The differences may have something to do with climate differences since temperature affects air pressure. Altitude also affects air pressure but I don't think this is the reason. Just my guess...
    Aug 13 2008
    Reston, VA
    And here are the Convertible pressures
    39F/35R 2 occupants
    42F/44R full load
    for both 18" and 19" tires
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Honestly, they probably just don't give the same level of detail regarding tire pressure based on occupancy numbers in America because our occupants are generally a lot heavier than other places. Just the other day I watched a car raise up about 4 inches after the fat ass owner clawed her way out of it. Fair to assume her Subaru's suspension wasn't going to last much longer.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by kmarei View Post
    39F/35R 2 occupants
    42F/44R full load
    Thanks, kmarei! I will add them in the top post.
    Senior Member Two Rings Hy Octane's Avatar
    Jan 25 2013
    FYI Tire Rack is adding a disclaimer to its XL/RF rated tires for 255-35-19's when shopping tires for the S5..
    "Important Note: XL/RF tires required. Customer must maintain higher tire pressure levels of 42psi for proper load. *********PLEASE COPY THIS NOTE ONTO INVOICE************"
    Always have kept them at 42 all round anyway, but it seems there is some kind of internal shredding that can happen inside the tire if it is driven at too low pressures for too long..Thus this notice.. Just a heads up..
    2013 S5 Coupe S-Tronic| Monsoon Grey | Premium Plus | Black Nappa Interior | MMI Nav Plus Pkg | Sports Diff | B&O | Advanced Key | 19" Wheels | H&R OE Springs | H&R Wheel Spacers 15mmF/ 20mmR |
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    I'm starting to think the tire pressures for the 3.2L V6 255/35-19 are wrong with being 33F/32R full load...considering the car is only 11lbs lighter than a 3.0T S5 which requires 38F/32R, been running 36F/35R at the moment to see what kind of wear I'll get, but just wanted to point that out.
    Instagram: donomoko
    - 2014 S5 3.0T Prestige - : Plain ole S5 w/ a few cosmetic mods...
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by NuVega View Post
    What's the full load PSI printed on your car's door jamb sticker? 33F/32R for full load seems to be too low.
    Feb 06 2010
    Las Vegas, NV
    Quote Originally Posted by plat View Post
    On the door jamb sticker it's listed for 18" wheels with 245/40-18 with 36F/35R, however in the manual for upsized wheels, for 255/35-19 it says 33F/32R for fully loaded car.
    Instagram: donomoko
    Dec 19 2015
    GVRD, BC Canada
    Yeah, I do not know what to say. The full load pressures listed in the Owners Manual seems to be wrong. I think you're on the right track trying out 36F/35R.
